After K&N Hi-flow air filter install, stall at idle - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Factory Facts > 2006 Honda Accord Instructions
Old 11-19-2009, 08:55 AM
Vic Vic is offline
Send a message via MSN to Vic
Yesterday I banged up my hands pretty well installing a new K&N Hi Flow Air Filter and a standard cabin air filter. I was surprised to find that none of these procedures were in the owner's manual at all.
I managed to figure it out and get the new filter on. I'm noticing more power like I expected, but I'm also noticing that the engine now chugs occasionally at idle or when the auto-transmission shifts into a higher gear.
This morning my car acutally stalled on me after giving it some gas when a light turned from red to green.
Is there anything I could have messed up or not done properly on this?
-Vic
Old 11-19-2009, 09:04 AM
inspire08's Avatar
inspire08 inspire08 is offline
4th Gear
Check your sensor, hose, and other tube related by the airbox to where you have insatalled the KN filter. Loose maybe or disconnected. Do you have any error code or check engine light?
2009 DIAMOND PEARL WHITE V6 EXL-3.5VCM
LS430/TSX LENS RETROFITTED HEADLIGHT
3M CLEAR BRA/3M TINT
1st-09 TSX SPLASHGUARD
09 TSX SWITHBLADE 2sets
09 TSX RSB 17mm
OEM SUNROOF DEFLECTOR
OEM BODY SIDE MOLDING
LED LIGHTS INTERIOR/EXTERIOR
INSPIRE TRUNK GARNISH CONVERSION
INSPIRE REAR SPOILER
CROSSTOUR LEATHER SHIFT KNOB
OEM COUPE WHEELS 18X8
Old 11-19-2009, 11:36 AM
Vic Vic is offline
no check engine light
I have a amaintenance light and B 12, but that was there before I installed and I've not yet cleared it out.
Old 11-19-2009, 01:37 PM
andysinnh's Avatar
andysinnh andysinnh is offline
Administrator
Send a message via AIM to andysinnh
It's real easy to dislodge a connnector or hose when you replace the air filter on these cars. And I"m guessing that you put a drop-in K&N filter and not a more major upgrade, right? So even though you're not throwing any codes - check to make sure everything is snug and tight - and make sure you look under the intake hose from the filter - there are some things on the side and underneath. Most folks who've changed the filter on these cars have had choice things to say about the experience....
A 3 "Honda" (and 1 "Ford" and 1 "BMW") Family in NH
12 Acura TL SH-AWD Tech Package (White, Wife's toy) 21k miles
13 Acura MDX SH-AWD Base (White, mine) 18k miles
14 Honda Accord LX Sedan (Black, Son#1's) 12k miles
04 Mazda Tribute LX 4WD (Black, Son #2's) 114k miles
08 Mini Cooper Hatch (White, Son #3's) 122k miles
Old 11-20-2009, 06:21 AM
Vic Vic is offline
got it
Last night, driving home, I noticed I did have the check engine light on. Stopped for a fill up and examined the hoses again. Sure eneough there was a smaller hose coming off the main one out the back which had come off. Put it back on and have no stalls or chugging.
I'm grateful the filter I put in will last a long time as this is not a task I'd want to repeat very often!
Old 11-20-2009, 06:27 AM
aeoporta aeoporta is offline
moooo
boy do i feel your pain vic, was changing the filter in my mini, just a simple drop in k&n, and all the clips that hold the airbox on just fell apart can you say cheap crap, needless to say a new airbox for a mini is 180 a new k/n cai was only 175. I cursed out the mini dealer then ordered the k&n cai. what should i expect anyways a screw for this car cost 10 bucks.
Old 11-20-2009, 07:16 AM
andysinnh's Avatar
Administrator
Glad to hear that you got it fixed - been there, done that in replacing the filter.
Now, just because you have a K&N in there doesn't mean you can ignore it. You need to take it out and clean and reoil it in a similar frequency to when you'd replace a normal air filter. The advantage of the K&N is that you can reuse it for the life of the car - but it still needs to be removed, cleaned and reoiled with the kit you can get from K&N. So, unfortunately, you will have to go thru this process again. But the suggestion others have when replacing the filter is to remove the air intake hose from the intake box - there should be a clamp around it - and this way you can just remove the lid to the airbox and not risk dislodging of hoses, etc. It's a bit of work to get that intake hose off, but in the end, it's less disruptive.
andy
Old 11-20-2009, 11:42 AM
Vic Vic is offline
True enough,
Thanks!
Tags
accord 06 intake diy, k&n hi-flow air filter
Title goes here
close
video goes here
