Drive Accord Honda Forums
Google
Thread Tools Rate Thread Display Modes
Old 10-13-2009, 02:39 PM
goldendragon576 goldendragon576 is offline
TPMS question
Quick question...I have snow tires that I plan on putting on my 09 Accord. I had them on my Acura and I know they fit. Question is, the snow tires do not have the TPMS sensors in them, will that effect anything when I put the snow tires on?
Drive Accord
Old 10-13-2009, 02:54 PM
Honda247's Avatar
Honda247 Honda247 is offline
Hello Kitty
Send a message via Yahoo to Honda247 Send a message via Skype™ to Honda247
Yes. You will not be able to turn off VSA. And you TPMS light will alway be on.
2008 Accord Sedan EXL V6 PMM
K&N Drop in Filter (33-2403)
P2R Throttle Body Spacer (P306)
Eibach Pro Kits (4076.140)
Nokyas Arctic White Stage2 7000k Low Beams (9006)
Nokyas Hyper Yellow Stage1 2500k High/DRL (9005)
Nokyas Hyper Yellow Stage1 2500k Fogs (H11)
Painted Exhaust Tips.
Painted Engine Cover
OEM Interior Illumination
OEM Splash Guards
OEM Cargo Net
Crosstour Leather Shift Knob
FRANCI5
Cardomain
Facebook Profile
Old 10-13-2009, 05:26 PM
nic's Avatar
nic nic is offline
4th Gear
Unless you put the tires on the rims that are on the car now... otherwise you either live with the TPMS light and the VSA... (if you get stuck, turning off vsa could help, but if you have good tires you shouldn't get stuck)... or get another TPMS set for the winter tires. Note that to install them they're going to have to take the rubber off, mount TPMS, remount the tire, reprogram the ECU, etc... expensive stuff :o(
Nic - 2009 Honda Accord Sedan EX-L w/ NAV (Inline 4, Manual 5 Speed) Crystal Black Pearl on Tan Leather
Completed mods: Tinted windows - V-LEDS interior and license plate bulbs (Click here) - Genuine Honda fog lights (Click here) - HIR headlight bulbs for low & high beams (Click here) - Takeda SRI (Click here) - WeatherTech FloorLiner DigitalFit Tan (Click here) - TSX rear sway bar (Click here)
Old 10-13-2009, 06:17 PM
so the TPMS light will stay on, what about the VSA? Since I can't turn it off, which I don't mind, I assume the light will be off. VSA light off means it's on and VSA light on means it's off.
Old 10-13-2009, 06:57 PM
nic's Avatar
nic nic is offline
4th Gear
That is correct, the VSA light will be off; it's only on when it is disabled.
Old 10-19-2009, 01:46 PM
thesedcshoes's Avatar
thesedcshoes thesedcshoes is offline
Laugh Out Loud :D
Hey if I rotate my wheels will I have to get the monitoring system configured?
Old 10-19-2009, 01:55 PM
Honda247's Avatar
Hello Kitty
Nope....
OEM Splash Guards
OEM Cargo Net
FRANCI5
Cardomain
Facebook Profile
Old 10-19-2009, 07:03 PM
craziexstylez's Avatar
craziexstylez craziexstylez is offline
STUNNIN
where can i go to get my sensor program? Do i have to go straight to honda or any tire place would do? And what the general cost to do that?? Thanks
08 Accord Sedan EXL V6 W/Navi RBP
Im selling my ateq tpms quickset, pm me if interested.
http://www.driveaccord.net/forums/sh...ad.php?t=38346
____________________
Old 10-22-2009, 06:34 AM
aeoporta's Avatar
aeoporta aeoporta is offline
moooo
If your tire place cannot reprogram your comp via ecu do not waste your money going to the stealership. get the sensor codes for each tire then buy the ateq tpms quickset and change codes yourself.
http://tpmsoutlet.com/at-tpmquickset.aspx
Old 10-22-2009, 06:36 AM
Danielc409's Avatar
Danielc409 Danielc409 is offline
6th Gear
What's a set of 4 sensors run? Might as well get another set for my stocks.
2008 Honda Accord Coupe V-6 EX-L Automatic NBP
RetroSolutions 55w 6000k HID's
Greddy Spectrum Elite Cat Back Exhaust
K&N Typhoon Short Ram Intake
Megan Racing Street Coil-overs
20" Vossen VVS-083 20x9 20x10.5
Bridgestone Potenza RE760 Ultra High Performance Summer Tires 245/35/20 Front 285/30/20 Rear
Hoen H11 Endurance Yellow Foglights
Progress Technology 22mm RSB
WeatherTech Digital Floor / Cargo Liner and Window Deflectors
Forthcoming
SPC 3 Arm Rear Camber Kit
Old 10-22-2009, 04:39 PM
aeoporta's Avatar
moooo
about 120 to 130 via tirerack prob can get em cheaper.
Old 10-22-2009, 04:43 PM
Danielc409's Avatar
6th Gear
Eh i looked at tire rack, looks like just retrofit stuff.
Forthcoming
Old 10-28-2009, 02:39 PM
STUNNIN
Sorry to bother you, I just got my new wheel tpms program.. Am I'm gonna have any problem if I put my stock wheel on? Do I have to get it reprogram the stock one after I just reprogram the new one?? Go oem.. I got mine 96 shipped..
Old 10-28-2009, 05:33 PM
aeoporta's Avatar
moooo
yep every time you change tires you have to update the computer thats why i say get the ateq programmer and diy
Old 10-28-2009, 06:02 PM
CaptainAmerica's Avatar
CaptainAmerica CaptainAmerica is offline
3rd Gear
I just put on new Honda 18" HFP rims I purchased at College Hills Honda and they came with the Honda OEM TPMS sensors and the following instructions http://www.collegehillshonda.com/ins...n/18wheels.pdf (warning 600k download).
I went to the local tire center who is very professional and they've been in business for ~ 40 years. They set the TPMS sensors and told me there are two ways to do it. The easier way is to set the computer to detect the new sensors and the more involved way which involves bumping the tire pressure incrementally. They took the easy route and now about 300 miles later my TPMS sensor light (2009 EX-L V6) comes on today so I have to go back.
So my question is if I get the ATEQ TPMS Quickset I wonder how it differs from their method of detecting the sensor? Unfortuntely I don't know the exact procedure they used but they said it was some type of standard TMPS setup steps they used as dictated by one of the tire manufacturers. I can't imagine the procedure for using this new tool is that much different from theirs. Do the sensors need to be initialized in some way? It doesn't sound like anyone here who used the Quickset tool is having a problem and once they get the numbers programmed they are good to go. If I look at the Honda instructions it sounds more involved but I'm wondering how this tool skips those steps?
Tom
Thread Tools
  Friends of Drive Accord
Throwdown Performance
Retro-Solutions
TV and NAV 2 Go
Diode Dynamics
Accord Mania
XenonDepot Lunarpages.com Web Hosting
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© Copyright 2002-2010 Wardsweb, LLC. All Rights Reserved.
