Thumping when accelerating and turning... - Drive Accord Honda Forums
Old 01-05-2010, 04:29 AM
Trip's Avatar
Trip Trip is offline
This isn't a Honda but I thought some of the problem solvers might have an idea...
A friend has a '99 Camry V6. The car has been well maintained (he's the original owner).
Over the last few months, there's a weird thumping/bumping noise coming from somewhere in front of the driver - maybe right on the other side of the firewall.
It only happens in one situation and can be reproduce at will. Accelerate, turn left, and if you quickly lift of the gas you hear and slight feel the thump/bump. Doesn't happen when braking or accelerating in a straight line.
I'm thinking - turning vehicle, body is flexing, something is secured as tightly as it should be. Maybe a rear engine mount or an exhaust hanger? Because it only happens when turning, I thought maybe CV joint or suspension component but there's non of the typical CV joint clicking and the boot isn't leaking. Maybe a loose strut mount?
Otherwise, the car drives fine - solid, steering is OK (for a 10 year old Camry ), no vibrations or anything else quirky.
Two mechanics and a Toyota dealer can't figure it out.
Any thoughts?
Current: 2009 Mazda 6 iGT 6MT, 1989 Prelude Si 5MT
Come & Gone: 84 Accord HB, 91 CRX Si, 89 Accord LXi, 90 Accord LX Cpe, 94 Accord EX, 95 Accord EX Cpe, 98 Accord EX, 99 A4, 03 Accord EX-L, 91 Civic RT4WD Wagon, 06 Accord EX-L NAVI
From The Dark Period: 01.5 Passat, 08 Accord 6-6
DA MOD TEAM
Old 01-05-2010, 07:19 AM
SatinSilver's Avatar
Moderator
Just a WAG but perhaps the tires are cupped. Esp if the tires were recently rotated. I had a similiar thing happen on the 99 Accord with Firestone Affinity tires. The shop said it appeared one of the belts in the tires snapped. Maybe rotate the tires and see if the problem still persists. My problem happened all the time but maybe your friends is in the beginning stages.
Old 01-11-2010, 05:41 PM
ja-quan's Avatar
ja-quan ja-quan is offline
3rd Gear
+ 1 for checking the tires. Check the axles you could have a c/v joint failing. Check to see if the axle boots are torn. If they are then more than likely dirt has damaged the joint... Most of the time it is more cost effective to replace the axle then replaced just the boots even of the c/v joint is still good.
08 coupe EX-L V6 MT
hfp rims
magnaflow exhaust
H&R springs
SPC camber kit
takeda SRI
Title goes here
close
video goes here
