a different oil change procedure...? - Drive Accord Honda Forums
Old 08-04-2005, 08:31 AM
avexnsx's Avatar
avexnsx avexnsx is offline
4th Gear
here
found this to be quite interesting...
Old 08-04-2005, 09:35 AM
CA05LXDriver's Avatar
CA05LXDriver CA05LXDriver is offline
5th Gear
Location: Changing the world, one urinal mint at a time!
Conspiracy to create more starter motor/battery claims???
If you pre-fill your oil filter, you are doing enough. There is virtually no load on an engine at idle, and residual oil in the system will lubricate the engine sufficiently at startup, regardless of oil low oil pressure.
Durka Durka
Old 08-04-2005, 09:40 AM
BenjiBoy650's Avatar
18. Top up the oil to the upper hole on the dipstick but do not overfill. The highest notch on the dipstick is the fully hot/overfill mark. The oil level shouldn’t be any higher than the second hole even when hot.
^^ is that true? If so, I'm in trouble...
Old 08-04-2005, 11:38 AM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
My oil light goes off in 2 seconds after I change oil. I don't think all the extra crapolla is worth the time & trouble.
Old 08-04-2005, 12:03 PM
Inspector1's Avatar
Inspector1 Inspector1 is offline
O do u know the buffinman
That dude must work for the Government and change his oil while he is at work(when he's not on line) .
Oh well it sounds like good advice for subby owners... heck why not tear down and rebuild after every drive since it's such a race car
I1
"Any man who thinks he can be happy and prosperous by letting the government take care of him better take a closer look at the American Indian."
- Henry Ford
4 Honda family...
08 EXL V6 W/Nav PMM 4Dr @ 92K miles
My daily driver (When the roads are salt free)
08 Pilot EX-L Dark Cherry Pearl @ 42K miles
The Mrs. daily driver
The Kids
02 EXV6 Naples Gold 4Dr @224K (Trans refresh @156K)
06 EXL I4 CBP 4Dr @ 82K Acquired 3/2013
DA RULES !`
Old 08-04-2005, 01:43 PM
04blkpearlcoupe's Avatar
04blkpearlcoupe 04blkpearlcoupe is offline
Rush fan
all that is a waste of time. unless you let your engine sit without oil for hours on end, there will still be a layer of oil on the surface of everything in the engine. In fact, when a car is parked all the oil is in the pan!
Gabe
2004 Accord LX coupe 2.4L auto 149,000 mi
1989 CRX 500,000 mi (sold)
Old 08-04-2005, 01:59 PM
VTECaddict's Avatar
VTECaddict VTECaddict is offline
Out of Control
yeah, the top hole is the "max" and the bottom hole is "min". it should be somewhere in between. how far do you fill it up?!
2006 BMW 330i 6MT (Alpine White/Terra)
Old 08-04-2005, 02:00 PM
I fill it up to the top when it's off and cold. My VTEC engages quicker/more often like that ...no, seriously...
Old 08-04-2005, 02:04 PM
Inspector1's Avatar
Except what remains in the filter!!
I1
- Henry Ford
4 Honda family...
The Kids
DA RULES !`
Old 08-05-2005, 05:41 AM
SSMV6's Avatar
SSMV6 SSMV6 is offline
39.1 going on 40mpg!
Don't worry about overfilling if it's still below the "max" mark when it's cold.. Engine oil doesn't expand that much when warm.. I like having more oil than less.. Your car always burn a little bit of oil anyway. It's ATF that expands by like 20% or something when warm.. .. That's why there's two sets of max-min marks on most ATF dipsticks... One for the cold reading and one for the hot.
2013 Accord EX-L Navi 5,058 miles and counting...
YTD avg mpg = 29.58 . . . . Last tank mpg = 30.30
2005 Accord EX-V6 Sedan (3/05-1/13) retired at 127,110 miles
1993 Accord 10th Anniversary Edition Sedan (5/08-7/10) Retired at 153,007 miles
2000 Civic Si (5/00-3/3/05) Retired at 59,500 miles
Old 08-05-2005, 12:00 PM
F6Hawk's Avatar
F6Hawk F6Hawk is offline
7th Gear and going strong
The problem with over-filling engine oil is not expansion, but the forming of bubbles, or foam. When this happens, the cooling capabilities of the oil are reduced, the engine will get hotter, and the oil can be "burnt" quicker. The lube qualities will still be the same (unless you run it like this for a long time), but who wants their engine to run hotter because of foaming oil?
Old 08-05-2005, 12:04 PM
SSMV6's Avatar
F6Hawk, you misunderstood my post.. What I meant was you could still use the marks on the dipstick to determine if you have enough oil in the crankcase in all engine oil temperatures. I'm not trying to say that it's ok to add another quart of oil to "top it off" after you've reached the max level on the dipstick.
I stuck in the ATF dipstick example to show that that engine oil doesn't expand as much as ATF when it's heated so the volume difference when it's cold versus hot is negligable. Hope that clears things up.
Old 08-06-2005, 04:18 PM
benjamming benjamming is offline
6th Gear
I lost all interest in the post when I read "DO NOT USE 0W or 5W as it is too thin". They don't know much about oil.
2002 Accord EXVL Auto Sedan - Nighthawk Black Pearl / Quartz, fog lights, mud guards, wheel locks, trunk tray
1994 Pontiac Grand Am GT Auto Coupe
Old 08-06-2005, 04:23 PM
Uhm...maybe it is too thin for their Subies?
Old 08-19-2005, 09:57 AM
Rather Ride's Avatar
Rather Ride Rather Ride is offline
Cage Hater
Beyond ANAL about his oil pressure. I'm shocked that he didn't squirt oil down the spark plug holes to lube the rings during the crank time required to bet oil pressure!
Jon
04 Accord Coupe EX I4 5AT Cloth
03 Yamaha FZ1 (Street bike) +27K miles
02 Suzuki DRZ400 (Enduro)
00 Honda TRX400EX (Quad)
99 Kawasaki Ultra 150 (Jetski)
