Gentex GNTX-177 AutoDim Mirror - Drive Accord Honda Forums
Old 12-08-2009, 11:12 AM
Nick986 Nick986 is offline
Top Gear is awesome
Picked up a GNTX-177 Auto Dim mirror w/compass and temperature and both harnesses (power/ground and temp + probe) for $5 @ Pull-A-Part
Christmas present for my sister since she is driving the 2000 Accord EX-VL. Wired one of these up in my Taurus and tapped into the moonroof power wire.
Any suggestions as to wiring this up in the Accord? Can I plug this into a perticular slot in the fuse box or is it better to tap into a keyed power source?
Going to go search for threads about grommets in firewall so I can pass the temp wiring through.
Have a camlock adapter in the mail from eBay.
Thanks!
--Nick
My car: 2000 Ford Taurus SEL (DOHC V6)-134K
Sister's car: 2000 Honda Accord EX-VL (V6!)-117K
Old 12-08-2009, 11:26 AM
sodaks2k sodaks2k is offline
Moderator
What does the "V" stand for?
2014 MSM Accord Sport Sedan 6M
Old 12-08-2009, 02:56 PM
Top Gear is awesome
When my parents bought the car new, the dealer classified it on internal paperwork as a EX-VL (V for V6, L for leather). Not sure if that's widely used Accord lingo though?
--Nick
Old 12-08-2009, 07:14 PM
Bruce Hawkins's Avatar
Bruce Hawkins Bruce Hawkins is offline
AC6DN
Dos that have the std windshield clip (how it mounted to the glass)?
Id mount the senor in the finder near the door. The problem is direct sun is bad, radiant heat from the ground is bad, Heat soak from the car is bad, under the hood is bad, any ware has problems. I purchased an aftermarket in/outside temp gauge for my truck and the only place that I could think of, was near the door and inside of the finder...
Bruce - AC6DN:
Honda Accord, 2001, 2.3L (L4), F23A4, 4D EX - My main carů
Ford Taurus, 1992, 3.8L V6, - Trany prob's
Toyota 4x4 Extra Cab Truck, 2.4L SR5, 22RTE (Turbo) 1987, I still have.
Honda Accord, 1984, 1800cc? L4,
Plymouth Arrow, 1978?, 1800cc?, L4 (POS)
Chevy, Monza, 1976, 350cu, V8, My funnest car, think muscle car, poorly made...
Olds Starfire? 1975, 231cu odd fire, V6,
My first car, 1965 Chevy Impala 283cu V8, (I got during the mid 1980)
Old 12-08-2009, 08:45 PM
Top Gear is awesome
I have a camlock adapter in the mail from eBay so I can mount this wedge mount mirror on the windshield's current camlock.
I'm going to mount the sensor like it is on a lot of cars: in front of the radiator somewhere around the header panel. As long as the car is in motion it should give a fairly accurate reading.
I am more concerned about where to get power for it in the Accord?
--Nick
Old 12-09-2009, 09:40 AM
Moderator
Thanks for clarification. I've never heard it before, but that's doesn't mean much.
Old 12-09-2009, 02:13 PM
TooSixy TooSixy is offline
I'd tap into the moon roof power as you don't care for a unswitched source.
Old 12-09-2009, 03:05 PM
AC6DN
Will the sun visors clear it?
I'd pick door/window power as it on for wile longer, or till the key is out
Bruce - AC6DN:
Old 12-10-2009, 02:49 PM
Top Gear is awesome
Someone had a picture of a Gentex 177 mirror at some point on a Gen 6 Accord and it cleared them fine.
So either moonroof power or door/window power. Now to find wiring diagrams and where it's best to tap the wire.
Found a good thread with with a grommet to poke through under the brake master cylinder...unless there's a better one.
--Nick
Old 12-10-2009, 06:44 PM
AC6DN
Get a SM or even a Chiltions maybe good enough...
Bruce - AC6DN:
Old 12-14-2009, 07:55 AM
Top Gear is awesome
Good call! A Haynes or a Chilton's should have the information I need. Have one for the Taurus, but it doesn't beat the service manual DVDs put out by Ford. Those are the .
--Nick
Old 12-20-2009, 05:34 PM
Top Gear is awesome
The local part stores did not have the book in stock, drat. What color wire should I tap into for a keyed power source? Any ideas?
--Nick
Old 12-23-2009, 01:12 PM
Top Gear is awesome
So far I learned that the switch for the moonroof power: if you are using a test light, and have the car running, and probe each terminal, none will light up, however, 3 will, when you ground them out, either open, close, or vent the moonroof. Now thinking about tapping the cruise control switch as it's a keyed power source.
--Nick
Old 12-26-2009, 04:26 AM
jeffhall009 jeffhall009 is offline
banned
Hey thanks for posting here all the suggestion. I was looking for them from a long time.
Old 12-26-2009, 06:41 AM
Top Gear is awesome
Ended up looking at the owners manual...decided to tap the power point wire since it and the radio were on the same fuse, and if it were to blow, the car wouldn't be rendered useless. Used the factory grommet as described in a thread on here to run temp sensor wiring, and grounded the mirror out under the dash. So for the pix...
(thumbnails, click for larger)
Tapped the White/Red wire for the power point
Passed the temp sensor wiring through this grommet under the dash.
There's the other end sticking out.
Voila, temp/compass mirror that cost $5 Just need to grab a wire cover from the junkyard (forgot it) to complete this.
--Nick
Tags
gentex, mirror
