2007 Accord power windows. - Drive Accord Honda Forums
Old 03-22-2009, 09:10 AM
07accord 07accord is offline
Question 2007 Accord power windows.
Hey guys im new to this forum so hello all. im very familiar with the search and i made sure to search my dilema before posting, but to my dismay i found no info on my issue.
I have an 07 Accord SE. The driver's window works fine. However, the other 3power windows stopped working. When I press the buttons, I can hear the click each time but the regulators won't budge. The "window lock" button was released. I also checked the fuse and it's fine. Where should I check next?
i know this has happened to others and im not quite sure why i cant find anything on it. Any ideas on the matter will be very helpful
Thanks in advance,
Issac
2007 Honda Accord SE
Old 03-22-2009, 01:24 PM
thefourth thefourth is offline
Anyone but the Red Wings
Not sure if this will help, but here is the procedure for reseting the power windows from the service manual:
1. Turn ignition on.
2. Move driver's window all the way down using the switch.
3. Open the driver's door.
NOTE: steps 4-7 must be done within 5 seconds of each other.
4. Turn the ignition switch off.
5. Push and hold the driver's window down switch.
6. Turn the ignition switch on.
7. Release the driver's window down switch.
8. Repeat steps 4-7 three more times.
9. Wait 1 second.
10. Confirm that AUTO UP and AUTO DOWN do NOT work. If they work, go back to step 1.
11. Move the driver's window all the way down by holding the driver's window down switch to the auto down position.
12. Pull up and hold the driver's window up switch to the auto up position until the window reaches the fully closed position, then continue to hold the switch for 1 second.
13. Confirm that the power window master switch is reset by using the driver's window auto up and down function.
Hope this helps.
Mine:
'07 Accord SE 5spd, Taffeta White SOLD
'96 Accord LX 5spd, SOLD at 303K miles
'03 Element EX 5spd Daily Driver
'08 TL-S 6spd Pearl White
In the household:
'09 Civic EX AT SOLD
'08 Pilot EX-L
'03 Ridgeline RTS
'01 Civic LX AT (retired)
OEM 8th gen V6 coupe wheels for sale: http://www.driveaccord.net/forums/sh...ad.php?t=59460
Old 03-22-2009, 04:15 PM
9. Wait 1 second.
Hope this helps.
thefourth., thank you
Unfortunatly that did not help .i tried it twice, reset yet didnt fix the other windows.
Please someone help me out, its gettin warm out..
Old 03-22-2009, 05:35 PM
Aviography's Avatar
OP,
This thread is moved to the Problems & Solutions forum, and your other thread is considered a Double Post for the same thread, and is deleted as per forum rule.
Welcome aboard, and sorry to hear about your problem.
TL shift knob, Hidden Hitch,
Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960
DA Moderator Team
Old 03-22-2009, 05:42 PM
Originally Posted by Aviography View Post
OP,
Hey thank you for that, i couldnt delete thread... i found the tech and solution after.
Old 03-26-2009, 01:19 PM
anyone!?
Old 03-26-2009, 07:59 PM
Does anybody on this forum have any ideas?? even a single one besides 'Thefourth'??
Old 04-09-2009, 10:10 PM
Cleankill's Avatar
Cleankill Cleankill is offline
4th Gear
Bring it to the dealer if it is under warranty...
My rear right window make some buzzing noise and they replace the electric motor under warranty.
07' J30A5 Auto 4Dr, 20mm TL-S rear sway bar, Neuspeed front tower bar, Debadged "SE"
Old 04-10-2009, 10:29 PM
sjlee's Avatar
sjlee sjlee is offline
6th Gear
Thanks in advance,
Issac
Can you open the other windows with either the buttons on the driver's door or the buttons on each individual door? My first guess is that it's a problem with the window lock feature.
2007 Honda Accord EX-L V6 AT 4DR (Alabaster Silver Metallic) - splash guards, wheel locks, OEM foglights
2005 Honda Pilot EX-L (Desert Rock Metallic) - splash guards, wheel locks, crossbars, side steps, towing package
1995 Yamaha FZR600 - sold
2001 Chevrolet Cavalier LS sedan (silver) - sold
1996 Acura Integra GS-R sedan (Black Currant Pearl) - sold
1995 Suzuki Katana 600 (teal) - totalled; sold
1984 Chevrolet Celebrity (brown) - first car; sold
Old 06-22-2009, 10:25 AM
accord 05 accord 05 is offline
My First Post
The exact same thing happened to me today. Did you ever find a solution? Thank you.
Old 06-22-2009, 03:46 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
unfortunately you're going to need to do diagnosis on the b-can network to see where the signals are being lost.
You'll need the factory manual to do it, with the following, the HDS, a scanner that can read the b-can system, or there's a manual mode mentioned in the manual to get information out of the system.
Have you tried to disconnect the battery? Negative first, then positive, hold the two cables against one another for at least a minute. Then put the positive back on, then negative and try and reset the windows again.
Old 05-22-2011, 03:13 PM
seajayemm seajayemm is offline
My First Post
This is an old thread but I have a fix for this problem. Its cheap and easy. If your driver side window works and the rest do not and all you hear is a clicking sound this will work for you. My sister in law has an 07 Accord and hers was doing this. The passenger windows were not getting power at the fuse on the inside of the car. What I did was took a speaker wire (small gauge) and jumped it from the driver side to the front passenger side. Now all windows work. Take the wire and strip about an inch and a half on both ends. Take 1 end and wrap it around a post on the driverside fuse, then take the other end of the wire and wrap it around a post on the front passenger side. BAM your windows will work again.
Old 05-22-2011, 07:18 PM
stiller fan's Avatar
stiller fan stiller fan is offline
<<< highway queen! :-)
that's a great way to fry your electrical system, or start a fire down the road.....
Originally Posted by craigslist ad
“I'm 5'6'brown eyes,38 old,no child,but like.” Please press 1 for English. No child, but like. You are child-like? You like no child? You like children? Sorry, the subscription for my translator is expired.
PROUD FAN OF STEELERS, PIRATES, AND PENGUINS
DA moderator
2007 Honda Accord LX Coupe 2.4 MT (163k miles)
gone, but not forgotten:
1993 Honda Accord (341k when sold, retired @ 369k)
1999 Honda Accord coupe (168k when sold, last check-in @ ~197k, blown head gasket)
Old 05-26-2011, 11:31 PM
cp1966 cp1966 is offline
9. Wait 1 second.
Hope this helps.
Regarding #8, are all of the steps with the drivers window? Or do I repeat the steps with each different door (eiother at that door or using the main switch in the drivers door?)
Old 05-27-2011, 11:05 PM
madamd madamd is offline
2nd Gear
NOT very SMART
