The car vibrates between the speed of 50 to 60 MPH - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 04-20-2009, 08:08 PM
ksomesula ksomesula is offline
The car runs smooth between 0-50 mph. When it reaches 50mph, it starts to vibrate. But when it crosses 60mph, it becomes smooth again.. I'm not sure what the problem is??
Old 04-20-2009, 08:19 PM
golftango's Avatar
golftango golftango is offline
FL350
Balance your tires.
GolfTango
My Flickr Page
'13 Suzuki Kizashi S 6MT
'12 Honda Pilot EX-L
Old 04-20-2009, 08:22 PM
i just got all the 4 wheels alligned
Old 04-20-2009, 08:26 PM
tech104 tech104 is offline
mechanic
you should have the run out of your rims checked. see if they are bent at all. Does it happen when you are braking?
Old 04-20-2009, 08:34 PM
superballz00 superballz00 is offline
5th Gear
Did they do a balance as well?
97 Accord LX Coupe A/T 28mpg
09 Accord LX-P A/T 31mpg
Pagani Zonda - When I win the lottery and move to Europe.
Old 04-20-2009, 08:35 PM
No...It vibrates only when i accelerate and that to only between 50-60mph...
I guess they did not balance the tires ...
Old 04-20-2009, 09:30 PM
Joe818 Joe818 is offline
4th Gear
it can be the balance or the alignment but same shit is wrong wit mine 60 to 70 it has a vibration i checked one of my rims is ****ed up has a speed wobble at that speed and me being the moron who does all the mechanical work on my car i rotated my tires i forgot to put my wobbly rim in the front now its worse in the back its okay new rims coming soon
Old 04-21-2009, 10:07 PM
tdmoreno tdmoreno is offline
I too have vibration from 60-70 and had my wheels balanced twice. The place that did it said that I had a slightly bent rear wheel so I replaced it and had them balance them again. It did not help. I have read lots of posts on the internet and the number one response seems to be wheel balance. Instead of balancing them again I borrowed the wheels off my dad's 06 hybrid and had the same exact problem. I have a horrible feeling that it is some type of engine related problem.
My shaking occurs when I jump on the freeway and then due to traffic conditions, cruise at a low rpm at about 60 and then accelerate slowly.The vibration lets up after 70. I can recreate the issue on all freeways and in turns. Anyone else having similar issues? I have a 4 cylinder 05 lx...
Old 04-21-2009, 10:24 PM
Venom10's Avatar
Venom10 Venom10 is offline
check the tires for bumps and the rims as well, if they seem to be ok, you will need balance and/or alignment
2004 HONDA ACCORD EX-V6 COUPE
NIGHTHAWK BLACK PEARL,
STILL OEM...YET, just got a brand new set of General Tire Altimax HP
Old 04-21-2009, 10:30 PM
I'm not trying to be rude but i just told you that I swapped all of my wheels for a set off of my dad's car and still have the same problem so I don't know how checking the tires for bumps and the rims as well could be of any help
I also stated that I have had the wheels balanced twice.... I guess you are trying to be helpful so I appreciate that... maybe you were just responding to the other guy and not me.... I hope someone might be able to shed some light on this situation..
Old 04-21-2009, 10:50 PM
4th Gear
mine happens when i accelerate slowly from 60 to 70 too then it lets up after i get to 70 i still think its my rim because when i rotated it i get more of a shaking in the rear end now
2004 White Coupe I4 6Mt
84,xxx Miles
Aem CAI
Tints
Tein Lowering Springs
18" White Axis Halo
-Blue Muteki Lug
-Blue Enkei Valves
Oem Front Lip
Depo Blackhousing Headlights
-6000k HID LB
6Mt Swap
-Act Stage 2 Clutch
-Act Racing Flywheel
Not Installed:
Depo Blackhousing Fogs
-3000k HID Fogs
-Lamin-x Yellow Film
Future Mods:
DC Header 4-2-1
Custom HKS Hi-P Exhaust
Eclipse Navi
Neuspeed Short Shifter
Old 04-22-2009, 07:24 AM
kbd kbd is offline
4th Gear
You might be an inner CV joint replacement candidate.......
Follow this thread.....I have not had opportunity to address my car yet.
http://www.driveaccord.net/forums/sh...509#post393509
If you remedy the symptoms, please post what you did!
2010 Accord EX-L V6 sedan, AT, Bali Blue Pearl
Gone: 06 Accord V-6 sedan, 6 MT, Carbon Bronze/Ivory - but still in the family -
Old 04-28-2009, 10:18 PM
bump... any updates?
Old 04-30-2009, 01:00 PM
bump
Old 05-01-2009, 07:00 AM
mike8o88's Avatar
mike8o88 mike8o88 is offline
Send a message via AIM to mike8o88
I had a problem like this with my 2004 i4 with 67000 miles. It would shake while accelerating. After about 60 I wouldn't feel it as much. Brought it to the Honda dealer where I bought it used. They told me I needed a new transmission because the bearings in the transmission were poorly made...
2004 Accord I4 Ex
Fogs, JBL's
Title goes here
close
video goes here
