Question on AT flush - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Fluid Dynamics
Old 06-24-2009, 04:30 AM
weatherwatcher weatherwatcher is offline
I have an 06 Honda Accord EX V-6 with 59,000 miles. I am getting ready to do a drain and fill on the automatic transmission. My question is, when I do the drain and fill, should I just do the procedure once or should I do it three times to try and remove as much of the old fluid as possible. I saw the DIY thread on this, and it appears it was only done once, but I believe that his car had less miles than mine.
Great website, I just found it and I have found loads of useful information.
Old 06-24-2009, 05:37 AM
bukxanger's Avatar
bukxanger bukxanger is offline
4th Gear
do it once then drive about 10 or 15 miles. then repeat two more times... which equals 3 total
08' Accord EX-L V6 Coupe Polished Metal Metallic
03' Accord EX I4 Alpine White
Old 06-25-2009, 07:34 AM
05lx's Avatar
05lx 05lx is offline
2nd Gear
it's a waste of time. Too many people are paranoid about things like this. I even read about people changing the at fluid every 10k. That would be equivalent to showering 4 times a day. The service manual says to do it once. If you take it to a Honda Dealer they will do it once and that's because that's what they feel is best. Anything more than that is a waste of time and money. Your transmission will not suffer by only doing it once compared to 3 times. What does play a big factor is how you drive your car change it once and be good to your tranny and you will be a happy camper.
Old 06-25-2009, 07:44 AM
SatinSilver's Avatar
Moderator
I think it depends more on if the miles are mostly highway, city or 50/50. If the 59k are mostly city miles and the color of the atf is brown/black then you may need to do 3 drain/fills.
If the miles are mostly hwy and your fluid is still red/dark red you may only need one or two d/f's.
05 Toyota Matrix XR: Silver, 55k
99 Accord Coupe: 2.3, 166k, original owner.(sold)
94 Civic Coupe: manual (sold with 45k)
83 Cutlass Supreme Coupe: Traded in with 67k.
Old 06-25-2009, 02:32 PM
superballz00 superballz00 is offline
5th Gear
I remember my 97 and 01 manual saying to change it 3 times. Good luck with changing it once every 60k.
97 Accord LX Coupe A/T 28mpg
09 Accord LX-P A/T 31mpg
Pagani Zonda - When I win the lottery and move to Europe.
Old 06-26-2009, 07:03 AM
I remember calling Honda to verify what the recommended. If I recall correctly they said 60k, then every 30k after that. I checked the fluid and it did not appear to be too dirty on the tranny dipstick. Nevertheless, I think I am going to flush it 3 times to try and get as much fresh fluid as I can into the transmission.
My question now would be, at 90K, should I do a full flush 2 -3 times again, or would I just be better off to do it once, based on the color of the fluid?
Thank you again for all of the advice, keep it coming.
Old 06-26-2009, 11:07 AM
CRZ1 CRZ1 is offline
You can do simple maths to find out. For example, method 1, drain and fill ATF 3 times at 60K miles, method 2, drain and fill ATF one time at 20K, 40K and 60K miles.
It is easy to find out the most amount of dirt in transmission during the 60K miles. Method 1 will has the higher value. For the same cost, method 2 will provide better environment for tranny.
Old 06-26-2009, 12:03 PM
5th Gear
Don't flush. Just drain and refill. If the fluid is still red then one drain and refill is fine.
Old 06-26-2009, 12:39 PM
cajun's Avatar
cajun cajun is offline
Where Y'at?
If there was an award for the most incorrect info per lines in a post you would get my vote. Please go read your manual. It doesn't say do it once and it doesn't say to base your trans fluid maintenance interval on your shower rate.
2010 PMM Accord LX-P, TSX rear sway, Honda weather mats, GG lower grille, 35% tint
2006 Toyo Sienna LE
2002 Accord SE, sold 6/10, 83K, TL rear sway and upper strut bars, original owner, great car
Old 06-27-2009, 01:33 PM
12153 12153 is offline
banned
Cajun and All:
AMEN to your pointing out such brutal IGNORANCE some have about fluids!
Fluid is the "life blood" of most ANY hydraulic device/system. Bad fluid = bad results. And changing ATF is a Helluva lot easier and cheaper than changing a transmission.
