Parts from EX-L V6 on LX-P? - Drive Accord Honda Forums
Old 06-23-2009, 03:46 PM
mur130 mur130 is offline
Is it true LX-P sedan can not install bumper and fog light from EX-L V6 sedan?
As well as 18" wheels?
Old 06-23-2009, 03:50 PM
noname noname is offline
2nd Gear
not true. you can install both of those on the LX-P
Old 06-23-2009, 04:11 PM
dexterdog's Avatar
dexterdog dexterdog is offline
New moddin' canvas
Not true but not entirely correct. The OEM wiring will not be there for the foglights so it won't be a direct plug and play.
Old 06-23-2009, 04:39 PM
So 18" factory wheels no offset issue and bumper should be perfect matched.
But for fog light, even if install the switch(08V38-TA0-100) won't help at all since it required rewiring?
Old 06-23-2009, 05:39 PM
Edaccord08 Edaccord08 is offline
Out of Control
Lower trim is missing part of wire harness.
On upper trim there's wire by each wheel well to plug fogs in after you buy kit, thats not there .
I think a few have hand wired it, mybe check other post of fogs on LX models.
Ed
2008 Accord LX, Alabaster Silver Metallic
gone 1985 XR4Ti
gone 1974 Opel Manta rally
Old 06-24-2009, 04:26 PM
Found many write ups but none with factory foglights with switch I mentioned above installed on LX sedan models. I got a friend works at body shop might able to find bumper with factory foglights for me. I just need to find a "clean" way to install it.
