12v accessory not working... - Drive Accord Honda Forums
Old 01-08-2010, 11:42 AM
akelsall akelsall is offline
HardCoreHondaLover
I bought a Kobalt air compressor for the car and plugged it into both of the 12v outlets in the car. Nothing happened (I had the key turned to ACC and the radio was on). I verified the 15A ACC fuse was OK. So, I thought maybe a got a bum compressor. I went to Lowes and replaced it with an identical unit. Same problem. This is on a 2004 Honda Accord LX.
Has anyone else had issues getting output from the 12v acc outlet?
Thanks,
Andy
Old 01-08-2010, 11:51 AM
Aceman196's Avatar
Aceman196 Aceman196 is offline
6th Gear
did you try plugging anything else in the 12v to see if it worked like a a cell phone charger.
07 Accord EX-L V6 6spd(TSB)
Night Hawk Black
25% Tint all round
2 Door
USA-SPEC PA15 HON2
Old 01-08-2010, 01:37 PM
ypsibird's Avatar
ypsibird ypsibird is offline
6th Gear
That could be very good advice. I have a dustbuster type vacuum that doesn't work in my wife's 03 but works just fine in my 06. Of course at first I thought it was a fuse too. But a cell phone charger worked perfectly in her car. It seems some of the 7th gen ac outlets are a bit touchy. Or perhaps not all ac accessories are very well made. Andy - when you get a chance you might also want to put a little info in your signature to identify your car.
2006 Accord Coupe silver 6 speed
Old 01-11-2010, 05:47 AM
HardCoreHondaLover
Aceman, thanks for responding. I have an old air compressor (about 5 years old) that works on my other car, but doesn't work in this one. I have tried both of the 12V outlets in the car and neither appear to work. I find it hard to believe both have failed (unless there's some wiring in common).
Any other ideas?
Thanks,
Andy
Nothing but Honda since 1990! Currently own:
1995 Honda Accord LX (300,000 miles and still going!)
Old 01-11-2010, 07:00 AM
crackerteg's Avatar
crackerteg crackerteg is offline
Call me Z
Try pushing the plug a bit harder into the socket. I have that issue with my compressor but not the chargers. When I first discovered this, I thought the same and realized it when the plug looked like it wasn't fully seated.
The name is Z
2005 Satin Silver Metallic LX sedan k24 5MT
Tein SS-P with EDFC l J Power rear camber arms l TL-S 20mm RSB l
Custom bronze EVO X GSR 18 x 8.5 +38 wheels wrapped in Kumho Ecsta sized 235/40/18 l OEM V6 coupe exhaust minus resonators l
Custom "Icebox" intake l Custom polished shifter extension l Custom FX35 bixenon retro in black housings l OEM rep front lip l ebay fogs l
"If one day the speed kills me, do not cry because I was smiling." - Paul Walker
Old 01-11-2010, 07:05 AM
searich07's Avatar
searich07 searich07 is offline
Out of Control
Clean compressor elecrical contact points with alcohol, before insertion into 12V outlet, Regards
Richard
'09 Accord Coupe Ex L-Nav (190hp) I4
- Alabaster Silver Metallic/ Zaino finish / Black Leather Interior
-Weathertech trunk, front
-3M clear bra, pillars, roof, rear deck
OEM:
- side molding
- fog lamps
- Auto dim mirror
HONDA Accords:
'99 Sedan EXL V6
76 K miles - 6th Gen (97-02) 3.0L V6 SOHC VTEC (200 hp)
'92 Coupe I4
127 K miles 4th Gen (90-93) 1992 facelift I4 2.2L (125 hp)
'85 Sedan LX 4dr I4
98 K miles 2nd Gen (82-85) 1985 refresh i4 1.8L (86 hp)
Old 01-11-2010, 01:43 PM
ypsibird's Avatar
6th Gear
Any other ideas?
Thanks,
Andy
Andy, it wasn't clear from your response that you tried what Aceman suggested. If you didn't, do yourself a favor and follow his sugestion. There is a reasonable chance there's nothing wrong with your ac outlets. Maybe my previous post wasn't as clear as it could be. The ac outlets in both my wife's 03 and my 06 were fine. Yet the vacuum that works without any difficulty in my 06 will not work in her 03. It's not an issue of cleaning contacts or pushing it in harder. I tried. Everything else we tried in her 03 worked perfectly. I just went out into my garage with a flashlight and compared the outlets in our 2 Accords. They are obviously different. The barrel of the outlet in her 03 has 2 cut out areas where my 06 is solid. I'd guess they improved the outlets at some point and your 04 probably has the older style. Your situation might be the classic - If it ain't broke don't fix it.
Old 01-11-2010, 04:50 PM
Aceman196's Avatar
6th Gear
+1 point exactly
Night Hawk Black
25% Tint all round
2 Door
USA-SPEC PA15 HON2
Old 01-26-2010, 09:51 AM
HardCoreHondaLover
ypsibird, you were spot-on. I bought another type of air compressor at Target (I don't have the exact brand, but it was green and silver). THAT unit works fine. I find it very frustrating that there's in incompatibility with something as simple as a 12v outlet. How hard is it for Honda to standardize their outlets?!! Oh well, at least I have a working compressor now. Thanks to all who replied (and especially to ypsibird).
Andy
Old 08-03-2011, 03:19 AM
bnikanor's Avatar
bnikanor bnikanor is offline
4th Gear
in other thread, it said you have to push harder, they don't make the hole wide enough
'87 accord
'92 accord
'96 civic (current car)
'01 accord (current car)
'06 accord (current car)
always been a Honda family :)
