What is the Factory Rear Brake pad thickness? - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 11-03-2009, 05:22 PM
Signal9's Avatar
Signal9 Signal9 is offline
4th Gear
I did search and I did advance search and I also used keyword and tag search.
Keywords = brake, pad , rear thickness
Searched only in 8th Gen forum.
I read first dozen posts and some people say their rear pads are at 8mm. Coupe owner.
I have a 09 Sedan and had my B1 service today. oil and tire rotation.
Front brake pads = 10mm ( as new the tech said)
Rear brake pads = 6 mm ( he said the rears are not 10 mm, but start off at 7mm)
I want to validate what he said because of some posts that I have read indicate a higher value for the rears.
My car has 8700 miles on it.
I did mentioned the brake noise and when I drove home, the noise wasn't as loud as before.
09 EX-L Sedan, Taffeta White 4 banger Auto.
28.25 MPG Average
Old 11-03-2009, 05:33 PM
MJCfromCT MJCfromCT is offline
3rd Gear
Front (NISSIN type):
Standard: 10.5 to 11.2mm
Service Limit: 1.6mm
Front (AKEBONO type):
Standard: 10.5 to 10.8mm
Rear:
Standard: 8.3 to 9.0mm
Service Limit: 1.0mm
Source: 2008 Accord Factory Service Manual
2008 EX-L Coupe V6 5AT w/Navigation - Belize Blue Pearl
Old 11-03-2009, 07:52 PM
Signal9's Avatar
4th Gear
Thanks MJC!
So. just under 9k miles and 2mm from pad gone if we round up high on the thickness scale.
so 18k = another 2mm loss.. 5mm
27k = 3mm
but i doubt the pads will wear down that way. Less mass, more heat. probably quicker wear.
Any brake pad specialist here?
28.25 MPG Average
Old 01-04-2010, 02:56 PM
3rd Gear
One update I wanted to provide to this, if anyone searches for this thread in the future:
Old 01-04-2010, 04:19 PM
aeoporta aeoporta is offline
moooo
added to the mini 8th gen help guide
http://www.driveaccord.net/forums/sh...ad.php?t=41153
Old 09-08-2010, 07:11 PM
ericdurb ericdurb is offline
I have a new set of the rear pads (ending in A40) and a new front pad set (ending in A60) and I put the digital calipers on them and the rear pads are 9.0mm thick and the fronts are 10.9mm thick factory new. I just measured the pad part (not the backing).
Old 09-08-2010, 07:39 PM
Danielc409's Avatar
Danielc409 Danielc409 is offline
Sugar coating for you ..
Your only 10 months late but I'm sure he'd thank you for it.
2011 Subaru STi - Stage 2 - Plasma Blue Pearl
My member journal / build thread @ IWSTI
2008 Honda Accord Coupe V-6 EX-L AT NBP
No longer owned
Old 09-08-2010, 08:48 PM
Signal9's Avatar
4th Gear
I should have measure the new pads myself when I changed them out for the new redesigned one as well a few months ago.
28.25 MPG Average
Old 09-16-2010, 08:24 PM
curlyhair curlyhair is offline
Is having 3.2mm left on the rear brake is unacceptable for a 1 year old car with 12k miles?
Because I just got home from the dealer for the first B1 service and was told that my brake has 8mm left on the front and 3.2mm left on the rear. I asked the service guy about how many more miles can my rear brake last and he told me that is vary but I can last about 20k-30k more miles. Was he just telling me BS?
2009 EXL V6 SEDAN
Alabaster Silver Metallic/ Black Leather
Mods:
20% tilt all around
35W 6000K HID Retro Solution
35W 6000k HID Fog DDM Tunning
Splash Guards
CCFL trunk light
Diode Dynamic Stage 2 LED interior
TSX swaybar
Odyssey lower grill
Future mods:
Old 09-17-2010, 10:53 AM
jmagl jmagl is offline
I was told by the service rep it was 9mm for the rears. Have an '08 EX-L rear pads were replaced at 20K miles (Nov'09). Just had a 1B service last week pads were down to 4mm after 12K miles. Was told that the dealer did not replace with the updated pads in Nov and they will replace these under warranty when it gets down to 2mm. Oh the fronts are still ok.
jmagl
'08 Accord EX-L Auto
Old 09-17-2010, 09:13 PM
09 ACCORD COUPE's Avatar
09 ACCORD COUPE 09 ACCORD COUPE is offline
09ACCORDCOUPE
09 Accord Coupe BBP/BLK Leather EX-L V6 6MT Navi
05 Acura TL NBP/BLK Leather 5AT Navi
FIRST CAR- 1971 BMW 2000, IN 1982
Old 09-20-2010, 02:56 PM
If you have 3.2mm left with 12K of mileage, then you probably won't get another 6K out of them. They are 9.0mm brand new and the service limit is 1.0mm, so that leaves 8.0mm to use up. You've used 4.8mm in 12K, so 3.2 left leaves you with 2.2mm of actual pad to use before they need to be replaced. That's approximately 5-6K of miles left on them.
Old 10-06-2012, 11:31 PM
nochamars's Avatar
nochamars nochamars is offline
4th Gear
I honestly have not experienced any brake problem in my 09 sedan since I bought it. Haven't even changed the brake pads yet. I'm at 20,000 no problems yet...
Sent from my iPhone using AG Free
*2009 Honda Accord Ex - Sedan
*Taffeta White
*8000k HID
*PUTCO LED lightning
*Infinity Kappa 692.9i Speakers/4 Channel Amp
*Audio Control LC7i
*JL Audio W6 on the way soon.......
More mods to come when life gets back on track....
Old 10-08-2012, 04:41 AM
Mechanic Mechanic is offline
5th Gear
nocharmars, if I were you, I'd remove a rear wheel and look at the brake pads to see if the prior owner upgraded to the last generation brake pads (A40s). If s/he did, you'll see a wire-spring clearly visable between the rear pads. If you don't see that, I recommend you buy a set of replacement pads (or your choice of aftermarket pads) and install them now.
What you're trying to avoid (obviously) is the backing plate on the old pads coming into contact with the rotors. You should hear the wear indicators first, but if for some reason you don't notice the sound, you could go from an incidental expense for brake pads to perhaps significant $ for brake rotors.
Title goes here
close
video goes here
