My engine is drinking oil??? - Drive Accord Honda Forums
Old 12-18-2009, 06:45 PM
curlyhair curlyhair is offline
Unhappy My engine is drinking oil???
I was shock when I checked my engine oil after washing my car this afternoon. The oil level is way below the lower mark (It is about half way between the lower mark and the end of the dipstick). I tried to check the oil level several times but the results came out the same (I did insert the dipstick all the way back into its hole)
Is my engine burning oil? And what should I do now? Bring it to the dealer and have them check it out tomorrow? Or change my oil? Or just add some more oil and wait until the MM Service comes on?
Right now my MM shows the oil life is 40% at 4800 miles. I haven't done anything since I bought my car in August 09, and I think the sticker on my car show that it was made some time in the end of 2008.
Any advice from you guy would highly appreciated
2009 EXL V6 SEDAN
Alabaster Silver Metallic/ Black Leather
Mods:
20% tilt all around
35W 6000K HID Retro Solution
35W 6000k HID Fog DDM Tunning
Splash Guards
CCFL trunk light
Diode Dynamic Stage 2 LED interior
TSX swaybar
Odyssey lower grill
Future mods:
Old 12-18-2009, 06:50 PM
Aceman196's Avatar
Aceman196 Aceman196 is offline
6th Gear
Do you change your oil yourself? If not maybe the car did not come with the right amount of oil.
07 Accord EX-L V6 6spd(TSB)
Night Hawk Black
25% Tint all round
2 Door
USA-SPEC PA15 HON2
Old 12-18-2009, 07:19 PM
No. This is still the original oil that came with the car. I remember last time when I checked it (about one and half month ago), it was full. (But that time, I just pull the dipstick out and checked the oil level, did not clean the dipstick end and re-check it). So I don't know I was really full that time
2009 EXL V6 SEDAN
Mods:
20% tilt all around
Splash Guards
CCFL trunk light
TSX swaybar
Odyssey lower grill
Future mods:
Old 12-18-2009, 07:26 PM
searich07's Avatar
searich07 searich07 is offline
Out of Control
curlyhair, hello from Redmond. How many miles do you have on your ride? Regards
Richard
'09 Accord Coupe Ex L-Nav (190hp) I4
- Alabaster Silver Metallic/ Zaino finish / Black Leather Interior
-Weathertech trunk, front
-3M clear bra, pillars, roof, rear deck
OEM:
- side molding
- fog lamps
- Auto dim mirror
HONDA Accords:
'99 Sedan EXL V6
76 K miles - 6th Gen (97-02) 3.0L V6 SOHC VTEC (200 hp)
'92 Coupe I4
127 K miles – 4th Gen (90-93) 1992 facelift I4 2.2L (125 hp)
'85 Sedan LX 4dr I4
98 K miles – 2nd Gen (82-85) 1985 refresh i4 1.8L (86 hp)
Old 12-18-2009, 07:30 PM
I have only 4800 miles on my car. Thanks for your helpings
2009 EXL V6 SEDAN
Mods:
20% tilt all around
Splash Guards
CCFL trunk light
TSX swaybar
Odyssey lower grill
Future mods:
Old 12-18-2009, 07:38 PM
Rattmann Rattmann is offline
5th Gear
you should add some to proper level and observe it. Check if oil coming out the rear end
Old 12-18-2009, 07:48 PM
And one more thing I noticed from my car is when it is cold outside, there is a lot of white smoke come out the end pipe even after the car reaches its normal temperature (even after driving for miles). Is that normal?
2009 EXL V6 SEDAN
Mods:
20% tilt all around
Splash Guards
CCFL trunk light
TSX swaybar
Odyssey lower grill
Future mods:
Old 12-18-2009, 08:18 PM
CYANiDE CYANiDE is offline
VTAKKKK
Send a message via AIM to CYANiDE
Was your car off for at least 10 minutes and on level ground?
2006 Accord EX i4 Sedan - 5AT - Graphite Pearl - [89,0xx miles]
FF Type II Coilovers || Skunk2 Front Camber Arms || Ingalls Rear Camber Kit || Acura TL-S 27mm Front/20mm Rear Sway Bars || K&N SRI
Old 12-18-2009, 08:47 PM
I parked my car for more than 5 hours before I checked the oil level. (It is level)
2009 EXL V6 SEDAN
Mods:
20% tilt all around
Splash Guards
CCFL trunk light
TSX swaybar
Odyssey lower grill
Future mods:
Old 12-18-2009, 08:49 PM
Honda247's Avatar
Honda247 Honda247 is offline
I snapped my G string....
Send a message via Yahoo to Honda247 Send a message via Skype™ to Honda247
There are several threads about this issue. My car burns oil as well. I think it burns 1qt every 1k miles. My car has 63k and it still burns oil. I just make sure to check it every week.
2009 Civic EX TW
K&N Drop in Filter (33-2342)
Eibach SportLines (4.3140)
Apexcone Raptor V2 35W 5000K HIDs (9006)
Nokyas Hyper Yellow Stage1 2500k High/DRL (9005)
Nokyas Hyper Yellow Stage1 2500k Fogs (H11)
Painted Engine Cover
FRANCI5
Cardomain
Facebook Profile
Youtube
Old 12-18-2009, 08:57 PM
So what do you guys think what I should do now? Add some more oil or bring it to the dealer?
2009 EXL V6 SEDAN
Mods:
20% tilt all around
Splash Guards
CCFL trunk light
TSX swaybar
Odyssey lower grill
Future mods:
Old 12-18-2009, 08:59 PM
Honda247's Avatar
Just add a qt. You'll be fine. Just make sure its 5/20. Any brand will do.
2009 Civic EX TW
FRANCI5
Cardomain
Facebook Profile
Youtube
Old 12-18-2009, 09:15 PM
Thanks. I will buy a quart of 5-20 Honda oil to put in my engine tomorrow. But do you think is it normal? Should I talk to my dealer about it?
2009 EXL V6 SEDAN
Mods:
20% tilt all around
Splash Guards
CCFL trunk light
TSX swaybar
Odyssey lower grill
Future mods:
Old 12-18-2009, 09:39 PM
Honda247's Avatar
Its normal. I already talked to my service advisor and he said that its normal. I've learned to accept it. I'd rather spend the 2 to 3 dollars on a qt of oil that have my engine go out....
2009 Civic EX TW
FRANCI5
Cardomain
Facebook Profile
Youtube
Old 12-19-2009, 01:18 PM
aeoporta aeoporta is offline
moooo
i change my oil every 5k max, I use mobil 1 synthetic, cheap peace of mind. There is always some left over so i keep that on hand in case i have to top her off, walmart is your best friend well sometimes .
