Basic Oil Check Question (Gen7) - Page 2 - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Fluid Dynamics
  #16
Old 06-04-2009, 04:29 PM
YRMed YRMed is offline
Leased a VW_My life ****s
Originally Posted by hillstones View Post
He never said he checked his oil with the engine running. I agree, it is not overfilled.
Well now, lets pick a fight, why dont we. I said "has been running" not " is running". Has been running implies was turned on and then turned off. Otherwise it would be a running engine.
But thank you, your input was invaluable. Your contribution to humanity is priceless.
'12 VW Jetta 2.5/5spd lease - WORST decision ever
'11 Infiniti G37x - Sold
'09 TW 6-6 - Sold 1/1/2011
  #17
Old 06-04-2009, 04:38 PM
BLCKFLSH's Avatar
BLCKFLSH BLCKFLSH is offline
Make that BluFlsh
Regardless if the engine has been off for 10 minutes, or 10 hours, I pretty much get the same reading on the dipstick. I put in 4.5 quarts with the oil and filter change (03 V6). I do not overfill. My engine does not burn/consume oil like some do.
  #18
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
Originally Posted by The Critic View Post
I would never exceed the max mark on the dipstick. It can cause damage to the emission control system.
On the Prius forum, people who overfill the engine oil have discovered that it negatively impacts fuel economy.
That strictly depends on how over full the oil is. A quart? WAY too full. 1/8 or 1/4" over full on the stick comes under BFD.
  #19
Old 06-06-2009, 09:59 PM
Accordriver's Avatar
Accordriver Accordriver is offline
6th Gear
How so?
-03 Honda Accord EX V6
-Debadged-17mm sway bar-UR crank pulley-AEM CAI
  #20
Old 06-07-2009, 04:14 AM
The Pope's Avatar
The Pope The Pope is offline
Just another old guy ....
Originally Posted by Accordriver View Post
How so?
Referance RtexasF answer. If you have too much oil, the crankshaft will be hitting it as it spins. This will cause the oil to foam. When oil foams, it starts to lose it's lubercation ability and will be allowed to pass by the piston rings easier along with it being able to be ****ed into the intake side of the engine thru the PCV (Positive Crankcase Valve) and then burned. This is not a good thing for a lot of the different sensors and systems that the car has. That's where it can start to cause problems with the Emissions Control System (among other issues).
So IMHO it's better to run your oil level a tad (1/2 qt at most) low that too high.
The Pope
Things that we go thru that don't kill us, makes us stronger. What we learned from these events are now tools in which we can use to help others.
My youngest son, RIP 10/3/2004 (He was 19 at the time)
My mom, RIP 4/6/2011
Forum Rules: http://www.driveaccord.net/forums/sh...ad.php?t=19181
  #21
Old 06-07-2009, 04:25 AM
07graphiteV6cpe's Avatar
07graphiteV6cpe 07graphiteV6cpe is offline
4th Gear
If the oil is below the minimum level will that hurt the engine.
2007 Accord V6 Coupe A/T with Honda chrome HFP 18" wheels and low profile Yokahama tires, drop in K&N filter, Mobil 1, K&N oil filter and 30% tint.
2006 Honda EX-P 4WD A/T Element Tangerine Metallic with black interior 44,000 miles Honda certified one owner vehicle
  #22
Old 06-07-2009, 03:32 PM
The Pope's Avatar
It depends on how much below it is, but in general, yes, it will hurt the engine, but it's (IMHO) not as bad as running an engine with too much.
IMHO a half quart low isn't as bad as having a half quart too much.
But you need to strive to have it in as close to the correct level as much as possible.
The Pope
  #23
Old 06-07-2009, 06:37 PM
6th Gear
While I agree that too much oil can cause lack of lubrication, even damaged internals in extreme cases, and allow oil to travel through the PCV system as it's the quickest way out, I don't see how *foaming* can cause oil the the PCV system nor how the oil will physically damage sensors..
  #24
Old 06-07-2009, 06:42 PM
littlewing1208's Avatar
littlewing1208 littlewing1208 is offline
3rd Gear
IACVs are very finicky to oil residue in them and MAPs are also not as accurate with a film of nastiness on the input side.
09 Accord LX-P Sedan
04 BMW 330i ZHP
  #25
Old 06-08-2009, 06:56 PM
psyshack's Avatar
psyshack psyshack is offline
Out of Control
Originally Posted by rsh37930 View Post
Correct. Thanks. I waited an hour, then waited overnight -- both readings are the same - oil up to the "A" in the "RCA" on the stick. I presume that is in range.
No it's over filled a tad. |xxxxxxx| That is your min and max.
09 HCHII,w/Navi,I4,CVT Crap,Atomic Blue/Beige,70k Miles (Dull/MPG/Quite Civic)
07 Mazda3 S Touring,I4,5MT,Purple/Charcoal,80k Miles (Civic What?)
00 Ranger Ext,XLT,I4,5MT,White/Gray,200k Miles (Thinks it's a F-150)
X, 05 Accord EX Sedan,I4,5AT,Red/Gray,89k Miles (My Fav. Accord Gen)
X, 06 Civic EX Sedan,w/Navi,I4,5MT,Silver/Gray,44k Miles (No Better Than GM Junk)
Can you save a gal. here and there then blow a half gallon playing with the tach? It can be done!
  #26
Old 06-08-2009, 07:25 PM
rsh37930 rsh37930 is offline
4th Gear
I am thinking it's probably .5 qt over.
  #27
Old 06-08-2009, 07:34 PM
Cleankill's Avatar
Cleankill Cleankill is offline
4th Gear
I assume your the dip-stick reading as just as accurate/errorous, then it would be 4.4L (mine is just above the "A")
07' J30A5 Auto 4Dr, 20mm TL-S rear sway bar, Neuspeed front tower bar, Debadged "SE"
  #28
Old 06-09-2009, 09:29 AM
4th Gear
ok ... you're the second person to say this, so it looks like I need to call Honda, to get an explanation ... I need to know the measurement is correct, before I know if there is an overfill
  #29
Old 06-09-2009, 03:33 PM
Cleankill's Avatar
4th Gear
i consider the V6 dipstick to be rather accurate (at least on mine). I drained it down to virtually no oil left, i even took a dryer to blast some air into the engine. Personally, I would not be concern with any slightly overfill; 1/4 of a quart is nothing! As long as you can see the oil at least min or not way overfilled, you are fine. Interestingly, I have actually seen some bottle has marginally more oil than other even they are the same brand and oil weight...
I have another vehicle call for 4L and i poured a 4L in. The dip stick is at "Min" mark...
