DIY: center console removal/shift boot removal. - Drive Accord Honda Forums
Old 06-23-2009, 07:38 AM
AznX TL's Avatar
AznX TL AznX TL is offline
need 6 speed!
Send a message via AIM to AznX TL
first remove the shift knob, the stock knob has tabs facing north and south, or 3rd and 4th gear that needs to be pinched to take it off the boot before turning the knob off.
after that, open the ashtray and power outlet (make sure you take out all of your change first) and pull up, just pull it enough so the clips pop out.
now just run your fingers on the side and pop the side clips off
do the same for the other side.
now move your way upto the arm rest where you'll see the center console ends. you have to pop this one out to finish off the clips holding the console in.
lift up the console, but not too fast. make sure you unplug the 12v outlet first by pushing in the center button like so and pulling the plug.
now you can take the whole console out, and when you flip it upside down you will see this. 4 screws holding in the shift boot.
when you take out the 4 screws you will notice there is a ring ontop of the boot (take the ring off), and the stock boot is stapled to the white part ring.
after you remove the staples. you will have just the white ring. put the new boot over it, don't worry about re-stapling it. just stick the top ring over the boot/white ring and it will hold it securely in place.
now to reinstall the boot, you will need to screw it back onto the console, but the boot is blocking the holes, you need to poke big enough holes to have the screws be able to go through. i simply used a screw driver to poke through mine.
and just screw it back onto the console and make sure the big side of the ring is facing the radio and the thinner side is facing you. and put the console back in opposite order of which you took it out, and don't forget to replug the 12v outlet before doing so.
you're done now with the boot installation, my boot has a metal ring on top which made a clinking noise every time i shifted. so an easy fix is to use electrical tape (because black tape is hard to notice) and wrap it around the shifter where the metal ring was clinking.
and problem solved, enjoy your new boot/shift knob.
-08 Accord lx-s 5speed manual/ tafetta white
mods
|DDM tuning 6k hids|12" Alpine Type-R|TSX switchblade|Lip spoiler|Type-R Suede red stitch boot|Gunmetal Type-R knob|
|Intake Resonator Delete|Hyper White led license plate led|led interior bulbs|Smoked Reverse lights|
Previous owned
-97 Acura 2.2CL auto/Flamenco Black
Old 06-23-2009, 11:44 AM
coupe_nasty's Avatar
coupe_nasty coupe_nasty is offline
Slammed and Simple
great writeup! im gonna do this. Im tired of looking at my aftermarket knob that has a round base up against the oem square base of our boots.
2009 Taffeta White Coupe V6 6MT EX-L
MODS
Tein Super Street Coilovers
19x8.5 5-Zigen Gravis I's (Chrome)
Full HFP Lip Kit
HKS Dual Hi-Power Catback Exhaust
RV6 V3 J-Pipe
P2R Ported Intake Runners
Rotora Cross Drilled/ Slotted Rotors
EBC Red Stuff Brake Pads
Ichiba Wheel Spacers
SPC 3-Arm Rear Camber
Ingalls Front Camber
Retro Solutions HID'S- (8000k Low's/3000k Fog's)
35% Tint
7th Gen Head Rests
Purple Fade Titanium pedals/Shift Knob
Seperate Fog Switch
Debadged
Old 06-23-2009, 08:08 PM
Indubitably's Avatar
Indubitably Indubitably is offline
6-6
Thanks for this and great write-up
Old 06-24-2009, 05:08 AM
08coupex's Avatar
08coupex 08coupex is offline
6th Gear
Nice job
2008 Accord Coupe EX Silver
20% tint
Viper 5701 2-way Responder LE w/ remote start
Weathertech floor liners front & Back
OEM deck lid spoiler
Factory fogs added
Xenon depot 5k HIDs
RETURNED LEASE...Weathertech for sale.
New ride 2011 F-150 FX4 Ecoboost super crew
Old 06-24-2009, 11:00 AM
peazs's Avatar
peazs peazs is offline
dub.dub
Send a message via MSN to peazs
subscribed for future use maybe :p
my love shack! ;)
Old 07-09-2009, 10:20 PM
jLim's Avatar
jLim jLim is offline
5th Gear
Thanks for the writeup. Two questions, how does the top ring on the boot stay up and can you estimate how much shorter your new knob is compared to stock.
2008 Honda Accord Coupe LX-S Manual
Alabaster Silver Metallic
[SIZE="1"]Now:
-OEM: Splash Guards, Wheel Locks, Trunk Tray, Rubber Mats, Front Bra
-V-LED Plate Light
-DDM Tuning 35W Slim Ballast HID Kit 6000K Lows
-Nokya Hyper Yellow 2500K Fogs
-Perforated Leather Shift Boot and Handbrake Boot (Redlinegoods)
Old 07-10-2009, 12:11 AM
6-6
i believe it is just held up on its own.. it isnt like the stock shifters where its attached.. I know he put the tape to prevent the clattering noise of metal
Old 07-10-2009, 05:00 AM
tuo.p.li's Avatar
tuo.p.li tuo.p.li is offline
2nd Gear
HOT:notwor thy:thumbs up::nu ts:
'09 Accord LX-P 5MT (Ruth)
Crystal Black Pearl
BROADWAY Convex Rear View Mirror 270mm
PUTCO LED Dome lights
Old 07-10-2009, 06:08 AM
DallasAccord's Avatar
DallasAccord DallasAccord is offline
Terminator
Is there anything extra to do in the DIY for the automatic trasmission in the sedan's center console removal?
Old 07-10-2009, 02:39 PM
AznX TL's Avatar
need 6 speed!
ring stays up by itself. but if you wanted to you could also use tape to make the shifter thick under the ring to hold it up or something close to that.
mods
Previous owned
Old 07-10-2009, 02:50 PM
staro0989's Avatar
staro0989 staro0989 is online now
5th Gear
Nope, same exact process actually.
2009 Honda Accord EX Sedan-TSX rsb, TSX AT Shift Knob, Leather Wrapped Steering Wheel-My car
2006 Honda Accord SE Sedan-Sisters
2004 Nissan Frontier XE-Fathers
2004 Toyota Highlander V6-Mothers
2009 Honda Accord EX-L Sedan-Grandfathers
