Hi gang. Just a heads up. I always check oil on my vehicles stone cold, by just pulling up the dipstick, reading it, and putting it back. Well, the one on my coupe always shows full, when IT'S NOT!!!
You need to wipe it clean, then reinsert it. Most people do that anyway, but I figured why waste a shop towel just for that :lmao:. Anyway, my other vehicles always read right (including the CR-V) because dipstick is smooth, but that method doesn't work with the 'rough' dipsticks, like my coupe, as oil doesn't flow down, even after an extended period of time (especially in winter).
The bad news is my V6 is drinking oil, just like the CR-V :bawl:. The good news is it's not bad (but still sucks) at about 1/8-qt every 1K miles, just like our CR-V. I use the car mostly on highway. The CR-V doesn't consume any oil on trips, but my coupe runs at higher rpms. I know cars tend to burn a bit of oil if run hard, but I never run my coupe hard at all, other than high-rpm on the highway, which I don't consider hard, but might be for oil consumption purposes. At any rate, it's pretty normal nowadays, so no worries, but check your oil regularly folks (the right way :yes
. None of my many new cars of the past ever consumed oil. Guess tolerances are not the same anymore; a sign of cost-cutting times, maybe. Good day gang.
