Whistling noise coming from front driver side wheel - Drive Accord Honda Forums
Old 03-16-2009, 02:08 PM
TomRock TomRock is offline
3rd Gear
So today on the right home from work I had the window down and noticed a high pitched whistling noise that seemed to coming from the front driver side wheel.
The whistling would start soon after I would come off a light and just keep droning on.
As soon as I tap the brake pedal it stops right away, but would always come back again.
The car has 13,000 miles on it, if it's the front pad I thought they would have lasted longer...
Old 03-16-2009, 02:12 PM
Kiribati's Avatar
Kiribati Kiribati is offline
In The Game
I had that on my old 96 Accord. I don't know if that's your problem but what had happened with mine was the ball joint (don't know the real name, you can picture it as a fist in your palm) that connects the wheel to the axle or whatever is out of lubrication and it's grinding against something.
But then again, on an 8th gen, I don't know if that's the problem.
2009 TW Honda Accord Coupe LX-S
Tint --23% Driver & Passenger/17% Sides & Rear
Mod -- HID White LED Dome, Trunk, & License Plate
Mod -- LED Hyper White DRLs
Mod -- 6k DIGITAL Brand HIDs (Retro-Solutions)
Suspension -- BC Racing BR Coilovers
Old 03-16-2009, 03:38 PM
YRMed YRMed is offline
Leased a VW_My life ****s
Which model accord do you have? My gen VII had hubcaps and the hubcap has an inner tension spring. Sometimes due to cold weather/dryness/rusting it would "sing"/produce a high pitched noise. Also, check your brake fluid. Perhaps your brake pads are not disengaging fully and thereby the surface of the brake pad is touching the rotor.
'12 VW Jetta 2.5/5spd lease - WORST decision ever
'11 Infiniti G37x - Sold
'09 TW 6-6 - Sold 1/1/2011
Old 03-16-2009, 04:51 PM
3rd Gear
I have a EX sedan. Do the factory brakepads that come on Accords have those "sqealers" that make noise when the pad is worn down to a certain point?
Title goes here
close
video goes here
