Starting Problems
Well its getting colder and colder up here in Canada
I've had the accord for about 3 months now and i found that today in the morning it would start untill the 4th try!!! if its been sitting for just a while say over an hour it will take maybe 2 tries! The first few attempts it seems like the battery is struggling as the lights and radio flicker a bit but then finally starts Should this really be happening on a brand new accord?, should i get it checked at the dealer?, it is kind of frustrating since even the 94 cutlass supreme can still start on the first crank in the coldest of days, so what do you guys/girls recommend i do?
09 Alabaster Silver Honda Accord EXL I4 w/o Navi 35% Tint On Front Windows, 5% Tint (Limo) on Rear Windows Vinyl Over Carpet In Entire Car Pioneer AVH-3300bt headunit 2 Alpine Type R Subs with Rockford Fosgate p1000-1bd amp |
| Sponsored Links | ||
Advertisement | ||
Batteries work very poorly in cold and hot weather. If any thing you may need a battery with a higher CCA or cold crank amp
07 Accord EX-L V6 6spd(TSB) Night Hawk Black 25% Tint all round 2 Door USA-SPEC PA15 HON2 |
Something to take in consideration is maybe to upgrade your I4 battery to the bigger v6 battery. Other things you could do is get a battery warmer (similar to a block heater), or to overall upgrade your battery. When searching for a new battery (dont skimp on it and get an everstart or something) look for OE or Optima and look for the 08+ accord but v6 in specs rather than the I4. I'd suggest a block heater but that could possibily mean that you'll have an ugly plug sticking out of your grill or hood or whereever you put it.
2008 cord 6-6 Taf White build thread: http://www.driveaccord.net/forums/sh...ad.php?t=42293 To Do: D2 coilover installed Megan racing camber kit Installed HID 6000K lowbeam installed Takeda SRI, installed 2-12" Rockford Fosgate T1's wired at 4 ohms CHECK! Eclipse za1200x AMP wired at 4 ohms- 1000 RMS CHECK Nokya Yellow fogs. rv6 v3 ichiba spacers 20f-25r |
This would be my first thought. My battery is only 400 or 500 CCA in my Accord. My 97 Chrysler Concorde had an 850CCA which was great in these Iowa winters!
2006 Accord SE Sedan |
Read this, problem solved. Its stickied in the 8th gen section
http://www.driveaccord.net/forums/sh...ad.php?t=41153 |
I4 starters **** to begin with, and a weak battery in freezing temperatures doesn't help either. So yes, a bigger battery would be nice, but this simple tip might be enough for you: Let the ECU do its diagnostics (and the fuel pump prime) before you start cranking. Honda/Acuras are especially slow to recognize the key, so if you start cranking right after you insert the key, you'd be wasting 2 or 3 seconds of your starter and battery EVERY time you use the car.
Finally, if you don't use the car daily for at least 15 miles, you need to charge your battery regularly as well man, especially in winter. I'd try those 2 things before anchoring even more weight on your car with a heavier/larger battery. Hope this helps. |
alright thanks for all the replies everyone, atleast i got a brief idea of whats happening now before i was just really lost and clueless
I have not had any issues starting on , but I am in NY , LI and it doesn't get real cold ,20F is cold here
Ed 2008 Accord LX, Alabaster Silver Metallic gone 1985 XR4Ti gone 1974 Opel Manta rally |
Optima 35 battery
I switched to an Optima 35 battery before the D-cell battery honda puts in gave me any trouble. The optima really turns her over good even in the 15 degree F nights. The other thing that would help is changing the oil to a 0W-20, I used Mobil 1. Amazon has the batteries for $144, but shop around on the net and you can find one cheaper.
| Sponsored Links | |
Advertisement | |
