Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Wheels & Tires
Google
Thread Tools Rate Thread Display Modes
Old 09-07-2005, 03:27 PM
cordboy cordboy is offline
05 ex I4 graphite pearl
17" ASA AR1 wheels?
Does anybody here have these in their 03-05s? Im planning on gettin these for my 05. Tirerack recommends 215-50-17 but the set im buying has 235-45-17. Its actually smaller than the recommended but wider. Offset is 48, sounds to big to me. Whats the right offset for those of you who have 17"s?
05 accord ex I4 graphite pearl 5at w/o leather ASA AR1 17" wheels
stock for now, future mods- tein ss dampers, trunk lid spoiler, front underbody spoiler, foglights, and dvd system
Drive Accord
Old 09-07-2005, 05:32 PM
here's a pic from tirerack
Old 09-07-2005, 05:42 PM
VTECaddict's Avatar
VTECaddict VTECaddict is offline
Out of Control
i believe they should fit. how wide are the rims?
2006 BMW 330i 6MT (Alpine White/Terra)
Old 09-07-2005, 07:24 PM
BenjiBoy650's Avatar
DA janitor and busboy
Send a message via AIM to BenjiBoy650
235 is kinda wide but I THINK you should be okay. TL's use 235 17's.
Ben
"Marshmallow" - '00 Odyssey LX J35A1/4spd AT, 109K
Taffeta White/Fern cloth
Gone & Missed...
"Sandy" - '99 Accord EX I4 5-speed sedan, 145K
Heather Mist Metallic/Ivory cloth
"Kiwi" - '04 Mazda6s V6/5MT, 70K
Sepang Green Metallic/Black Leather
Old 09-07-2005, 10:46 PM
7. Im worried about the 48 offset. With a smaller offset you have the option of adding spacers but with too big of an offset there's nothing much you can do bout it. Thanks for all the inputs
Old 09-08-2005, 12:24 AM
VTECaddict's Avatar
Out of Control
they will fit. i checked discounttire.com, and several of the 17x7's they have listed for the Accord have +48 offsets.
Old 09-08-2005, 10:12 AM
04blkpearlcoupe's Avatar
04blkpearlcoupe 04blkpearlcoupe is offline
Rush fan
The offset is probably -48, not +48. A negative number moves the wheel farther out for a wider stance which is what most aftermarket wheels do.
Here's a direct quote from Discount Tire's site regarding negative offset:
"Note that extensive negative offset can potentially cause increased steering wheel kick-back and place additional stresses on the vehicle's entire suspension."
Gabe
04 accord lx coupe 2.4 auto
Old 09-08-2005, 01:37 PM
VTECaddict's Avatar
Out of Control
-48 offset would rub like crazy. the wheel would stick out the side of the car like 4 inches.
Old 09-08-2005, 02:35 PM
Rush fan
The OEM offset is -38 so -48 would put the wheel 10mm farther out, about 1/4 - 1/2inch.
positive/negative offset explained:
http://www.discounttire.com/dtcs/infoWheelOffsets.dos
http://www.off-road.com/chevy/tech/wheel/
Gabe
Old 09-08-2005, 03:34 PM
VTECaddict's Avatar
Out of Control
i know what negative/positive offset is. go outside and look at your wheel. the hub mounting surface is definitely on the street-side half of the wheel, therefore it has positive offset.
Old 09-08-2005, 03:53 PM
Rush fan
youre right. front wheel drive wheels have a positive offset. my bad. so then are those wheels +48 or -48? if they are +48 then the wheels would sit deeper into the wheel wells. that doesnt make much sense. if they are -48 then they would stick out real far like u said. that doesnt make much sense either.
Gabe
Old 09-08-2005, 04:06 PM
VTECaddict's Avatar
Out of Control
i dont know what the OEM offsets are...i've read +45 in some places, and i've also read somewhere that the 6MT wheels have a +55 offset?!
i think anywhere from +42 to +48 will be OK...but it depends on how wide the wheel/tire is and how low your car is.
Old 09-08-2005, 04:21 PM
+48 with a 235 tire might cause the tires to rub on the struts, especially if the car is lowered and has a ton of negative camber.
Ben
Gone & Missed...
Old 09-08-2005, 08:33 PM
I totally agree. Also considering a mild drop in the future. Should i get these then get spacers and put a little bit more stress on the bolts, suspension and what else...Does anybody here have 17" wheels in their cars and whats the offset and tire size?
Old 09-22-2005, 01:25 AM
finally got them today. I decided against the 235-45-17 tire size and went with a closer to stock size(215-50-17). Not to bad. Looks kinda small but i'll take it. Better than having a harsh ride if i got 18"s. I'll post pics as soon as i get a hold of a digital camera
Thread Tools
  Friends of Drive Accord
Throwdown Performance
Retro-Solutions
TV and NAV 2 Go
Diode Dynamics
Accord Mania
XenonDepot Lunarpages.com Web Hosting
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© Copyright 2002-2009 Wardsweb, LLC. All Rights Reserved.
