Drive Accord Honda Forums
Google
Thread Tools Rate Thread Display Modes
Old 05-30-2009, 09:24 PM
str86tt str86tt is offline
Send a message via AIM to str86tt
Hitch and Bike Rack
I bought a hitch and bike rack for my Accord a couple months ago. I know there's that other thread in the 7th gen forum but it didn't quite have everything I was hoping to find while I was researching.
I ended up with this combo:
Hidden Hitch #60236
Thule Roadway #914
There were two hitch part numbers that I found for our cars. It looks like one was an older design. The one I purchased has the angled tubes going to the reciever which I thought might be better hidden under the car.
I ended up repainting parts of the hitch where the paint had been chipped off during shipping.
The install was fairly straight forward although it took us quite a while to get the exhaust unhooked from the rubber hangers. We did find that the backing plates that are supposed to be inserted into the hole in the frame was too wide to fit. The instructions provided say to file the hole bigger but I did not want to remove the e-coat and expose steel. We ended up grinding the plates a little bit narrower and painting the plates with Rustoleum.
Trimming the heat shields was just trial and error to get enough material removed from the corner that the hitch now occupied. There's already a dimple in each heat shield that marks the spot where the bolt & nut from the hitch are located. We used a 1" christmas tree (stepped) drill bit to drill a hole but it wasn't quite big enough. The heat shield just got bent a little bit when it was bolted back up.
Drive Accord
Old 05-30-2009, 09:31 PM
For the rack, I believe Thule's website recommends the #912 which is the two bike version of the rack I ended buying. However, Thule does say that when using the 914 with a class I hitch it can only carry two bikes. It took a little back and forth with tech support to confirm that the hitch would go into a class I.
I tried looking at Yakima racks as well but it looks like you need at least a class II hitch to use their racks.
Old 05-30-2009, 09:34 PM
some more pics...
Old 05-30-2009, 09:53 PM
twcoupe twcoupe is offline
looks like a good setup, will check this out. Thanks.
Old 05-30-2009, 10:44 PM
PKT PKT is offline
4th Gear
Very cool! You know, I am about to install that exact same hitch tomorrow afternoon, for a kayak trailer; I will get me a bike rack like that as well. I take it since this is not for a trailer you didnt install the wiring harness, Im wondering how thats going to go. I will try to get pics if I get it done tomorrow... I like how the hitch bolts to the tow hook and basically just transfers the weight to the hook.
I decided I dont want to put my kayak on top of my coupe, so this is the trailer Im getting, found a deal on a used one nearby http://www.sportsrig.com/ these are pretty slick, extends the hauling capacity of the car and then folds up into the garage...
Thanks for the tip, I think Ill grind down the plates as well. The part about 'enlarging the hole' bugs the hell out of me.
2008 EX-L V6 Coupe NBP
Old 05-31-2009, 09:32 AM
Yeah, I didn't do the wiring since I didn't intend on using a trailer but the pictures I saw of the harness don't look like it would be difficult.
I liked the fact that there was no drilling needed to install the hitch although I was bummed to lose the tow hook as a jack point. Now I have to work on the rear one side at a time.
That's a pretty cool looking trailer.
Don't forget those plates have a coating on them too. That's why I repainted them after grinding. I just hope using the heat gun to quick dry the paint doesn't keep it from sticking. :-)
Old 11-05-2009, 02:13 PM
bigme bigme is offline
noob
thanks for the pictures, have you ever put four bikes on that rack? I have a 05 Accord sedan and am looking for a way to transport 4 bikes, mine my wifes and two kid sized bikes.
2005 Accord LX 5MT 2.4l VTEC
Old 11-05-2009, 07:40 PM
el Vato's Avatar
el Vato el Vato is offline
3rd Gear
Send a message via Yahoo to el Vato
Your my hero!
I was contemplating this setup as well. Now with your pics I get a clear view of what it'll look like.
Looks Great!
