Won't Start with One Key Sometime - Drive Accord Honda Forums
Old 12-28-2009, 08:22 PM
Flyboy's Avatar
Flyboy Flyboy is offline
Out of Control
Today I tried to start my car with the regular key and the green key light did not illuminate on the instrument cluster. I then went and got the valet key and when I tried to start the car the green light came on and the car started normally. After I reached my destination, and started home, I used the regular key and it worked just fine. How can the key, have an intermittent problem. The key is not powered by anything. What could cause this to happen. Could this mean that I may have a problem developing with the immobilizer system or the key?
I don't have any remote starter or other after market accessories on the car.
Thanks in advance.
2013 Accord Coupe EX-L I4 San Marino Red
2000 Accord Coupe V
6
San Marino Red 170,000 miles and still counting!
2007 Fit Sport Silver 60,000 miles and going strong.
Previous Honda: 1994 Accord Wagon Red, 1988 Prelude White 5 speed manual, 1981 Accord 4 Door Ivory 5 speed manual
Previous Cars before Honda: 73 Mazda RX2 manual, 63 VW Bug manual, 63 Alfa Romeo 2600 Spyder manual, 70 Toyota Crown manual, 59 Vauxhall Victor manual (worst car ever produced, a pre Yugo, Yugo)
Old 12-29-2009, 06:07 AM
nehonda's Avatar
nehonda nehonda is offline
6th Gear
I believe you have a flaky transponder in your regular key causing the intermittent no start. The immobilizer unit sends power to the transponder in the key which then sends a coded signal back to the immobilizer. If it is a good key code the green light comes on for about 2 seconds then goes off. If it is an incorrect code the light continues to blink. If the light does not come on at all the ECM did not get any signal from the immobilizer (good or bad). There could be a loose connection between the immobilizer and the ECM, but that would be more random and not depend on which key you use.
Good Luck
2000 Accord SE I4 F23A1 Auto - Sold @174k miles & 10 years ownership
1998 Accord LX I4 F23A1 5 speed - sons DD in DC
1986 Accord LX Auto Totaled @137k miles
1983 Accord LX 5 spd My Second Accord traded in
1978 Accord LX 5 spd My First Accord sold @ 100k
Old 12-29-2009, 08:56 AM
Flyboy's Avatar
Out of Control
Thanks for your quick reply. I assume that the Honda Dealer can sell me a new key. I wonder how much that will cost?
Thanks
2000 Accord Coupe V
6
Old 12-29-2009, 10:35 AM
nfcrew54 nfcrew54 is offline
3rd Gear
ranges from 75-150 dollars. But I live in NYC... Everything here cost too much.
Old 12-29-2009, 11:04 AM
12153 12153 is offline
banned
Thanks
A replacement/spare "T5" key from my dealer cost me $18.77. They require strict (written) proof of ownership, as HMC really doesn't care to sell keys to thieves and/or those who have no legitimate business with your car.
Old 12-29-2009, 03:26 PM
Flyboy's Avatar
Out of Control
Hi Thanks for the advice. What a price range! From $18 to $150. Obviously, I would have to bring along the title to the car or the registration. As long as the other key works, unless it starts to get flakey, I will take a wait and see attitude.
2000 Accord Coupe V
6
Old 12-30-2009, 07:03 AM
sodaks2k sodaks2k is offline
Moderator
I believe the cost of the key is around $18, and then they (usually) charge you to program the key. The registration and an ID should be just fine.
2014 MSM Accord Sport Sedan 6M
Old 12-30-2009, 03:10 PM
cajun's Avatar
cajun cajun is offline
Out of Control
A used Accord I was looking at last year only had one key. The local dealer told me it would be a little over $100 (total) for a new key + programming.
2010 PMM Accord LX-P, TSX rear sway, GG lower grille, 35% tint, 50K+
2006 Toyo Sienna LE, 100K+
2002 Accord SE (sold), TL rear sway and upper strut bars
Old 06-03-2010, 08:08 PM
Flyboy's Avatar
Out of Control
The problem with the key became more frequent so I took the car to the Honda dealer and they found what was causing the issue. The green key light would not illuminate when I turned on the ignition. After awhile it would work fine. All three keys had the same problem so I deduced it wasn't the key transponder. The dealer discovered a crack in a solder joint in the PC board on the main power relay. They replaced the relay and it works fine. I would have never guessed this was the problem. I hope this will help someone else.
2000 Accord Coupe V
6
Old 06-04-2010, 12:58 PM
Bruce Hawkins's Avatar
Bruce Hawkins Bruce Hawkins is offline
AC6DN
I almost want to go find the main relay, and re-flow the solder, just because. This relay is located where (passengers fuse box)?
Bruce - AC6DN:
Honda Accord, 2001, 2.3L (L4), F23A4, 4D EX - My main carů
Ford Taurus, 1992, 3.8L V6, - Trany prob's
Toyota 4x4 Extra Cab Truck, 2.4L SR5, 22RTE (Turbo) 1987, I still have.
Honda Accord, 1984, 1800cc? L4,
Plymouth Arrow, 1978?, 1800cc?, L4 (POS)
Chevy, Monza, 1976, 350cu, V8, My funnest car, think muscle car, poorly made...
Olds Starfire? 1975, 231cu odd fire, V6,
My first car, 1965 Chevy Impala 283cu V8, (I got during the mid 1980)
Old 06-04-2010, 05:24 PM
nehonda's Avatar
6th Gear
According to the Accord service manual the PGM-FI main relay is located under the dash and above the steering column separate from the fuse panels. I have not looked for mine, but it sounds rather difficlult to get to.
Old 06-07-2010, 04:33 AM
Flyboy's Avatar
Out of Control
If I remember the service writer showed me the relay and I think the crack was in the PC board itself at a solder joint. The part was only about $75 dollars.
2000 Accord Coupe V
6
Title goes here
close
video goes here
