Lowbeam Headlight Relay location - Drive Accord Honda Forums
Old 12-12-2009, 02:06 PM
jfugazzi jfugazzi is offline
Does anyone know where the lowbeam headlight relay is located on a 2005 Accord V6? Both lowbeam headlights stopped working last night. Tested today and i'm not getting any power at the light sockets or at the headlight fuse sockets. Highbeams work fine. The schematic in the Haynes manual shows a low beam relay which I suspect is the problem but I can't locate where it is.
Thanks
Joe Fugazzi
Old 12-14-2009, 07:14 PM
cbalach22 cbalach22 is offline
My First Post
I had a similar problem where my passenger headlight went out...replaced the bulb, new bulb didn't work either.
After jiggling the wire a bit, I got the light to work (with the original bulb) and somehow I haven't had a problem since.
I found this post...though I didn't download the PDFs so I'm not sure if it'll be helpful.
Also, try searching Google for an image of the WIRING HARNESS.
