Thread Tools | Search this Thread |
Rating:
Display Modes |
#91
Dropping to lose the gap will still need a 3 bar camber system
Coils have nothing to do with it
'13 EX-L I4 COUPE STEEL/BLK Click here for pics New Accord? Click here for a good PDF detail procedure Other car: `13 Camaro 6.2L 2SS |
| Sponsored Links | ||
Advertisement | ||
#92
I got the i4 coupe...any input though really for best quality and adjustment for this car???
And I need the 3 peace camber kit...not just 1 peace.. Im also gonna add the stiffer Rear sway bar. Tein SS sound good but maybe overkill... |
#93
Spring options
I do not know what other springs are available for our cars (besides the Eibachs) but I don't think they will eliminate the gaps on my car. If the gaps get cut in half that would be a lot better then they are. Is there a standard computation to determine the point at which we have to upgrade from stock, or from the cheaper 1 bar adjustment to the more costly 3 piece camber adjustment set? Anything over 1" drop? 2" drop ... 3"???? Or let me give a specific example ... what would I have to use if I were to replace stock items with Koni shocks/struts and Eibach Pro lowering springs? Would I have to use the 3 pcs camber adjustment kit for this simple 1.4" drop?? If I definitely need it then I'll get it, as I don't want to wear out new tires, but if it is not necessary I'd like to put the $$$ elsewhere ... I just don't know what that drop point is where the full 3pcs set must be installed for correct adjustments.Thank you for your responses
Michael in MD 2009 EX-L V6 Sedan w/o navi -- 50% tint MS-8 running stock speakers / Eclipse 75w amp to stock sub / Custom [LOL] center channel in lower dash console |
#94
In general, a 1.5 drop will require a one piece camber rod.....anything more needs the 3 piece. But you have to ask yourself, why go cheap after spending all the monetary and time? A one piece gets it CLOSE to spec and not spot on...a 3 piece does.
Look at j power rods to save money. I'll never understsnd someone spending tons of money on wheels and susp then cheapening out on the underpinnings...like buying a new vette and putting on ford focus tires......go all in or go home.....
#95
Thanks Glen
I'm not trying to cheap out, just trying to determine what is needed for my minimum drop ... ... and mainly trying to find out if there are other performance spring options for my V6 sedan besides the Eibach Pro's Thanks again for your response
#96
Eibach Pro Kit, H&R Sport, Tanabe NF210, Tein H-tech / S-tech, Megan, D2, Ground Control, Ksport, eBay springs....
#97
Hey Thanks
![]() I'm assuming that the shock/spring option for our cars is not a popular one these days as most folks go with coilovers. Guess I should reconsider that a bit and look into their longevity & reliability. Thank again
#98
Coils are nothing more than a matched spring with a shock. The reason the springs don't work is because you're stressing the stock shock because it's not made for it, so therefore, inevitably it breaks.
#99
Now how about for those people that get snow ...maybe 4 months in the year lets say...salt too...or near a lake...
![]() Would coilovers be a waste of money then... |
#100
It'll cost you a alignment, but thats the beauty of coils, raise them for the winter! Can't do that with springs or HFP...
#101
I heard coilovers won't resist the winter/salt beatings. Adjusting the height every half year with alignment...what a tedious job yikes. (Living up north ****s...) I was told to just go with springs, if not going too low...and they should fair good with winter apparently... ![]() (Got excited about dishing out alota money for nothing lol) |
#102
1 . Put on springs and you will be buying shocks in a few years because you will blow the shocks , and then you will have double the labor to replace the shocks. 2.I have no idea why coil overs would be more susceptible to winter weather than the shocks that you now have. So now go do what you want?...
#103
1. Months, not years. If you are not at all interested in adjusting height, get the HFP setup. Don't get springs.
2009 EX-L V6 w/ Navi CBP 5AT - Body Side Molding - exLEDUSA Interior 5k LEDs - Brakemotiv Drilled/Slotted Rotors - 35% Tint - 6k HID Headlights - Debadged |
#104
Side-by-side of rusted and seized coilover and new coilover: ![]() Rusted coilovers: ![]() Even if aluminum components are anodized and steel components are painted/powder coated, it's still recommended that they be regularly cleaned/maintained. http://teinusa-blog.com/tein-damper-maintainence/ |
#105
I can appreciate the threads going to hell without boeshield T-9 or equiv, but does the coil itself break vs a std shock/strut in winter weather?
| Sponsored Links | |
Advertisement | |
| Tags |
| bc racing, buddy club, camber, coilovers, coils, eibach, faq, function & form, ground control, h&r, hfp, isc, koni, ksport, megan, spring, springs, tanabe, tein, toe |
