How to replace headlight bulb on 05 Accord V6? - Drive Accord Honda Forums
Old 03-04-2009, 06:45 AM
milo3814 milo3814 is offline
Hi,
The headlight (low beam) on the passenger site of my 05 Accord V6 went out this morning. Now I am reading some odd stuff about removing 'fender lining' to get to the bulb. Is that really necessary, or is there an easy way to do this.
Thanks,
Milo.
Old 03-04-2009, 09:14 AM
ypsibird's Avatar
ypsibird ypsibird is offline
6th Gear
You should be able to easily reach the passenger side from under the hood. The driver's side is another matter. I find it easier (done it both ways) to just pull the battery for the driver's side. But you should be in good shape to get to the bulb on the passenger side without pulling the fender liner.
2006 Accord Coupe silver 6 speed
Old 03-04-2009, 10:21 AM
dohcivtec's Avatar
dohcivtec dohcivtec is offline
Yes, I am a guy
pulling the fender is easiest. took me 15 minutes to read the manual, pull the fender, take bulb out, put bulb in, and push the pins back.
Codename: Trisha
2007 Honda Accord VP Alabaster Silver Metallic + fujita cai + tein basics + dampachi :) + 17mm rsb + TSX wheels
1989 Dodge Caravan LE(RIP BUDDY)
31.81 MPG!!!!
Old 03-05-2009, 05:13 AM
Thanks, yes, it was actually very easy to get to the bulb from under the hood. No idea why they make it look so complicated in the manual. There is no need to rip anything away from under the fender.
Old 03-05-2009, 06:25 PM
Aviography's Avatar
Wait until you have to replace the driver's side.
I did it by removing the battery, it's easier in my book.
TL shift knob, Hidden Hitch,
DA Moderator Team
