accord-tsx 170hp-200hp WTF - Drive Accord Honda Forums
Old 10-10-2005, 08:41 PM
Mv774's Avatar
Mv774 Mv774 is offline
30-35mpg
Send a message via AIM to Mv774
so whats up with the tsx having 30 more HP.... acura honda needs to get there..... stuff straight
question: how does the tsx make 30 more HP the engines are the same right?
anybody think of a tsx head swap? or a camshaft swap?
or maybe its mapped differently?
i know it would cost alot of money but wouldnt somebody have done it already?
https://www.paypal.com/us/verified/p...%40yahoo%2ecom
Proud member of N.A.T.O. - No Altezza Taillights Organization.[/SIZE]
Old 10-10-2005, 08:52 PM
BenjiBoy650's Avatar
It's ridiculously easy to get the engine to make 30 more HP when you can modify everything. You can get the head you have now modded/port/polished with cams and such and easily get +50HP.
Old 10-11-2005, 03:55 AM
stevel's Avatar
stevel stevel is offline
accordless
the accord and tsx engines are the same family and displacement, but most other specifics of the engines are different, compression, etc.
'08 RDX tech.
'06 accord V6 6 MT nav sedan... gone.
'06 TSX 6MT.
Old 10-11-2005, 04:02 AM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
Also the TSX version of the 2.4 requires premium fuel to achieve 200HP.
Old 10-11-2005, 07:35 AM
EXLNavi's Avatar
EXLNavi EXLNavi is offline
Blast from the past!
Send a message via MSN to EXLNavi
Yep, that's a result of higher compression, I suppose.
'04 EX-L i4 5AT with Navi
If your mother still drives you to school,.... you ain't no gangster. PULL YOUR PANTS UP!
Old 10-11-2005, 11:21 AM
04blkpearlcoupe's Avatar
04blkpearlcoupe 04blkpearlcoupe is offline
Rush fan
The accord engine uses a different head and cams. The VTEC mechanism in the accord is less aggressive too (hence the different cams). In the accord, when VTEC kicks in it only opens a 4th valve (on the intake side). It normally runs on 3 valves per cylinder. There's no VTEC at all on the exhaust side. It's designed more for fuel economy.
In the TSX head, VTEC is used on both intake and exhaust valves, and when it kicks in, the pairs of valves synchronize and open wider like in other VTEC engines.
Gabe
2004 Accord LX coupe 2.4L auto 149,000 mi
1989 CRX 500,000 mi (sold)
