Loss of power...help - Drive Accord Honda Forums
Old 06-26-2009, 08:20 PM
accordEX03's Avatar
accordEX03 accordEX03 is offline
Send a message via AIM to accordEX03
I have an 03 4 banger. It has 154K miles on it and this is the first problem I have come across... When I take off with the a/c on mostly, the car is very hesitant to move, while driving, I have to punch it to make it move. When I get on it, it hesitates at first but at the top of every gear, it opens up and goes like it normally does but as soon as I get to the next gear...no power until the top of that gear... I don't know everything about cars, but I do know a thing or two but this has stumped me... It does it with the a/c off too just not near as bad or as often. Any help would be great. I appreciate it.
Old 06-26-2009, 08:37 PM
Joe818 Joe818 is offline
4th Gear
wait let me try to help you out ... so you go through first gear normally ... then second gear you punch it but like it goes to around 4000 rpm and it like lags/goes down around 400 rpm for a second and it goes up again?
2004 White Coupe I4 6Mt
84,xxx Miles
Aem CAI
Tints
Tein Lowering Springs
18" White Axis Halo
-Blue Muteki Lug
-Blue Enkei Valves
Oem Front Lip
Depo Blackhousing Headlights
-6000k HID LB
6Mt Swap
-Act Stage 2 Clutch
-Act Racing Flywheel
Not Installed:
Depo Blackhousing Fogs
-3000k HID Fogs
-Lamin-x Yellow Film
Future Mods:
DC Header 4-2-1
Custom HKS Hi-P Exhaust
Eclipse Navi
Neuspeed Short Shifter
Old 06-26-2009, 08:41 PM
A&Fbro28's Avatar
A&Fbro28 A&Fbro28 is offline
Out of Control
Send a message via AIM to A&Fbro28 Send a message via Yahoo to A&Fbro28
I wonder if its the tranny "stalling" of sorts and not a motor issue. Whens the last time you had a tune-up?
Desmond,
08 Acura TL w/Technology Pkg
08 Taffeta White Honda Accord EX-L w/Navi Coupe (traded-in)
http://www.cardomain.com/ride/3093726
Old 06-26-2009, 09:04 PM
hillstones hillstones is offline
Sold the Accord & Civic
Do you have an auto or a manual? If it is an auto, and the transmission feels like it is slipping, it may be going out on you. Transmission failures are a known issue for the 2003's.
Old 06-26-2009, 10:56 PM
Boba Fett's Avatar
Boba Fett Boba Fett is offline
4th Gear
Have you had anyone look at it?
Maybe a Honda service shop or good repair shop? Maybe even a place that will give you a free estimate (I know, they can be hard to find)?
7.5 Gen 2006 Accord Coupe EX 4cyl Manual
17mm rear sway bar
EBC Green Stuff Brakes
Centric Premium Rotors
Yokohama AVID TRZ
Mobil 1 Synthetic and Filter
Infinity Reference
Old 06-27-2009, 02:47 AM
4th Gear
if its what i explained to you if your cars automatic tranny is failing ... if its stick your clutch is gone
84,xxx Miles
Aem CAI
Tints
18" White Axis Halo
-Blue Muteki Lug
-Blue Enkei Valves
Oem Front Lip
-6000k HID LB
6Mt Swap
-Act Stage 2 Clutch
Not Installed:
-3000k HID Fogs
Future Mods:
DC Header 4-2-1
Eclipse Navi
Old 06-27-2009, 05:47 AM
accordEX03's Avatar
it's an automagic tranny. Its usually really quick and responsive. Doesn't take much for it to reach 5000rpms but while getting to 3500 rpm it lags untill I get to say 4 then it has the open up effect of VTEC. Its a noticeable amount of power that kicks in. I've noticed that the cars GradeLogic transmission will down shift its self when it never has before but its harder to get it to downshift. Something that shouldn't happen with a 5 spd auto... It downshift while downhill and its noticable when it wasn't before. I personally think its electronic because the tranny doesn't feel like its slipping any and once it gets past that ''lag'' stage, it hooks it up...
