I recived a bad tinting job
I went with a friend who does vinyl graphics for cars, and he knows a guy who has been doing tinting for years. I spent $250 for the car. He used really good tinting film. I went with 35% all the way around. However when I look out the back window now, it seems like the view is rippled...I looked closely at the film on the back window and it's kinda dimpled.
Has anyone else had optical clarity problems on the back window? I was thinking that maybe it was a batch of defective material, or maybe its the "rake" or incline of the rear window that is causing the rippled effect?? Has anyone gotten their 2009 Accord Coupe tinted and had a problem with optical clarity in the rear window? What brand of material did they use? 3M etc?
2009 Alabaster Silver EX-L 6000K HID Lights low beams Llumar 35% tint back, sides Clear vinyl protection (hood, front bumper, side mirrors) 19" ASA AR1's (silver) My photo stream via Flickr http://www.flickr.com/photos/chicago...7618854154167/ http://www.flickr.com/photos/chicago...ot/3904721219/ |
| Sponsored Links | ||
Advertisement | ||
you might have to let the tint cure for a few days.....but give the tinter a heads up about it.
-08 Accord lx-s 5speed manual/ tafetta white mods |DDM tuning 6k hids|12" Alpine Type-R|TSX switchblade|Lip spoiler|Type-R Suede red stitch boot|Gunmetal Type-R knob| |Intake Resonator Delete|Hyper White led license plate led|led interior bulbs|Smoked Reverse lights| Previous owned -97 Acura 2.2CL auto/Flamenco Black |
There should be no problem whatsoever with how the film attaches to the glass. Tint film is not very thick whatsoever and has no problem adhering to something just because of how angled it is. If it is dimpled, it could potentially be water underneath that was not properly squeegied out.
If it was just recently done (i.e. today), let it bake out in the sun for about a week, and any small bubbles that have water underneath should evaporate away. Don't try to push it out yourself, you could cause a fold in the film if you do it wrong.
2009 CS1 ASM | TaoDesign | OEM | Prodrive | Sumitomo | McGard | UltraRacing | BC Racing | SPC Magnaflow |TopSpeed | Digital | ValentineOne | Alpine | Pioneer | WeatherTech | DIY 2007 AP2 LBP | OEM | Hüper Optik | GPFab | Berk Technology | Modifry |
if you see little individual circles in the film that's just water. You'll need to wait 24-48 hours for the film to dry and properly adhere to the window. Just give the tinter a heads-up and if you're still unsatisfied with the job (and for $250 you should be VERY satisfied) ask him to redo the problem windows
give it a week in the sun...I'll bet it's fine...
'13 EX-L I4 COUPE STEEL/BLK Click here for pics New Accord? Click here for a good PDF detail procedure Other car: `13 Camaro 2SS |
Its been on over two weeks. The tinter saw it and will attempt to fix it..sigh....hope it was a bad batch of material.
If it's the rear window that's giving you problems, it will be a pain in the butt to replace if it gets cured and stays on for a while with bubbles. Taking off rear tint is the most problematic place because of the defroster lines. Tearing too hard can damage the lines and cause them not to work anymore. So if it holds bubbles past 3 days, take it to the tinter asap, so it doesn't get completely dried down with the glue.
Edit: Just saw your post. The tinter should be able to lightly slice the tint along a defroster line and push the air out. It's not usually a big problem, but can be fixable.
Are you sure this guy know what's he's going? There's a simple solution to remove the rear tint. It involves a hot sunny day and a black plastic/cloth covering the inside of the glass. Steel wool on glass... come on now.
2013 EX-L V6, MSM/Black Mods - Deck lid spoiler - Llumar 30 + Air Blue 80 - exLEDusa interior - Morimoto Elite 3Five 5500K - WeatherTech floor liner - 3M ScotchGard 2008 EX-L Night Hawk/Ivory, RIP |
He claims to have been doing this for over 10 years.. When he mentioned steel wool....and scrubbing over the defroster lines....dunno.....I have the appointment tomorrow at 9am....
Steel wool if used harshly, yes, will hurt the defroster lines.
I have always used 409 with a large cut trash bag sealed up on it for hours on end in order to get old tint soft enough to peel off. Steel wool is never used with us, and we use a 1" blade to scrape off glue inbetween the defroster lines.
And ammonia based solution which helps loosen the adhesive.
2005 Satin Silver V6 Coupe 6 speed, Venture Shield clear protetive film, TL shift knob, Hidden Hitch, GM Friction Modified Synchromesh transmission fluid 2007 Acura TL-S front/rear sway bars, Clutch slave cylinder restrictor valve delete. Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960 Honda steel rims 225/55-16 Michelin Alpin PA2 __________________ DA Moderator Team DriveAccord.Net Forum Rules & Regs DriveAccord.net Classified Rules |
brother used a steamer and steamed it for a couple of minutes and it peeled right off in a whole sheet
2009 CBP accord coupe EX MODS 4x40 pieces trident hardshell gum, wintergreen, bubblegum, peppermint, strawberry blast. All flavors of HI-CHEW FUTURE MODS Ice breakers sour mints |
I got Llumar Formula One Pinnacle 15% on my rear windshield (yes, same '09 model as you). The first thing I noticed at night was some "blurriness" with headlights. The lights streak vertically into a thin line. I asked the installer at the tint shop and he said this was due to the way light reflects off the tint when it goes around the rear defroster lines and there is no way to get rid of it (besides removing the tint). Have not had the same problem on the other windows.
Though it is annoying, I've gotten used to it. During daytime, it's no big deal, but you really have to be looking for it to notice any minor distortions. I let the tint set a few days before cleaning the windows. Cleaning off some of the excess residue left by the tinting solution helped a little too. |
Exactly!!!! This is what I have a problem with! Oh man, this ****s... :-(
| Sponsored Links | |
Advertisement | |
| Tags |
| defective, not optically clear, rippled, tint |
