strange idle? - Drive Accord Honda Forums
Old 09-05-2005, 04:35 PM
magitekkn's Avatar
magitekkn magitekkn is offline
K20A3 > F22A1
strange idle?
Adding to the bad juju surrounding my accord, after driving, when I shift back into park, the revs climb from 1k to 1400, then drop, climb from 1k to 1400 then drop ad infinitum... any ideas? My thought is IAC or something of that ilk, but I have no idea how to diagnose.
As always, all help appreciated,
(PS the ride back from Penn. was 13 hours... luckily 8 hours of that was cloudy... the other 5 was sweaty... ugh..)
The Fleet:
07 Accord SE (Royal Blue Pearl) - 13 mi
04 RSX (Nighthawk Black Pearl) - 37,000 mi
Recent Departures:
93 Accord LX (Arcadia Green Pearl) - 224,000 mi
"Bye my little green car, I'll miss you!!!"
Old 09-05-2005, 06:58 PM
benjamming benjamming is offline
6th Gear
Question
Has the throttle body/IACV been cleaned recently?
2002 Accord EXVL Auto Sedan - Nighthawk Black Pearl / Quartz, fog lights, mud guards, wheel locks, trunk tray
1994 Pontiac Grand Am GT Auto Coupe
Old 09-06-2005, 06:15 AM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
PCV??? Although I haven't asked, that's the sort of thing they do when "bad".
I kicked cancer's butt! You might be next!!!! :) I survived a fatal heart attack, PRAYERS WORK!
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
Ours: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
little '98 Civic sedan, everything still works! Named Mater.
Old 09-06-2005, 10:32 AM
magitekkn's Avatar
K20A3 > F22A1
you don't say... guess what, my PCV valve has been dumping oil out the top of the valve cover... here's hoping that really is the problem... (now just to get that fan motor)...
The Fleet:
Recent Departures:
Old 09-06-2005, 10:36 AM
princess's Avatar
ready to go....
And maybe that will be the end of the repairs for a while!!
Old 09-06-2005, 06:27 PM
magitekkn's Avatar
K20A3 > F22A1
Well i don't think it (replacing the PCV Valve) solved it... but now that I have the new blower motor in (yay!) and the a/c back on as a result, I've noticed that it only happens when the A/C is off... which is to say that I normally have it on, so this could have been like this forever...
hmmm
The Fleet:
Recent Departures:
Old 09-06-2005, 06:42 PM
princess's Avatar
ready to go....
ummmm, that would be a vacuume leak....but no clue what it is caused by...
Sorry to say, we won't be around here for a couple of weeks to help you figure this one out..... in less than 12 hours now....we'll be on the plane to HI. In fact, since we have to get up at 3am, bedtime is comin' soon!
Hopefully someone else can help with it.
Old 09-06-2005, 11:45 PM
tafettawhite tafettawhite is offline
Lovin' every minute of it
Try pulling off the intake hose to the throttle body(with the car off). open the throttle plate and feel inside with your finger.. Do you feel a ridge of carbon? Shine a light and look. that can cause erratic idle. If you have the much carbon buildup near the throttle plate, I would 1st decarbonize the intake chamber w/ a BG Induction Service...
2nd, check the range of the IAC. I believe it should be on the throttlebody assy, or nearby. SHould have 5 volts to it. If it's not pulling 5volts, it may be a sensor or ecm problem. You'd have to troubleshoot it from there.
If the IAC is in range, you could have a vac leak somewhere also... Hope this helps...
2009 Accord LX Sedan Polished Metal
Old 09-12-2005, 07:59 AM
magitekkn's Avatar
K20A3 > F22A1
Talking Woot!
once again... problem solved!
Original problem:
surging in Park, between 1300 and 1800 rpm... occurs regardless of A/C on or off, blower fan etc...
Solution:
The top left Fast Idle Valve mounting bolt was loose by about 1/3rd inch. (Yes it was sticking out of the valve body...)
Tightened up the bolt, reset the idle using the idle speed screw...
a few check engine lights later (forgot to reconnect EACV/IAC)
voila! problem solved!
now to go get a lead pipe to beat my mechanic with...
The Fleet:
Recent Departures:
Title goes here
close
video goes here
