Squealing noise from engine - Drive Accord Honda Forums
Old 01-25-2010, 05:21 PM
abcrndm abcrndm is offline
i drove my car for the first time in a week today (notably it was cold and rained a lot during this time), and after a couple minutes of driving the car started squealing fairly loudly. and the squeal was the same no matter what speed i was driving at.
when i parked, i popped the hood and the noise was definitely coming from the engine, and appeared that it may have been coming from the belt right next to the engine (fan belt?).
what could this problem be? could there be any harm in continuing to drive the car? there is no check engine light on
thanks
2005 Accord EX-L V6 non-navi
Old 01-26-2010, 07:39 AM
jeffislouie jeffislouie is offline
No longer active
I get this from time to time when it is really cold or really wet. I spoke to the Honda tech about it at my last oil change and he said it is just the belt reacting to very cold or wet conditions. Other than being annoying, it shouldn't cause problems. If it does it all the time, the belt should be replaced.
When this happens to me now, shutting off the car after it has warmed up and restarted often clears the problem for some reason.
Since I can't figure out how to cancel my account, this serves as notice that the above user is no longer an active member of this community.
No messages will be checked. No responses will be given.
Frankly, even though this forum has a lot of very nice people, the few bad apples around here have gotten on my nerves. I simply don't care enough to log on and try and help others when all too frequently, I get mocked or made fun of.
Old 01-26-2010, 09:03 AM
Lowaccord66 Lowaccord66 is offline
Go check your serp belts for dryness and look for cracks on the underside of the belt. You can use belt conditioner if the belt is dry and in good shape however its a temp fix and that belt is cheap and easy to change.
Old 01-26-2010, 09:29 AM
thanks to both of you.
this was probably the issue, since with no rain today, there was no problem.
Old 01-26-2010, 09:41 AM
hillstones hillstones is offline
Sold the Accord
Did the noise increase when you turned the steering wheel in either direction, and then it goes away after the car warms up? If so, air could be getting into the power steering system and the fix is to replace the o-ring on the hose going into the power steering pump. There is a TSB on it explaining the procedure.
