Can somebody school me on the Accord's traction control? - Drive Accord Honda Forums
Old 09-18-2009, 08:22 AM
Z-CARR's Avatar
Z-CARR Z-CARR is offline
I had trouble finding a clear answer to this in a search of the 7th Gen forum...
This is the first car I've owned that has a traction control other than ABS. The 7th Gen Accord does have "stability control" as part of the traction control system, correct? Is the traction control only effective to prevent wheel spin on takeoff, or is it also active at highway speeds to prevent sliding?
The reason I ask is that it was a point for me to get a car for my wife to drive that is safer than our old 1998 Maxima. She is a very good driver. She's a professional delivery driver in fact for a certain well-known company so I'm not so concerned about her skills and habits. I am, however, always concerned about the skills and habits of all the other drivers and obstacles on the road.
Can some of you please take a few minutes to explain to me the extent of the functionality of my Accord's TCS?
I'll also be having a look at the owners manual when she gets home tonight so see if there's any good info in there.
Thanks in advance!
Chris
2005 Honda Accord EX V6
2003 Toyota Tundra V6 Access Cab
1991 Nissan 300ZX 2+2
(Twin Turbo Conversion.. All around, Very Highly Modified)
Old 09-18-2009, 08:39 AM
Cleankill's Avatar
Cleankill Cleankill is offline
4th Gear
Traction Control System = prevent wheelspin off the line / lose of traction on acceleration
Honda VSA (Electronic Stability Program; also known as ESC, VSC, VDC, advanced trac, etc) = prevent understeer/oversteer/lose of traction
07' J30A5 Auto 4Dr, 20mm TL-S rear sway bar, Neuspeed front tower bar, Debadged "SE"
Old 09-18-2009, 09:42 AM
Z-CARR's Avatar
Is my '05 Accord equipped with the VSA? I'm going to assume now that it is not since I haven't seen anything that leads me to believe that it is (ie: dash lights, documentation, etc.). Thanks for the reply.
Old 09-18-2009, 11:03 AM
ezshift5's Avatar
ezshift5 ezshift5 is offline
6th Gear
.....we have similar cars .....which - IIRC - are not VSA-equipped.
ez....
2005 Accord EX V-6 Coupe 6M
Taff. White;cargo net;7-24-05
'13 VW JETTA SPTWGN TDI 6M
Build date:03/12/2013 NO NAV
ZERO SUNROOF:CANDY WHITE
1982 VW Rab. Diesel Pickup 5M
Mojave Beige/ac/bedliner/alloys
(sold to restoration outfit)
Last edited by ezshift5; 09-18-2009 at 11:04 AM. Reason: sentence structure/context
Old 09-18-2009, 11:34 AM
nolefan32's Avatar
nolefan32 nolefan32 is offline
4th Gear
If your car has VSA, the quickest way to tell is there'd be a switch to turn it off, down next to the switches for the sunroof (low on the dash, to the left of the steering wheel). Some cars have ESC systems that are too touchy, hence why they come with off switches, although Honda's VSA is generally not to intrusive.
And I have had mine kick in in all driving conditions, not just on takeoff. Any time the car senses wheel slip (which is a lot less now that I've got better tires than the stupid Michelins that came with the car).
Proud owner of a 2007 Honda Accord coupe V6/6MT with navi
Nighthawk black pearl/Ebony leather
Wing spoiler
Fog lights
Parrot bluetooth kit
Sport pedals
VentureShield hood protectant
Old 09-18-2009, 11:49 AM
accordn17's Avatar
accordn17 accordn17 is offline
goodfella
so the 2005 accords dont have any of that? even an 05 ex-L? coupe
Satin Silver
05 accord coupe ex-l I2.4
k&n drop in filter
o-nex 6k hid's
pioneer highs
alpine typex 12inch sub...
900watt rockford amp
19inch vsr wheels...
pirelli zero nero z rated tires
Old 09-18-2009, 01:07 PM
Aviography's Avatar
03'-05' V-6 cars have TCS - Traction Control System, that's it and nothing more, it applies font brakes to bring spinning tires under control, and it will also retard throttle (since it is electroinc throttle with no direct cable between your foot and the throttle plate).
06'-07' V-6 cars have VSA - Vehicle Stability Assist, it is the TCS in the 03'-05' Accords plus additional electronics to control front and rear brake calipers independently to bring a slightly out-of-control cars back in line. Note that if you grossly mis-handled your car such as driving beyond the road condition or going into a turn marked for 30 MPH at 90 MPH, then physics and Newton's Laws take over, nothing will save your @$$ at that time.
I don't believe the I-4 cars had the TCS or VSA, it's easy to tell as the switch is to the left and below the steering wheel, it's part of the 3 switch cluster of sunroof, TCS/VSA, and the fog-light.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 09-18-2009, 01:28 PM
Aceman196's Avatar
Aceman196 Aceman196 is offline
6th Gear
As stated above The VSA is not like what you would get in a BMW or Benz.
07 Accord EX-L V6 6spd(TSB)
Night Hawk Black
25% Tint all round
2 Door
USA-SPEC PA15 HON2
