Maintenance Minder? Code B12? - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 10-19-2009, 10:13 AM
FollowingNFront's Avatar
FollowingNFront FollowingNFront is offline
6th Gear
Ok so I bought a certified '06 Accord EXL V6 (4dr) in July of this year from Paragon Honda in Queens.
My maintenance minder is now on 15% telling me its time for an oil change....
The code associated with it is B12. (yes like the vitamin)
I called a local dealer to schedule an oil change and ask about the code...
They said that the code is saying that I need to: rotate my tires, adjust brakes, change oil, cabin filter, and some other visual inspections...
She said all-in-all it would cost me $220!!!
I have a couple of questions:
-1) How does the maintenance minder do its thing? The service writer told me that the car's sensors kept track of how I drive and displays the appropriate code for that... Is that true?
-2) I just bought the car 3 months (5,000) miles ago... When they certified it, didnt they rotate the tires, adjust my brakes, change my oil, and my cabin filter like "B12" is telling me to do? Can I just skip this one?
-3) sooooo, can I just get my oil changed and not worry about this "B12" this time around? Would it hurt the car any in the long run?
Because I dont have that kind of money at this moment.
Thanks
2006 Accord EXL-V6 Auto 4dr (CM6)
+ Desert Mist
+ MODS: HFP suspension with Ingalls rear camber kit, Morimoto Mini H1 retrofit, Nokya Hyper Yellow drl/highs, 17mm TL rear sway bar, JBL GTO 6x9's and tweeters, splash guards, WeatherTech DigitalFit floorliners (front) and Honda all-weather floormats (rear), trunk tray, hood bra.... More to come
= Sexy
Old 10-19-2009, 10:22 AM
edbro edbro is offline
3rd Gear
I wondered the same thing. I have a brand new 09 that only has 300 miles on it. But, the oil life is still at 100%. So, even if it clicks down to 99% at the next mile, this tells me that the oil is good for 30,000 miles. NOT!
Old 10-19-2009, 10:25 AM
CYANiDE CYANiDE is offline
VTAKKKK
Send a message via AIM to CYANiDE
Thanks
Read my post on V6P.
It goes down by 10% each time. Regardless, check your oil at least once a month. My indicator was still at 30% when I changed my oil at about 3.5k after the last change. Oil was black as hell anyway...I wouldn't have wanted to leave it for another 1k miles.
2006 Accord EX i4 Sedan - 5AT - Graphite Pearl - [89,0xx miles]
FF Type II Coilovers || Skunk2 Front Camber Arms || Ingalls Rear Camber Kit || Acura TL-S 27mm Front/20mm Rear Sway Bars || K&N SRI
Old 10-19-2009, 11:17 AM
6th Gear
I answered you on V6P
+ Desert Mist
= Sexy
Old 10-19-2009, 11:45 AM
hillstones hillstones is offline
Sold the Accord
The cabin filter is changed every 30,000 miles. It is a $22 part from Honda (use the Honda eStore and pick it up at your dealer, estore.honda.com). The part is under the heater blower topic under the interior section. You only need the filter, not the filter holder assembly.
To replace it, open your glove box and unclip the clutch lever on the right side. Then pinch both sides of the glove box inward to release the tabs holding the door. Let the door open all the way to the floor. Then look up in the dash and you will see the filter holder with two tabs on each side. Push the tabs inward towards each other and slide out the filter. Make sure you pay attention to the flow arrows on the filter and the holder to make sure you put the filter in the correct direction for air flow.
Who knows what they do when they claim a used car is "Certified." I believe the maintenance minder is still mostly based on mileage on the vehicle. It will trigger different maintenance codes based on the mileage on your vehicle.
Old 10-19-2009, 11:54 AM
6th Gear
Ok... So since the car only has 25k on it right now, and the cabin air filter is changed every 30k, since they explicitly told me that they changed the cabin air filter upon certification, Ill wait until my next oil change to do it... Which should be just over 30k miles.
I think I will either do the oil change myself or have the dealer do it... I may be able to rotate the tires myself...
What do they do when they "adjust the brakes"?
