#31
| Sponsored Links | ||
Advertisement | ||
#32
8thGen - I think you're right. I just looked on the Honda website, and they list the Rear Decklid Spoiler as a standard exterior feature. I wonder if my trunk got swapped, or somehow they missed this at the factory? I did have the V6 badge on the back.
#33
#34
i just installed my 22mm tsx sway bar
body roll is considerably less when i took some tight turns at high speed (50mph)
08 TW Accord Coupe V6MT ------------------------------- Custom single exit exhaust w/ RV6 race pipe and XLR8 J-pipe AEM CAI TSX Switchblade TSX 22m rear sway bar window tint: 35% sides 15% back multicolor LED underglow HIDs 10k for headlights 8k in fogs/brights rvinyl taillight dark smoke tint Tein SS Coilovers Stock 18" flat black powdercoat VIS CF hood Ichiba 20mm wheel spacers, rear Megan Racing rear camber arm SPC tow arm and trailing arm EBC front and rear slotted rotors |
#35
-I went to magauto.com & after selecting swaybar&bushing(x2) after repeated attempts to 'checkout'---their system kept 'saying'"you have nothing in your cart"????? WTF?
Either I'm retarded or they're "system" aint working..?? Anyone else have problems there??
2008AccordCoupe-4cyl.-5spd.manual-Silver-limotintALL-manyMods.inFuture--CoiloversFirst... |
#36
Well, I managed to place my order at DelrayACURA----$79.40(w/S&H)--
the part # were--52300-TL2-AO1(swayBar) & 52306-TL2--AO2(Bushingx2) Hope I got the right stuff..cause your part#'s were---52300-TL-AO1---slightly different...?
#37
I would ask them if it's the 17mm and the corresponding bushings. I had trouble with Magauto too when I was using FireFox, but no issues with IE8.
2009 Accord Coupe EX-L V6 Auto w/o Nav Polished Metal Metallic Finished Mods: 1. 5000K 55W HID for the low beams from Retro-solutions 2. De-badged rear emblems 3. Hoen fogs & DRLs 4. Audio system (JL fronts and amps, eD sub, DynaMat in doors, RF cap, no rears) 5. LED white lights in interior, trunk, and license plate 6. TSX 17mm rear sway bar 7. Dual-mode LED blinker/night lights and LED DRLs 8. Takeda Retain Short Ram Intake Wishlist: 1. HFP Suspension Kit 2. HFP 19" Wheels |
#38
-I received my 17mm swaybar--it's really not THAT much bigger than the 15mm bar...I'm thinking the 22mm is the way to go..??
Now I gotta find were you guys are buying the 22mm swaybar???
#39
Someone correct me if I'm wrong but I think putting such a large bar in back without upgrading the front bar as well may cause snap oversteer ..
«2008 Accord coupe V6 6MT ASM» 19" HFP Wheels ¤ Tein SS Coils ¤ Retro Solutions 55W 5000K low beam HID & 35W 3000K fog HID ¤ 3M clear bra ¤ 3M tints (50/50/35) ¤ Angel Eyes JL C5-650 components in front JL C5-650x coaxials in rear JL Slash 300/4v2 amp JL CleanSweep Dynamat Xtreme everywhere Sundown SAE-1500D amp 2 JL 10W6v2's in custom fiberglass enclosures |
#40
I had a '79 Olds 98 & a '73Olds Cutlass--back in the day---neither car had SWAYBARs in the back BUT I installed SWAYBARS in BOTH(rear only) & they cornered like racecars--they performed OUTSTANDING--my point: beefing up our swaybar from 15mm to 22mm cant hurt...just make us more LEVEL. then again I dont even know what SNAP OVERSTEER is??? so, no offense....just sharing what little I've experienced w/swaybars.
#41
The way it works is a bigger bar in the front increases rear lateral traction and a bigger bar in the rear increases front lateral traction. So if the bar in the rear is much bigger than the bar in the front, the front will have much more traction than the rear .. so the car will tend to oversteer
#42
nice info from all of u...... i was just thinking is there any available poly urethane bushings for the end links and mount? if so, where did u get it and how much? cuz if thats the case i would try installng a stiffer bushings first then swap in the rear sway bar for the purpose of l"less work" with changing just the end links and mount bushings lol......
im a newb here but i read the whole thread........ 17 mmm ..makes sense cuz if its 22 rear and 26(?) front, that might cause a snap oversteer... im not an expert on suspension but what i did on my infiniti was 28/22 F/R with eibach and tokiko struts plus SPL adjustable FUCA and tension rods with adjustable RUCA and remaining bushings as poly urethane, ..... all i can say is WOW........ !
Ala ey kamusta na ga....™ 2009 Honda accord sedan ex ーー just basic for now 1994 infiniti Q45 1st gen --- traded in (my unfinished project car) 1996 suzuki swift 1.3 8valve 3spd AT |
#43
Nothing wrong with paying someone else to do it for you; some people do not have the inclination or time to do it themselves. Some of us have more important things to do.
#44
progress 22mm sway bar
I just installed the progress 22mm sway bar. The video was very helpful. if you get the progress sway bar you will have to drill out the bracket holes a bit if you want the new bolts to fit. Not a big deal just took some time.
#45
Just thought I'd offer a word of caution to all...
Despite taking precautions (i.e. liquid wrench on the end link nuts), the rust that had formed on everything over time still made it hard to unbolt the end link. I managed to strip the hex-shaped keyway that's in the end of the end link bolts (where the 5mm allen key goes) on one side. Had to remove the sway bar with that one link still connected, and then use a hacksaw to cut the link off the sway bar. Bought a new nut, and used what little thread I had left on the end link to put everything back together with some lock tite, but I'm not confident that it'll hold indefinitely. New end link is now on order ($32 CAD) If I had to do it all over again, I would still use the liquid wrench, but I would let it sit longer, hammer it a little harder, and then use a tap and die set to clean off the rust from the threads before trying to remove the nuts. I have to say that it's the dumbest arrangement on Honda's part. It's not the first time I've stripped the hex keyway in the end of a bolt because things had seized up over time. There has to be a better design out there that would allow better application of counter-torque.
2008 Taffetta White Coupe I4 5MT 18" TSW Vortex Hyper Silver (18x8, 40 ET) 245/45R18 Toyo Versado LX Eibach Prokit w/ Koni Sport (Yellows) Fog Lights (College Hills Honda) DIY Odyssey Lower Front Grille DIY Block Heater Cord Holder TSX 17mm rear sway bar |
| Sponsored Links | |
Advertisement | |
| Tags |
| diy, my 8th gen, my8thgen .com, rear, sway bar, tsx |
