Accord 2003 Passenger Door Child Lock - Drive Accord Honda Forums
Old 09-11-2009, 06:18 AM
Halon_X Halon_X is offline
I bought an Accord 2003 Coupe. If someone tries to open the passenger door with the lock on, the door cannot be opened from inside even though you remove the lock. You have to open it from the outside. Any way to remove this kind of child lock mechanism??
Thanks for your inputs!
Old 09-11-2009, 07:00 AM
Honda247's Avatar
Honda247 Honda247 is offline
I snapped my G string....
Send a message via Yahoo to Honda247 Send a message via Skype™ to Honda247
There is a lock on the end of the door. Open the rear door and look for a rectangle switch. Up is for lock and down is for unlock. I think that what you are reffering to....
2009 Civic EX TW
K&N Drop in Filter (33-2342)
Eibach SportLines (4.3140)
Apexcone Raptor V2 35W 5000K HIDs (9006)
Nokyas Hyper Yellow Stage1 2500k High/DRL (9005)
Nokyas Hyper Yellow Stage1 2500k Fogs (H11)
Painted Engine Cover
FRANCI5
Cardomain
Facebook Profile
Youtube
Old 09-11-2009, 08:26 AM
03LXV6's Avatar
03LXV6 03LXV6 is offline
Moderator
OP you sure you are talking about child lock. I don't think 2 Coupes come with child lock. If you are talking about just the door lock itself, maybe the cable on the inside is broken and will need to be replaced.
2007 EX-L 4DR
Old 09-11-2009, 10:27 AM
Thanks for your reply. I used the term child lock because that's the way the door is behaving. The lock cannot be damaged. It opens without any problems if the lock is off.
Old 09-11-2009, 10:28 AM
It's a coupe (2 door).
Old 09-11-2009, 04:42 PM
Honda247's Avatar
Man, I need to learn to read the whole post first..... I fail....
2009 Civic EX TW
FRANCI5
Cardomain
Facebook Profile
Youtube
Old 09-11-2009, 06:33 PM
Antarctica's Avatar
Antarctica Antarctica is offline
Forum Insomniac
So what kind of lock are you talking about? I just walked out to my car to see what you're talking about, and the coupes do not have a child lock at all. That feature is usually reserved for the backseats only in sedans. Is the lock you're referring to an electrically-operated lock or manually-operated lock? Take a picture of the lock and post it here so we can help you.
2003 Honda Accord EX-L V6 6MT, Satin Silver Metallic
Infinity speakers with 3 Treo 10" subwoofers
Old 09-12-2009, 08:29 PM
AMAN1 AMAN1 is offline
6th Gear
Don't know why a coupe would have a child lock at all, don't think they came with them at all. Check your owner's manual it should have some stuff on child locks.
Old 09-13-2009, 10:57 AM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
Coupes don't have child locks on the latches.
If it won't open from the inside, the release cable probably broke where it attaches to the handle. Cheap soft plastic.
Old 09-13-2009, 01:26 PM
hillstones hillstones is offline
Sold the Accord
Take off the door panel and check the cable connecting the handle to the latch mechanism.
Either the cable broke at the interior handle, or it broke at the latch mechanism. Or, someone replaced the door lock actuator and did not have the latch with the cable in the correct position when they reassembled the latch mechanism.
So how good are you at do-it-yourself activities? If you are handy, I can provide you with instructions for removing the latch mechanism to check the operation of the cable (if it is not broken at the interior handle).
Old 09-14-2009, 07:15 PM
Gapo Boy's Avatar
Gapo Boy Gapo Boy is offline
3rd Gear
It seems I am having problem with actuator on the driver side. Can you direct me to the right thread which discusses on how to go about this one (DIY). I tried to search DIY in this forum but not luck yet. Thanks!
Current Ride:
2011 Toyota 4Runner SR5 Upgrade Package@7,000km
2004 Accord EXL I4 @ 150,000 km
Previous Rides:
1997 Accord EX-R V6
1994 Toyota Cressida I6
1991 Toyota Corolla I4
Old 09-14-2009, 07:51 PM
Sold the Accord
Here is the info if you have a coupe:
http://www.driveaccord.net/forums/sh...91&postcount=1
Old 09-18-2009, 07:52 AM
Thanks for your inputs people! I was out for a couple of days!
I will try the door panel removal procedure. But it's kind of funny because the door is ok as long as you open it with the door lock removed.
Thanks for the link Hillstones!
Old 09-18-2009, 09:52 AM
03LXV6's Avatar
Moderator
I think you are misunderstanding the function of the door lock. When the lock is engaged, pulling on the handle will not open the door.
I think I have seen on some ford vehicle where the door will still open from the inside even if the lock is engaged.
2007 EX-L 4DR
Old 09-18-2009, 12:23 PM
What I meant was that when I try to open the door with the lock engaged, the door makes a kind of a click and even though I removed the lock it does not open. I have to open the door from the outside.
Title goes here
close
video goes here
