Recommended Maintenance Schedule
With nearly 29K miles on my 2004 Accord, I'm approaching some maintenance items. The dealer recommends a bunch of things like transmission fluid flush, etc.
My previous car was a Dodge Intrepid and you definitely had to change the transmission fluid every 30K miles... but I wouldn't expect that of Honda. And so I guess my question is this: Which maintenance schedule would you go by? The dealer's or either of the ones listed in the Owner's Manual? I get the oil changed (by the dealer) every 3-4K miles, whether it's really necessary or not... but on bigger-ticket items I'm unsure how to approach it. Any input would be appreciated.
Redondo Red 2005 Acura TL 5AT non-navi |
| Sponsored Links | ||
Advertisement | ||
Good Morning All
My plan is to change oil every 5K, as for the transmission I will most likely due a simple drain and fill every 30K. I plan to do these myself. If the ATF starts looking darker or smells like it is burnt I might do a flush. Never have your tranny power flushed. Have had 2 bad experiences after power flushes..Both trannies quit within 15K. Tire rotations will be done most likely every 15K or so. Have had bad after effects from rotations. I usually do my rotation at Firestone or similar with one of their $20 Rotate and balance specials or coupons. Dealers get $25 plus for rotations only. RIP OFF Dan
2008 Toyota Tacoma Access Cab Pickup 4 cyl-5speed manual tranny 1991 BMW R100GS Purchased Feb. 1992 |
Oh, I have the tires rotated every other oil change at the dealer... and it's not $25, at least at the dealer I go to anyway.
I'm at 30k right now and here's my plan
DIY Oil change DIY Tranny fluid change DIY microfilter change (behind glovebox) DIY air filter inspection (I have a re-useable K&N filter) Tire rotation (at a local tire shop) Brakes - I don't worry about brakes until either 1) I start feeling vibrations when braking or 2) I hear sounds coming from them. Then I take them in to have the rotors and drums turned and the pads replaced if needed. I've learned from past experience that the brakes will let you know when they need service. Just be sure to get them serviced asap once they start giving the signals.
Gabe 2004 Accord LX coupe 2.4L auto 149,000 mi 1989 CRX 500,000 mi (sold) |
Consider when you read replies in this forum that you are surrounded by maintenance junkies. Some change their engine oil and tranny fluid at rediculous intervals (I'm actually one of 'em).. but it is likely not doing much good. As far as changing your tranny fluid, I'd recommend NOT doing a flush, but just simply doing a drain/refill with a filter change... if anything at all. It's amazing how few people know there is a serviceable tranny filter on the accord... odds are your service advisor doesn't even know. You would probably NEVER have an issue if you follow the manual and don't change it, though.
Durka Durka |
Thanks, everyone.
The auto trans fluid change every 30K is really cheap insurance. I think it would be prudent to change it at that interval in spite of the owner's manual.
If I had a Honda automatic, I would be changing my engine and tranny oil at the same time (3-5K). Some people use synthetic in their engines, but from what I see, the engine will go 250K on dino. Instead, I will use the difference in price to change the tranny fluid, which will cost 6K to replace if it goes out, and it will NOT always last 250K miles.
i have flushed my tranny fluid twice, with no problems.....
DA moderator 2007 Honda Accord LX Coupe 2.4 MT (163k miles) gone, but not forgotten: 1993 Honda Accord (341k when sold, retired @ 369k) 1999 Honda Accord coupe (168k when sold, last check-in @ ~197k, blown head gasket) |
Why are you guys paying to have the tires rotated? It can easily be done when you put the spare tire into the mix temporarily.
2013 Accord EX-L Navi 6,612 miles and counting... YTD avg mpg = 30.07 . . . . Last tank mpg = 33.84 2005 Accord EX-V6 Sedan (3/05-1/13) retired at 127,110 miles 1993 Accord 10th Anniversary Edition Sedan (5/08-7/10) Retired at 153,007 miles 2000 Civic Si (5/00-3/3/05) Retired at 59,500 miles |
Yeah but stiller you have one of the automatics when they were making them solid.
Rotating the tires is something most folks should be able to do easily in their driveway. It also allows you to inspect the brakes and suspension components. AT fluid change every 15-30k would be great. This can easily be done by almost anyone. Maybe change the fluid every 15k & change the filter every 30k.
--------------------- 2002 Accord EXVL Auto Sedan - Nighthawk Black Pearl / Quartz, fog lights, mud guards, wheel locks, trunk tray 1994 Pontiac Grand Am GT Auto Coupe |
The maitenance schedule in the owner's manual is the better approach, unless you want to help your dealer with the mortgage on his 2nd home. Do not neglect AT fluid changes - - even on a Honda, and stay with Honda ATF (as well as other Honda fluids, except oil). Talk to other Honda drivers near you and hopefully they can recommend a good independent. For a few weeks, I asked every Honda driver I saw at work, the gas pump, ball games - - met many interesting people who are always happy to talk about their Honda. |
Durka Durka |
As CA05LXDriver mentioned, Some of us are maint. junkies. I am one of those.
On our new Accord it goes like this. Change oil and filter about every 5K. Use M1 5w-30w with M1 filter. Drain and fill the 5at tranny every other oil change with filter change. Rotate tires > front to back. Keep rotation the same. Inspect brakes and other wheel well componets. Check and lube if needed all door, hood and trunk hinges. Check and clean air fliter every oil change. K&N going in this oil change. Cabin air filter and wiper blades every 6 months. Will change cabine air filter over to one that has carbon in it. A user here supplied a link to a co. that makes a filter like this for the Accord. We expect to see 200k plus miles on this car and expect no major problems with it. We have owned the car 3.5 months now I think and it already has almost 10k miles on it. Seeing that the wife and I ride into Tulsa together now for work. The car will see a easy 30k a year. In years past we would both take a car in everyday and see 22k to 25k on each car every year. The way milage will pile up on this car will change. The Ranger is paid off now so we will buy either a 06 Civic or a 06 Accord LX se sedan in the coming months. If we get a Civic Hybrid or Coupe it will end up doing alot of the daily drive work and the Accord will get a break. If it turns out to be a Accord LX se or a Civic Si. They wont see as much of the daily work and will be more evening and weekend rides. With the Accord or Si getting some mod work done. The maint. we be the same for them. The Rangers maint. has been the same also, and will continue as such. You can never to do much maint. But you can do to little. All maint. and service work done in my driveway. Dealers = BAD!!!
09 HCHII,w/Navi,I4,CVT Crap,Atomic Blue/Beige,70k Miles (Dull/MPG/Quite Civic) 07 Mazda3 S Touring,I4,5MT,Purple/Charcoal,80k Miles (Civic What?) 00 Ranger Ext,XLT,I4,5MT,White/Gray,200k Miles (Thinks it's a F-150) X, 05 Accord EX Sedan,I4,5AT,Red/Gray,89k Miles (My Fav. Accord Gen) X, 06 Civic EX Sedan,w/Navi,I4,5MT,Silver/Gray,44k Miles (No Better Than GM Junk) Can you save a gal. here and there then blow a half gallon playing with the tach? It can be done! |
what is the difference between a mere drain and refill for the ATF, as opposed to a flush?
2004 Accord LX I4 AT Silver Sedan |
| Sponsored Links | |
Advertisement | |
