02 sensor heater circuit malfunction - Drive Accord Honda Forums
Old 02-05-2009, 10:34 AM
richmon74's Avatar
richmon74 richmon74 is offline
2nd Gear
Send a message via Yahoo to richmon74
My scanner result shows these 2 error codes on my car:
P0141 ... 02 sensor heater circuit malfunction (bank 1 sensor 2)
P0706 ... trans range sensor ckt range/perf
how do I go about fixing these?
where do I locate d 02 sensor?
any help will be appreciated
2004Model Ex Auto Trans
Old 02-06-2009, 03:52 AM
richmon74's Avatar
2nd Gear
Someone should talk 2 me ....
Old 02-06-2009, 05:17 AM
HondaFamilyMan's Avatar
HondaFamilyMan HondaFamilyMan is offline
I got the P0141 code along with some misfires a few months ago, it ended up that the O2 sensor heaters needed to be replaced. $600 job.
I am not sure what your second code is for.
Old 02-06-2009, 12:39 PM
03exl's Avatar
03exl 03exl is offline
3rd Gear
I had the P0141 code about 1 month ago. Just search for it and you will find several threads on it. There was a Honda Service News article on that sensor. There is a better sensor out now, supposedly more corrosion resistant.
Actually, here:http://www.driveaccord.net/forums/se...archid=1269811
It's probably easier to just post the search results.
Edit: By the way, changing this sensor should not cost $600. I believe HondaFamilyMan was including other repairs in that figure. My dealer charged about $230 to the extended warranty folks (third party).
2003 EX-L Sedan I4 5AT
Old 02-06-2009, 12:40 PM
03exl's Avatar
3rd Gear
The thread with the service news article:http://www.driveaccord.net/forums/sh...ighlight=p0141
Old 02-07-2009, 06:25 PM
richmon74's Avatar
2nd Gear
I've gotten much infos on the error P0141 but nothing yet on P0706. Can anyone help?
Old 02-07-2009, 06:33 PM
Aviography's Avatar
Google is frighteningly powerful!
Here's one detailed response:
http://www.alldatadiy.com/alldata/AF...1611/134174205
Edit: Just saw that you (likely) have an I-4 and the page above is for a V6......, maybe there are some similarities....
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 02-07-2009, 07:18 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
Without an HDS (real Honda scanner) it's going to be difficult to diagnose the trans range sensor issue.
You need to know whether or not it's actually putting out the correct voltages for each gear you're selecting.
Does your PRNDL work properly on the dash? (gear indicator)
The a/f or O2 sensor heater issue is usually the sensor itself, the heater within the sensor has crapped out. You have to determine by the code displayed which bank (if a V6) and which sensor (front or rear) is showing the problem.
Old 02-08-2009, 02:06 AM
richmon74's Avatar
2nd Gear
No it doesn't work well. The "D" light blinks indicating and error according to the manual
Old 02-08-2009, 04:58 AM
richmon74's Avatar
2nd Gear
That's a lot of steps there. I don't even understand some of d terms there. More over, i don't av a HDS. I use an Actron AutoScanner Plus CP9180. can it do d work?
Old 02-08-2009, 05:04 AM
Aviography's Avatar
FredSVT is the expert here, I only found the info to pass it on, sounds like a trip to the dealership or a trusted shop that has HDS.
DA Moderator Team
Old 02-09-2009, 04:55 AM
03exl's Avatar
3rd Gear
I would just go to the dealer for that one... hopefully it's nothing major.
Old 02-10-2009, 06:07 AM
richmon74's Avatar
2nd Gear
The problem is that the nearest dealer is about 900km drive from my location through a bad road that makes the journey 12 -14hrs. Also you'll have to keep the car for about 4weeks b4 they work on it
Old 02-10-2009, 07:58 AM
03exl's Avatar
3rd Gear
Man! Where are you at?
Old 02-10-2009, 03:38 PM
Fredsvt's Avatar
Moderator
You can try with a generic obd2 scanner, but mostly they'll only display the code number. (if that) Many will just show a P0700, a general trans fault.
Does this car see much mud, heavy snow, or water?
BTW, with the light blinking, I wouldn't want to be driving it much. Especially not on a 900km drive to a dealership. I'd be worried of damaging the trans.
Title goes here
close
video goes here
