2009 Accord-Crack in windshield - Drive Accord Honda Forums
Old 08-15-2009, 07:22 AM
gmoliver gmoliver is offline
I came to Houston from New Orleans with my daughter to see my son. I have a 2009 Honda Accord EX-L V-6 with Navi. with 2500 miles. A rock hit about an inch from the edge of the glass where the inspection sticker is located. The crack is about 8 inches long. Anyone have good experience with repairing an 8 inch crack? I realize it may have to be replaced but thought about trying the repair first. Also, if it has to be replaced any opinion on getting OEM windshield?
Thanks,
Glenn
Old 08-15-2009, 08:00 AM
benzo's Avatar
benzo benzo is offline
4th Gear
as long as you catch the crack early and the crack hasnt migrated to the end of the glass, it should be repairable. I have a company called NOVUS who did my cracked windshields. They do a great job and i do believe they are nation wide. they will come right out to you and do the repair.
2008 Accord EX-L Coupe
Megan Racing Springs(2"drop)
Clear Bra
RV6 J-Pipe and Stuff
INJEN Cold Air
6000k HID Headlights/Fogs
Re-Wired Fogs(separate switch)
Lower Odyssey Grill Mod
Old 08-15-2009, 08:46 AM
Aviography's Avatar
Not worth repairing, it's just going to get worse, 8" is pretty long, plus the windshield is part of your safety barrier in conjunction with the actual frame of the car.
As for replacement, you don't need to get "OEM", as long as you get the name brand such as PPG, Pilkington, etc. as they are made for OEM application but won't cost you an arm and leg as the OEM prices would be.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 08-15-2009, 09:27 AM
TX WJ TX WJ is offline
Toyota / Honda fan
Some states require insurance companies to pay the cost of glass replacement with no deductible, SC requires that they cover all glass and not just the windshield. When my windshield in my Camry cracked they replaced it no charge.
2009 Toyota Camry XLE V-6, Sirius Lifetime
2006 Honda Odyssey EX-L, Navi, RES, Factory XM installed.
Old 08-15-2009, 09:32 AM
cajun's Avatar
cajun cajun is offline
Out of Control
+1 on everything above, but in my case I asked for the price diff to get an OEM Honda-marked windshield (made by PPG) vs. a PPG. Insurance covered it either way at no cost (including deductible) to me. Might be worth it to ask.
2010 PMM Accord LX-P, TSX rear sway, GG lower grille, 35% tint, 50K+
2006 Toyo Sienna LE, 100K+
2002 Accord SE (sold), TL rear sway and upper strut bars
Old 08-15-2009, 09:33 AM
LSUJeff's Avatar
LSUJeff LSUJeff is offline
CS1 #6048
I agree with Aviography. 8" is likely too long to repair. You could probably stop it from growing larger, but I'd also recommend a new windshield. Check the glass deductible on your insurance.
+1 on the NOVUS recommendation. I had them replace the rear glass in my 98 civic. The guy was a pro and did a great job.
2008 ASM Accord Coupe :: K24 :: 5MT :: EX-L NAVI
INTERIOR | PXAMG | 5th Gen Prelude Shifter | TSX Switchblade Key
EXTERIOR | HFP Side/Rear Kit | OEM Side Molding | 5K HID Lamps + Nokya Fogs | OEM Decklid Spoiler | Ody Lower Grille | Llumar 35% Sides 15% Rear | LED Switchbacks + Red Flashers
DRIVETRAIN | Stock
SUSPENSION | TSW Vortex 18x8 +40 | Kumho Ecsta SPT 235/45
FUTURE
Takeda SRI
OEM Rear View Camera
Tein SS Coilovers + EDFC
GReddy SE Catback
Old 08-15-2009, 09:53 AM
postmortem postmortem is offline
3rd Gear
OEM glass has evident problem with cracks (more cracks than average glass), I would stay away from it if I could. You are not only person with cracked windshield.
2009 Accord Sedan EX V6 White Diamond Pearl
Mods:None.
Future Mods: None.
Old 08-15-2009, 10:10 AM
AznRolla's Avatar
AznRolla AznRolla is offline
Azn Domination
I dont even think most glass places will fix an 8" crack...
2009 Honda Accord Coupe V-6 EX-L w/ Navi
Polished Metal Metallic
Debadged
35% Front/ 15% Rear Tint
6000K Low Beam HIDs
Coming Soon
3000K Fog Light HIDs
12" Kicker L5 in a Ported Box
Kicker zx7501
Old 08-15-2009, 10:18 AM
Thanks for the information. I was figuring that it would probably need to be replaced. I will check with NOVUS but my insurance has Safelite as their recommended glass company. As with Cajun I would like to get the replacement as OEM Honda marked. If it is PPG made then do not see a problem. But right now not sure what my insurance company will do. I think they will require the comp. deductible but will wait an see. They did say if the crack is longer than a dollar bill then they recommend replacement. If so then so be it. Thanks for the insight. Glenn
Old 08-15-2009, 12:02 PM
morcheez's Avatar
morcheez morcheez is offline
6th Gear
Send a message via AIM to morcheez
thats strange u say that...me and some friends took a road trip to ikea (in houston) from new orleans last monday...we borrowed one of thier grandparents 08 suburban and about 3 hours into our voyage we get hit by a rock and have a crack probably 2 inches from the top of the windshield to about an inch to the bottom..ughh...luckily they were cool about it and said accidents happen ...hope the same doesnt happen to me when i head that way for my vacation next month...anyways let us know the cost on the windshield im just curious to know
08 ASM Coupe i4/ tint / lip spoiler / 6k hids / 20" verde chaos 45mm offset 255/35 nitto nt555 / eibach pro kit / autozone grille mod / weathertech floor liners / clarion touchscreen / tsx key / trunk liner/ dual exhaust, v-leds white&amber turn bulbs/ fog lights w nokya 2500 bulbs/ odyssey lower grill/ custom wall in trunk/ 35&20 tint/black roof/ color matched grill and rear "H"
Old 04-25-2011, 08:01 PM
PtmacR PtmacR is offline
Are you saying this is common with accords?
Can you please share in more detail what you know about this? While the prior posts seem to be discussing cracks brought about by accidental impacts, i.e. rocks, your post suggests that there is a problem with the workmanship that is causing cracks.
Old 04-25-2011, 08:13 PM
ksills's Avatar
ksills ksills is offline
Wisdom Born of Age
Thanks,
Glenn
I had a similar experience with my 08 LXP and was advised that since Honda uses the windshield for structural integrity anything above 6 inches should be replaced, not repaired. I had full glass on my insurance so no cost. Could have had OEM but chose Safelight as it was more expedient.
2008 Honda Accord LX-P Sedan Tafeta White
  • Xenon Depot 4300K Volt HID kit
  • Spec-D projector headlights (Converted to HID)
  • Ultra Racing Upper Strut Bar
  • TSX Rear Sway Bar
  • Spyder LED Tail Light w/Tubes
  • PUTCO LED Dome Light Kit
  • Chrome grill overlay
  • Odyssey Lower Grill
  • Stainless steel door sills
  • Crosstour Leather Shift Knob
  • EX-L "Wood" Interior
  • Llumar High Performance 35% Tint
  • Rear Lip
Squirrels ...............nature's speed bump
Old 04-25-2011, 08:28 PM
Los's Avatar
Los Los is offline
4th Gear
Thats crazy. I too got a big chip in my windshield on my last trip from New Orleans back to Houston. This huge truck had mud and rocks flinging up in the air on I-10. I was sad to see it cause that size of a chip.
2008 EX-L PMM Coupe
Title goes here
close
video goes here
