Crankshaft Position Sensor - Drive Accord Honda Forums
Old 11-14-2009, 12:08 PM
roadhog02 roadhog02 is offline
Hi! I'm a new memember and I am looking for infomation on how to test and replace the CPS on a 97 Accord EX with the 4 Cyl VTEC motor. I did a search and did not find anything that would show me what I am looking for. Thank you for any help that you can give me.
Old 11-14-2009, 12:23 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
What issue are you having that's leading you to look at the CKP? (crank sensor)
How many miles are on your car?
Old 11-14-2009, 05:25 PM
I have just over 200,000 miles on my car. When the check engine light came on I read the code on my testor and it came up with Crankshaft Sensor "A" as the error for the check engine light.
Old 11-14-2009, 09:09 PM
Calamity Coyote's Avatar
Calamity Coyote Calamity Coyote is offline
Texas Ground Pounder
I've had the CPS go bad on my Ranger before. Got the engine code like you and when I took the sensor off, I found that the plastic parts had broken off and caused damaged to the shaft as well. Ended up having to replace the shaft as well as the sensor.
2003 Accord EX Sedan V6 Auto NAVI (Noble Green Pearl)
Mods:Fog Lights-front & rear TL sway bar-V6 MT shock tower bar-AEM V2-Magnaflow cat-back-Window & Moon visors-Kaminari Lip Kit-clear bra-Bug Shield-CUSCO Type II TSX Lower brace-Enkei EVO5 wheels
Audio/Video:audio under construction-KP window up, one touch moonroof, mirror tilt-Dice iPod-Rear Camera-TVandNav2go Video
Wish List:Air Ride-Charger
Old 11-15-2009, 09:36 AM
Fredsvt's Avatar
Moderator
Can you post which code number. There are 4 sensors, 3 in the distributor and the one at the lower timing belt sprocket that can be called that.
There's a CYP, (cylinder position), TDC (top dead center), CKP (crank position), CMP (camshaft position).
Usually the car will continue to run with the one by the timing belt not working on older cars as it was just used for misfire diagnosis. The 3 in the distributor are the ones that are very important for running.
Old 11-15-2009, 11:32 AM
The test equipment that I am using (Autoscanner by Actron) just says "Crankshaft Position Sensor A". It doesn't diplay a numerical code. Mu assumption would be that it is refering to the one at the crankshaft then.
Is there any way to test the sensor with an ohm meter?
Old 11-15-2009, 01:27 PM
Fredsvt's Avatar
Moderator
A test with an ohm meter may or may not show a problem with it.
The sensor can have the correct resistance but still not output the proper signal to the PCM. Make sure the wires leading to the sensor are in tact, undamaged and not soaked with oil or anything contaminating the plug that goes down to that sensor.
Without the code, I can't tell you which sensor to check.
If it was one in the distributor, you can't replace any of them, you have to replace the entire distributor body.
Old 11-15-2009, 03:14 PM
Thank you for the information. I'll cean it up because it is coated in oil and dirt and see what happens. This would be un unlikely fix for me though, I don't have that kind of luck!
Old 11-15-2009, 05:14 PM
Fredsvt's Avatar
Moderator
Carefully check the wires for soft spots and any places the insulation may have been damaged by the oil. If there's oil IN the connector for the sensor (outside the timing cover) clean it really well, there can be issues from that.
There should be a foil type metal shield around the wires, if it contacts any copper in the wires, the sensor will be dead for all intents and purposes.
