96 Accord speedometer sticking - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > The Early Generations
Old 08-27-2009, 05:15 AM
ccparch57 ccparch57 is offline
Unhappy 96 Accord speedometer sticking
My 1996 Accord's speedometer occasionally sticks around the 20 mph location, and causes the odometer and trip meter to stop working. Other than replacing the whole cluster, is there a way to repair this? Also, if I replace it, is it possible to adjust the mileage to match my existing odometer?
Old 08-27-2009, 05:17 AM
A&Fbro28's Avatar
A&Fbro28 A&Fbro28 is offline
Out of Control
Send a message via AIM to A&Fbro28 Send a message via Yahoo to A&Fbro28
Time for a new speed sensor. It isnt much money that i can remember.
Desmond,
08 Acura TL w/Technology Pkg
08 Taffeta White Honda Accord EX-L w/Navi Coupe (traded-in)
http://www.cardomain.com/ride/3093726
Old 08-28-2009, 12:21 PM
12153 12153 is offline
banned
CCParch57:
Is your speedo solid-state (electronic)? Or old-style (mechanical) with cable drive?
Old 08-30-2009, 04:28 PM
ItsaHonda's Avatar
ItsaHonda ItsaHonda is offline
6th Gear
The 5th gen gauge cluster is electronic, not cable-driven... ditto for the 4th gen. The VSS (vehicle speed sensor) is a common problem on the older Accords, so it is certainly a possibility... but my experience with a VSS failure has been an entirely non-functioning speedometer, not just an intermittent pause. I would say to check the cruise control when the speedometer sticks, but I'm not certain that it even engages at 20 mph. If the VSS has failed or is failing, the cruise control will be inop.
1990 Honda Accord LX coupe
130,XXX miles
1989 Honda Accord LX sedan
186,XXX miles
1998 Lexus GS400
170,XXX miles
1992 Cadillac Allante
70,XXX miles
2013 Kia Optima LX
8,xxx miles
Old 08-30-2009, 04:42 PM
banned
ItsaHonda:
Thanks for the enlightenment. Were I not so lazy, I would look it up.
This represents a techno change from my 3rd Gen...which has a cable-driven, mechanical speedo. Its speed sensor unit governs (only) cruise control operation.
Old 09-09-2009, 02:41 PM
I have determined pretty much that it is my speedometer, so I was able to obtain a used one (entire cluster) at a Honda salvage parts place. I have figured out how to replace it, but now my problem is I can't get the trim off the console in order to get at the cluster. I removed the two screws underneath in front of the cluster and I can get that side pulled out, but I can't get the side above where the radio sits out. I have removed the two HVAC knobs, but it appears to be attached on that side. Is there another screw or something that has to come out?
Old 09-15-2009, 12:10 PM
h22accord h22accord is offline
i was going to say the same thing
check speed sensor
Old 09-15-2009, 02:48 PM
Shadow Works's Avatar
Shadow Works Shadow Works is offline
Always in reverse
Where is this speed sensor located guys?
Old 09-26-2009, 12:42 AM
htekken's Avatar
htekken htekken is offline
dont deviate
the VSS is tough to spot. it sits on top of tranny but towards the back. even in daylight it can be hard to see since its deep in the bay, so a flashlight would help. hard to replace cuz its hard to reach, i know, i did this last month.
OP how exactly did you determine it was the cluster? i know this thread is kinda old but curious cuz it sounds like a vss problem to me. my symptoms were, speedo needle went crazy up and down while driving, then just stopped moving completely, trip odom stopped working, odometer stopped working, and got the occasional CEL.
/94EX CD7 G77M/DZ-D1/JDM S2K HID/18RH-C5/WW-T/(gone)
/07SE CM5 NH700M/17V6-6/OEM LIP/Decklid/Hybrid LED/TSX HID/
/02IS BD1 B01B 8N8/
Old 11-02-2009, 02:03 PM
Speedometer replacement
I determined it was the speedometer cluster based on what my normal mechanic told me. He had suggested I could replace it myself, so I found one at a Honda salvage yard near me. The problem I have had is getting the cover off so that I can remove the cluster. I can see that it is held in by clips, but for the life of me I cannot get it loose, especially around the heater vents above the radio. Is there a special tool for this?
Old 11-04-2009, 10:15 AM
htekken's Avatar
dont deviate
no. did you trying using a flathead to pry? its been a while since i removed the gauge cluster so i dont member whut i did.
/02IS BD1 B01B 8N8/