+ Desert Mist
= Sexy
Old 10-19-2009, 12:18 PM
flippco's Avatar
flippco flippco is offline
4th Gear
Oil life is not linear, meaning the more miles and heat it is exposed to the faster the oil degrades. There is a sensor that captures engine revolutions and temperature. The oil life indicator is an estimate on how much longer until the system recommends changing it.
The cabin and engine air filters are pretty cheap, I just changed both in about 10 minutes and both filters cost around $30 at my local auto parts store.
I would also recommend signing up for Owner Link, there is a good overview of the maintenance minder system and you can see the maintenance schedule. Depending on how many miles are on the vehicle it would be a good idea to budget for some upcoming services such as timing belt/water pump, tranny drain and refill and coolant flush.
https://www.ahm-ownerlink.com
2006 Honda Accord EX-L V6 AT Sapphire Blue
Old 10-19-2009, 12:23 PM
LFSoccer2k6's Avatar
LFSoccer2k6 LFSoccer2k6 is offline
2007 4DR EX-L V6 5AT
Send a message via AIM to LFSoccer2k6 Send a message via Skype™ to LFSoccer2k6
I just had a B1 minder. Is there a place on this for or somewhere that lists what each minder code means? Thanks.
2007 NHBP EX-L V6 Sedan 5AT
CarDomain: http://www.cardomain.com/ride/3237223
DIY Documents: http://www.driveaccord.net/forums/sh...ad.php?t=40150
Old 10-19-2009, 12:24 PM
flippco's Avatar
4th Gear
Ownerlink is the place to go.
Old 10-19-2009, 01:43 PM
6th Gear
I just realized that I have an ownerlink account already... Im checking it now...
on a sidenote, I think Im doing the oil change myself... Should I switch to synthetic (car only has 25,000 miles), or should I just go dino?
+ Desert Mist
= Sexy
Old 10-19-2009, 02:57 PM
VTAKKKK
Really depends how often you want to change your oil. I'm currently on Valvoline Full Synth to give it a shot, but probably going back to dino after this change, don't feel a difference.
Old 10-19-2009, 03:07 PM
searich07's Avatar
searich07 searich07 is offline
Out of Control
Maintenance Minder says 15%
FollowingNFront:
“just bought the car 3 months (5,000) miles ago... When they certified it, didnt they rotate the tires, adjust my brakes, change my oil, and my cabin filter?”
Answer is that “they should have”, but your Maintenance Minder is telling us something very different that you are on 15%. So exactly what did they do to certify your car? Just slap a certification sticker on your car? Or? Regards
Richard
'09 Accord Coupe Ex L-Nav (190hp) I4
- Alabaster Silver Metallic/ Zaino finish / Black Leather Interior
-Weathertech trunk, front
-3M clear bra, pillars, roof, rear deck
OEM:
- side molding
- fog lamps
- Auto dim mirror
HONDA Accords:
'99 Sedan EXL V6
76 K miles - 6th Gen (97-02) 3.0L V6 SOHC VTEC (200 hp)
'92 Coupe I4
127 K miles – 4th Gen (90-93) 1992 facelift I4 2.2L (125 hp)
'85 Sedan LX 4dr I4
98 K miles – 2nd Gen (82-85) 1985 refresh i4 1.8L (86 hp)
Old 10-19-2009, 03:28 PM
6th Gear
Originally Posted by searich07 View Post
FollowingNFront:
Richard
Doesnt the maintenance minder just go off of miles when it comes to the "A,B,1,2,3,4,5" codes?
How does the car KNOW that my tires have to be rotated if its not going by the mileage????
(Just fyi, when I bought the car the maintenance minder % was 100%)
+ Desert Mist
= Sexy
Old 10-19-2009, 03:37 PM
VTAKKKK
Minder goes by miles for everything other than oil I believe. For oil it takes into consideration cold starts, hard driving, etc. You can reset the maintenance minder yourself, its in the manual.
For certification, its a big checklist, but they fly through it, certification is moreso for the 100k warranty on powertrain than anything else.
Old 10-19-2009, 03:54 PM
briansays briansays is offline
is the B1 code different from B12? i got the B1 code, i thought THAT was the one to tell you to get your oil changed..
Title goes here
close
video goes here