08' Accord Sedan EX V6 Silver/Black Leather
  • V1 Hardwired
  • 10" Infiniti Sub w/Phoenix Gold Amp
  • 19x8.5 et35 Rays Engineering A34
  • Ground Control Coilovers
Old 11-05-2009, 09:29 PM
morcheez's Avatar
morcheez morcheez is offline
6th Gear
Send a message via AIM to morcheez
thanks for all the info ...just curious how much did everything cost
08 ASM Coupe i4/ tint / lip spoiler / 6k hids / 20" verde chaos 45mm offset 255/35 nitto nt555 / eibach pro kit / autozone grille mod / weathertech floor liners / clarion touchscreen / tsx key / trunk liner/ dual exhaust, v-leds white&amber turn bulbs/ fog lights w nokya 2500 bulbs/ odyssey lower grill/ custom wall in trunk/ 35&20 tint/black roof/ color matched grill and rear "H"
Old 11-06-2009, 01:49 AM
zZz LoNeLy zZz's Avatar
zZz LoNeLy zZz zZz LoNeLy zZz is offline
4th Gear
Send a message via AIM to zZz LoNeLy zZz
trying to find snowboarding racks but the cheapest i found was like $500 and thats just for the rack first. any of yah have a snowboard/ski rack on your coupe, can you post a picture. thanks.
XBL: zZz LoNeLy zZz
PSN: zZzLoNeLyzZz
Old 11-06-2009, 03:36 PM
Sorry, most of the time I only have one bike on there. It actually does say somewhere on the Thule website that the rack is only supposed to carry 2 bikes with a class I hitch. So, going more would be a do it at your own risk kinda thing. I bought the 4 bike rack because it wasn't much more and it gives me more flexibility.
Old 11-06-2009, 03:39 PM
I think everything ended up around the mid 300 range for the rack and hitch. The hitch came from etrailer and the rack from REI (had a 15-20% off coupon). I don't remember what I paid for the antisway cages for the rack.
Old 11-06-2009, 09:24 PM
el Vato's Avatar
3rd Gear
str86tt,
Does that rack have the option of locking the bikes?
  • V1 Hardwired
Old 11-07-2009, 06:12 AM
Originally Posted by el Vato View Post
str86tt,
It's got a spot at the base to loop a locking cable through (I haven't been using anything to lock up my bike).
The do have a model, the Ridgeline that has a built in locking cable along with a few other extras.
Old 11-07-2009, 06:54 AM
searich07's Avatar
searich07 searich07 is offline
5th Gear
Recreational Carrying racks
sr86tt, I admire you for attempting to use bikes for exercise. I have used bike racks on my Accords since 1992. But only use ones with rails above roof. One issue with a rack on rear end, is extension of car in terms of feet, which makes it very difficult to park properly without encroaching on an adjacent space or access lane.
Carrying two bikes on rear extension rack will add 3 or 4 feet to your car. No matter how one decides to rack their car for bikes, kayak, snowboards, or skis. I have found above roof configurations work best for me. Having a Coupe limits which above roof solutions you can adapt for carrying recreational gear. Regards
Richard
'09 Accord Coupe Ex L-Nav (190hp) I4
- Alabaster Silver Metallic/ Zaino finish / Black Leather Interior
-Weathertech trunk, front
-3M clear bra, pillars, roof, rear deck
OEM:
- side moulding
- fog lamps
- Auto dim mirror
HONDA Accords:
'99 Sedan EXL V6
76 K miles - 6th Gen (97-02) 3.0L V6 SOHC VTEC (200 hp)
'92 Coupe I4
127 K miles – 4th Gen (90-93) 1992 facelift I4 2.2L (125 hp)
'85 Sedan LX 4dr I4
98 K miles – 2nd Gen (82-85) 1985 refresh i4 1.8L (86 hp)
Thread Tools
  Friends of Drive Accord
Throwdown Performance
Retro-Solutions
TV and NAV 2 Go
Diode Dynamics
Accord Mania
XenonDepot Lunarpages.com Web Hosting
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© Copyright 2002-2009 Wardsweb, LLC. All Rights Reserved.
