Poor Gas Mileage - Drive Accord Honda Forums
Old 07-14-2009, 11:41 AM
Toniok Toniok is offline
2nd Gear
Poor Gas Mileage
Lately it seems my mileage has gone way down. I generally average around 300 miles before the fuel light comes on. The last two fill up's have resulted in the low fuel light coming on at 270 miles. I generally drive until the low light comes on and fill up with the fuel averaging anywhere from 11 to 12+ gallons of fuel. Most of my driving consists of city stop and go driving. It also seems that the "oomph" has gone from the engine and it it lags when accelerating. I have been driving with the air on all the time now and drive on the fast side. I have been been filling up with 87 octane gas at Circle K, I just refiled the other day at Mobil to see if mileage improves. Tomorrow I'm going to have the alignment and tires balance checked as I was driving the other day and felt a slight shimmy at 55mph. Air filter was clean, dumped a fuel cleaner in the tank a few fill up's ago. I've been debating about changing the fuel filter.
Any advice on what to look at would be appreciated.
2005 Honda Accord LX
Old 07-14-2009, 11:49 AM
golftango's Avatar
golftango golftango is offline
FL350
Check your basic tune-up items:
Air filter - dirty? Replace it
MAF sensor - clean it with MAF sensor cleaner
Throttle body - dirty? Clean it with some tb cleaner
Tire air pressure?
Brakes - caliper sticking? Check the e-brake to see if in spec
Any CEL lights? If so, could be an o2 sensor.
Good luck.
GolfTango
My Flickr Page
'13 Suzuki Kizashi S 6MT
'12 Honda Pilot EX-L
Old 07-14-2009, 11:54 AM
2nd Gear
Tire air pressure?
Good luck.
Can the MAF be cleaned with any electronic cleaner? When I have the tires checked tomorrow, I'll ask them to check the calipers. My brakes have been squeaking though.
Old 07-14-2009, 12:00 PM
golftango's Avatar
FL350
No. Use use CRC MAF Cleaner which can be found at any auto part store. I have a write up with pics here:
http://www.driveaccord.net/forums/sh...ad.php?t=20631
GolfTango
My Flickr Page
Old 07-14-2009, 01:18 PM
Accordian169's Avatar
Accordian169 Accordian169 is offline
I <3 My 6 Speed
The fuel filter is just a metal screen in the tank, so you won't be changing that unless you really want to drop your tank. I don't know, it sounds like you answered you're own question when you said you've been running the AC all the time and you've been driving fast in the city. Those three factors would naturally mean lower mpgs. Generally mpgs go down due to the warmer weather in the summer time as well. Just some food for thought.
2003 Accord Coupe V6 6spd
AEM V2 CAI UR Underdrive Pulley J-SHIFT J-Pipe & Test-Pipe 2.50" Mid-Pipe / 2.25" Y-Pipe '03 Acura CL-S Mufflers
TB Coolant Bypass CompTech Short Shifter Corsport Aluminum Shift Bushings NRG Carbon Fiber Shift Knob
Ingalls Stiffy ETD Eibach Sportlines/HFP Struts 17mm TL Rear Sway 18x8 Konig Runaway 235/40/18 Nexen N5000
Centric Drilled Rotors DEPO Blackhouse Headlights Xentec 5000k HIDs Eagle Eyes LED Tail Lights LED LP Light
Old 07-14-2009, 01:40 PM
jgott jgott is offline
In my experience, mpg always goes up in the summer. A quick search online backs this up, with details as to why. On average, fuel economy is 10% lower in the winter -- this is combustion engines in general - not Accord specific.
Old 07-14-2009, 01:41 PM
2nd Gear
Thanks on the info on the fuel filter, I was under the impression that it was located by the back of the drivers side engine bay. I do understand that there should be a drop off in mileage with the ac but in the 4 yrs I've had the car, I don't ever recall a drop like this.
Old 07-14-2009, 02:14 PM
devi0us's Avatar
devi0us devi0us is offline
4th Gear
Fuel economy is better in the summer/warm weather despite the addition of AC because cold engines require a richer fuel mixture and winter gas contains additives that allow it to be used in cold conditions but lower fuel economy.
2003 Honda Accord EX-L I4 Auto 120,XXX Miles
Morimoto Mini H1 Retro 4300K | USA Spec PA15-HON2
Old 07-14-2009, 03:06 PM
joshsch's Avatar
joshsch joshsch is offline
YO
I've got an 2005 LX also and I've been only getting like 280 per tank. When I first bought the car a year ago, I was getting close to 350 per tank. New air filter, tires are properly inflated, so who knows... I'll have to check out the maf sensor and throttle body.
2005 LX 4 door- Black-
Limo tint all the way around.
17" Motegi SP-10's
Debadged except for rear "H" emblem.
Rear emblem painted to match car.
Grille painted to match car including emblem.
Stage 2 LED conversion from Diode Dynamics
17mm Acura TL rear sway bar
Tinted taillights
PS3 Gamer Tag: Joshsch99
Old 07-14-2009, 04:31 PM
2nd Gear
I live in Florida and only use the ac during the summer months.
Old 07-14-2009, 04:52 PM
I <3 My 6 Speed
I guess it depends on where you live. Here in Arizona it goes down in the summer when it's 115 out. Our winters are usually in the 60s-70s so we get better mileage in the winter. I guess a cold climate might be different.
Old 07-14-2009, 06:17 PM
Aceman196's Avatar
Aceman196 Aceman196 is offline
6th Gear
When I first got my car using the A/C killed my MPG after breaking it in I bearly notice. The A/C makes the car drive like @#$%. I seem like a NOOB when I try to move off with the A/C on.(Manual Trans)
07 Accord EX-L V6 6spd(TSB)
Night Hawk Black
25% Tint all round
2 Door
USA-SPEC PA15 HON2
Old 07-14-2009, 11:06 PM
wizputer's Avatar
wizputer wizputer is offline
4th Gear
Not to mention the quicker RPM drops when the compressor is running.... which I like, IF it happened the the compressor is off too
2006 Accord V6 6spd MT Carbon Bronze/Black
62k miles total - 25k in 1y1m (New transmission @ 50k courtesy of Honda)
25.4 avg mpg - best 31.9mpg
  • EBC 3GD Sport Rotors (Slotted/Dimpled)[Front]
  • Akebono Street Performance Pads[Front]
  • AEM V2
  • 55% Font/5% Rear Tint
  • Interior+License Plate White LEDs
  • DDM 5k HID Lows/HIR Highs
  • Hella Micro DE fogs(OEM garnish) w/ Raptor 3k HID
  • USA-Spec PA15-HON2 iPod/AUX Input
  • Scangauge II
  • TL Switchblade Key
To install: TL-S Sway Bars; Comp-tech SS
Old 07-15-2009, 12:26 AM
hillstones hillstones is offline
Sold the Accord
Summertime and the AC lower your fuel mileage.
Old 07-15-2009, 07:04 AM
2nd Gear
Had the balance, brakes and alignment checked this morning, all came up OK. I'm going to pick up some new spark plugs, MAF cleaner and a new cabin air filter. I'm thinking about taking the car and having a fuel system cleaning/treatment and hoping that this will restore some of the "oomph" to my acceleration.
