Tranny vibration when accelerating - Drive Accord Honda Forums
Old 01-22-2010, 09:57 AM
gp15857 gp15857 is offline
My gf's 2005 auto v6 accord has a vibration/rubbing feel in the acceleration from a complete stop. It occurs from approximately 2000-2400 rpms and goes away. It only happens from a stop in auto's 1st gear. I have noticed it since the 1st time driving the car. Odometer was 75k miles then and it currently has 105K. Gf is original owner and she never noticed it. Any experiences or suggestions? Thanx
Old 01-22-2010, 10:22 AM
Accordriver's Avatar
Accordriver Accordriver is offline
6th Gear
Just how hard are you accelerating? You might be feeling the traction control, did you notice the yellow triangle light up?
-03 Honda Accord EX V6
-Debadged-17mm sway bar-UR crank pulley-AEM CAI
Old 01-22-2010, 10:43 AM
ikethegreat's Avatar
ikethegreat ikethegreat is offline
Carpe Diem
How do you know it's actually coming from the tranny?
Old 01-22-2010, 12:27 PM
The vibration is felt whether I baby or mash on the pedal.
It could quite possibly not be the transmission. It is just a consistent feeling from 2000-2400 rpms.
Old 01-22-2010, 04:57 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
Ignore the rpm for a moment.
Do you feel this vibration from the instant you hit the accelerator to a certain road speed?
Does it feel more like a "wobble"?
If you put the car in park or neutral, and bring it to the revs you mentioned, can you feel it? Also, if in drive, and you use your left foot to hold the brake FIRMLY, and bring the revs to 2000, do you feel it? Don't do this for a long period of time.
Old 01-22-2010, 07:47 PM
Jeff's Avatar
Jeff Jeff is offline
4th Gear
Send a message via Skype™ to Jeff
I think it's just the engine shaking around. My car does this too. I haven't really worried about it a lot. I bet if you got high performance mounts, the engine wouldn't move at all.
2007 Honda Accord EX-L i4 Sedan
Old 01-22-2010, 08:07 PM
Fredsvt's Avatar
Moderator
High performance mounts would reduce engine movement, but also allow far more vibration to reach the passengers.
If the front mount is bad, it'll clunk once on acceleration as the engine lifts up.
The stock mounts don't let a whole lot of movement in normal driving.
On hard acceleration should the tires hop, then it can move a bit but the axle hop is so violent I think he'd feel that much more.
Old 01-22-2010, 09:14 PM
The vibration occurs on acceleration from roughly 8-12 mph and goes away. I take away that if I accelerate extremely softly/creeping, the vibration doesn't occur. I cannot replicate the vibration/rubbing sound in park/neutral/revving with foot on brake.
This is the first Honda I've driven so I didnt know if this was normal. Thanks for input.
Old 01-22-2010, 10:27 PM
jairomvp's Avatar
jairomvp jairomvp is offline
06 ACCORD
it sounds like a mount for sure, try this pop yur hood put the ebrake on,put it in gear without taking off, press the gas just a bit and see how bad the engine move back, if you see it move to much thats motor mounts if not well i have no idea but i hope it just a bad motor mount easy fix. good luck
If you win today,get ready for tomorrow!!!!!!!!
Old 01-22-2010, 11:58 PM
paperboy42190's Avatar
paperboy42190 paperboy42190 is offline
Out of Control
what about your tranny mounts? my tranny mounts were broken to hell and caused weird noises at times. after i replaced the mount, it was good again
2007 Acura TL Type-S
Old 01-23-2010, 05:57 AM
Fredsvt's Avatar
Moderator
Will it do it in gear, foot on brake at the rpm you mentioned?
Also, try putting it in D2 and accelerating away, do you feel it.
I'd be checking the axles. Sounds like you have an inner joint going bad. The 4 cylinder cars with the long right axle are known for having issues that cause a "wobble" like vibration, first only on initial take off, like what you feel. Then as they get worse, it happens any time you accelerate up to about 45-50 mph.
Old 01-23-2010, 08:16 AM
It doesn't sound like a "wobble". Closer to a rubbing or grinding without metal parts. I hear it and only feel it in the acceleration pedal. Not the steering wheel.
Ok, I cannot replicate it with the foot on the brake. It is the same in D3 and 1. In 2, the sound/feeling is much louder and lasts longer.
Are tranny mounts easy to detect when they are worn?
I'm just confused that this issue has not got worse. It has remained the same from 75-105K miles, just over 2 years.
Old 01-23-2010, 01:48 PM
Fredsvt's Avatar
Moderator
Is this sound loud enough to be made into an audio file to post?
Starting in second makes it worse, not good.
Since you're really not accelerating hard, I can't see it being mounts. Bad mounts, you'd feel the engine moving, noticeable clunk especially if the front mount is bad.
Have you or a shop done a trans drain and fill on this car anytime recently? I'd like to see what's on the drain plug magnet. What does the current fluid in the unit look like? Can you put the dipstick into bright sunlight to see if there's metal flakes in it?
Old 01-23-2010, 03:06 PM
RedAccordV6 RedAccordV6 is offline
79,125
If the fluid turns out dark brown with a burnt smell and there DOES appear to be metal flakes in the fluid like Fred suggested, I believe your second gear is toast. Especially since starting in second makes it worse...
2004 Accord EX-L V6 sedan 5AT
Hella HID's, 35% tint
17'' Fuzion HRi's
brembo blank rotors front/rear
Akebono pro-ceramic pads
Old 01-23-2010, 04:04 PM
Fredsvt's Avatar
Moderator
That car "shouldn't" have issues with 2nd in that way, but anything is possible. It should have the internal lube problem fixed.
If it has a jet kit, the trans is either used or rebuilt by someone at sometime incorrectly.
I'd really like to hear it, if it's audible to a microphone.
Title goes here
close
video goes here