Old 06-27-2009, 06:00 AM
accordEX03's Avatar
I really appreciate your guys help. Nobody has looked at it and it hasn't been tuned up. It hasn't had timing issues or ever even been changed/inspected. I know with that its bad to have the ''dont fix it unless it breaks'' attitude. but it has always been an economical, responsive powerful 4 cyl so I didn't bother with it. I bought it with 91k on it 2 1/2 years ago. an older couple owned or just someone who listened to oldies and gospel (according to the radio presets) so I knew it had been in good hands. My sisters 05 Altima S loaded has 170k miles and runs like a hoopty junker. I trusted it to Oklahoma City for the IKE evacuation and would do it anytime in the future. 85 mph and got 36-38 consecutive mpg. I did change the tension pulley and drive belt. and ran some Lucas brand fuel system cleaner like my room mate in his 07 Si Sedan-si died in Galveston to a drunk driver and he left us for a Mazda speed3.
Old 06-27-2009, 07:14 AM
cobra94563 cobra94563 is offline
3rd Gear
fuel injection? any check engine light error?
'05 v6 coupe 6MT
Old 06-27-2009, 08:31 AM
SatinSilver's Avatar
Moderator
Don't have to worry about the timing belt since you don't have one. In 03 Honda dropped the belt in favor of a chain. It should last awhile.
I'd do some simple preventative maintenance like some atf drain and fills with Honda Z-1. What color is the atf currently? You may need to do 1-3 drain and fills to get the color back to light pink. Do this instead of a transmission flush that could stir up contaminants and block a passage. This is what Honda Corp. recommends. Put some new plugs in OEM NGK plugs..about $10 each from Advance Auto.
Down the road or now replace the pcv valve with an oem one. www.collegehillshonda.com has a decent price. That way your car won't turn into an oil burner. Replace air and cabin filters.
Have dealer or diy the coolant for some extra long life Honda coolant type 2.5.
Old 06-27-2009, 09:17 AM
97obw 97obw is offline
03's dont have a different transmission than the 04'-07's though do they?
Old 06-27-2009, 09:37 AM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
If it bogs through low revs, then wakes up at high revs, it's time to check the timing chain. Especially if this happened suddenly.
Pull the valve cover, look down at the crank pulley, ONLY turn the crankshaft clockwise line up the white mark on the crank pulley to the pointer on the cover. The two arrows on the cam gears should be relatively up, and the two hash marks on the sprockets must be together. If they aren't it's jumped time. A couple of teeth, it'll run, not well. More than that, and it can bend the valves. Bad deal.
It sounds like the engine rotated backwards, by design, when it does, the chain tensioner backs off. If there's excessive wear in the chain and guides, it can come off the crank gear. When you restart it, it jumps a couple of teeth until all the slack is taken back up again.. Normally, when they have no wear, this loss of tension isn't a big deal.
Old 06-27-2009, 03:00 PM
accordEX03's Avatar
I'm not exactly sure but I don't think they are different. everything else is the same...
Old 06-28-2009, 06:28 PM
Frenchy's Avatar
Frenchy Frenchy is offline
04 Accord 4dr 2.4std ex-l
Buddy i think your a/c compressor might be your problem.
Take your a/c belt off & check if your power come back.
If so,that means your compressor bearing are seizing up,a know problem on all
Honda.The compressor is taking all your power to make him rotate.
I'm pretty sure on that one.
2004 Accord Ex-l
Eibach pro kit springs
Tl-S front&rear sway bar
OEM front lip
OEM rear spoiler
OEM brush aluminum interior trim
Momo phantom carbon fiber shifter
Momo black leather shifter boot
Neuspeed short throw shifter
OEM painted mud guard
Focal m5 silver rims 17-7.5+45 offset
Maxis tire 225-45-17
Black hosing headlight diy
Tint 20% all around
6000k hid
AEM cold air intake
Old 06-28-2009, 06:29 PM
Fredsvt's Avatar
Moderator
You can't remove the a/c belt. The water pump will stop turning and you'll have way more issues than just no power after that.
Tags
hesitates, lags, loss of power, power, slow
Title goes here
close
video goes here
