Display fine-no sound from radio - Drive Accord Honda Forums
Old 06-12-2009, 06:44 AM
328skidpad 328skidpad is offline
I have searched but not found any solutions.
When I turn on the stereo, the display turns on and then after 10 seconds the volume bars light up.
But there is no sound coming from the speakers. I extensively searched the net and someone mentioned that it has to do with "connection"
Any ideas, this is a 03 accord lx stock everything.
thanks
Old 06-12-2009, 07:25 AM
sodaks2k sodaks2k is offline
Moderator
http://www.driveaccord.net/forums/sh...ighlight=radio
Old 06-18-2009, 09:24 PM
americanhero's Avatar
americanhero americanhero is offline
2nd Gear
thanks
Had the same problem. Could be couple of things. Your radio could have gone bad. I would take it to a local stereo shop and have it tested out. Why you ask? You won't have to go through the steps below to determine if it's the radio unit that has gone bad. If the radio unit has gone bad, a new radio unit it is!
One of your speakers could be grounding out. Your car contains what is called smart amp. If one of the speaker is grounding out, it turns off all speakers.
First I would disconnect the two back speakers and see if the audio comes back. Take out each speaker and see if audio comes back.
From what I've read, disconnecting--reconnecting battery works for some people.
Tell me, is the "volume control coming on after 10 seconds" normal or has it been a recent phenomena?
Try taking it to the dealer for diagnosis if you don't know how to test the speaker wires.
Taking out the headunit is PITA.
Old 06-23-2009, 08:50 AM
_karu_'s Avatar
_karu_ _karu_ is offline
Go Bills!
unbelievable. same issue for me. same car, same model.
"A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain."
Current Ride:
2003 Accord LX Sedan
Previous Rides:
2003 Civic EX Sedan
2002 Civic EX Coupe
Old 12-19-2013, 05:09 PM
bhills_8398 bhills_8398 is offline
My First Post
Useless reply . It would have been nice if you replied an update of how you solved this problem. So all the rest of us with same problem could learn from it!
Old 09-02-2014, 08:52 PM
bighec5460 bighec5460 is offline
My First Post
2008 honda acc. display fine no sound on stereo system
Ok, i have the solution to one of the problems that it could be, at least it was for me anyways. If you have a bluetooth on your vehicle, sometimes this switch can get stuck when switching over from radio to bluetooth. When it gets stuck it does not send out any sound from your radio, because your blutooth is still engaged looking for a blue tooth connection. I had to unscrew the blu tooth button alittle bit right there on your console and stuck a safety clip under the switch it and lifted the button. And yes low and behold the sound came back on, now i don't have to listen to that dam beeping noise every 5 dam minutes while driving, beep, beep beep, beep beep beep beep LOL! this would probably be a good time to replace the switch or you can try and clean it if you are able to? I rather replace it myself. I hope this was some help to anyone out there. Good luck!
P.S do check your fuses because your radio runs off of more than 1 fuse, and also, it could be a bad amp in your radio or you might have an amp seperate from your radio that is bad, or could be a short, i guess you didn't want to hear that part lol! well good luck anyway!
Title goes here
close
video goes here
