adjusting coils - Drive Accord Honda Forums
Old 02-04-2010, 07:52 AM
MyVtecRoars's Avatar
MyVtecRoars MyVtecRoars is offline
3rd Gear
adjusting coils
how do you measure the height when you lower or raise the damper, to make it even all the way around O_o
Old 02-04-2010, 08:49 AM
MSchu's Avatar
MSchu MSchu is offline
Out of Control
that's not what coil adjustment is used for.
sure it enables ride height adjustments, but it's main focus is corner weighting. the end result if done correctly will almost always never yield a car that looks even all the way around from a visual standpoint, but from a stand point of weight distribution it will be as close as possible to evenly distributed.
peace
Schu
Old 02-04-2010, 09:03 AM
Throwdown's Avatar
Throwdown Throwdown is offline
FORUM SPONSOR
Send a message via AIM to Throwdown
Thanks Vixen for the email so I could get back on here:
PM'ing you as we speakk...
Old 02-04-2010, 09:19 AM
Vixen89 Vixen89 is offline
banned
I'd answer him but I don't have them myself or the experience..!
Old 02-04-2010, 09:22 AM
Throwdown's Avatar
FORUM SPONSOR
I Pm'd you, so assuming you are out in the garage.
On this page furple made a good drawing of the adjustment.
http://www.driveaccord.net/forums/sh...+seized&page=5
Let me know if you need ANYTHING else. Coilovers are a tweaking process, that I know can be annoying at first... but once they are set, they are set until you want to change it (after they are fully settled of course).
Old 02-04-2010, 09:25 AM
Domtenn15's Avatar
Domtenn15 Domtenn15 is offline
Vtec Pwr
Send a message via AIM to Domtenn15
peace
Schu
That was not his question, I think he meant to ask how you adjust the height of coilovers and at the same time make sure is the same all around...
I dont know the answer since i dont have coilovers yet, but I think is a very good question since I will be getting them soon.
My idea is that could be by rotating the coils left to lower, right to raise, but again I could be very wrong. And also as he asked, How do you make sure they are all set at the same height?
08 Accord Coupe 6-6
Albaster Silver
8k Hid headlights and fogs
Tinted Windows
Honda all weather floor mats
WeatherTech Dark windows visor
3m Roof Lip Spoiler
Takeda SRI
Magnaflow exhaust
Megan Racing Street Coilovers
SPC 3 arm Camber Kit + Front Ball joint
Megan SS Coilovers
15mm Rear Ichiba wheel spacers
Motevo Aftermarket GPS/DVD (love it)
Future mods
Wheels
Old 02-04-2010, 09:30 AM
09^CBP^6MT 09^CBP^6MT is offline
banned
Easy answer, you adjust the spring perches to change the ride height. Turn the bottom cup on the shock that the spring sits in to move the spring up or down, changing the ride height.
Old 02-04-2010, 09:38 AM
Domtenn15's Avatar
Vtec Pwr
Does it have different numbers or somehting like that, or how you know you have all of them set at the same height?
08 Accord Coupe 6-6
Albaster Silver
Tinted Windows
3m Roof Lip Spoiler
Takeda SRI
Magnaflow exhaust
Megan SS Coilovers
Future mods
Wheels
Old 02-04-2010, 09:40 AM
banned
Tape measure or corner scales. I have access to digital corner scales, but for a street car that is major over kill IMO. Just measure to the bottom of the fender.
Old 02-04-2010, 09:41 AM
Accordriver's Avatar
Accordriver Accordriver is offline
6th Gear
Depends on how persnickety you want to be. I would just get a ruler.
-03 Honda Accord EX V6
-Debadged-17mm sway bar-UR crank pulley-AEM CAI
Old 02-04-2010, 09:45 AM
Dennis's Avatar
Dennis Dennis is offline
banned
i have one of these got it from Home Depot for like 5 dollars
Old 02-04-2010, 09:48 AM
banned
Damn, you a bit anal....lol calipers,but it would work great. Harbor freight has them real cheap too.
Old 02-04-2010, 10:51 AM
mystick6 mystick6 is offline
banned
No bud. To lower or raise on KSport or Megans you must remove the bottom bolt or bolts that are attached to lower shock perch of your coiover and loosen the last collar which is the locks the shock down. Adjust the collar if you want to lower it then move the collar towards the other 2 collars that lock down the spring preload if you wish to raise em them move collar down towards the floor. Once you find where you want to the collar to be (which will be your height) screw in the shock body since its a threaded body you will be able to move it up or down towards the collar. Then lock the collar in place. DONE>
Old 02-04-2010, 10:56 AM
banned
To determine the height you want it at. This is what I do. After you install your coils. Measure distance between the center of the fender and the center of the bottom of your rims lip. For example if its 25" distance and you want to drop it 2 inches. You will need to bring the shock lock collar toward s bottom spring collar (theres 2 collars where the spring sits) 1 collar is what the spring rest on and the 2nd collar is what lock spring preload into place. 2" of thread. So measure from bottom spring lock collar 2" then place the shock lock collar where the 2" would be. Then adjust shock body to the collar and lock... I hope you understand this...
Old 02-04-2010, 01:39 PM
Phongvtboy's Avatar
Phongvtboy Phongvtboy is offline
5th Gear
For mine I just have to Losen the lock rings and spin the collar. I wouldn't suggest messin with the spring perches as they should be preloaded. Adjust the hight of the shock not the position of the spring IMO. My d2 manual also suggests not to adjust hight by spring perch but shock body collar.
2008 cord 6-6 Taf White
build thread: http://www.driveaccord.net/forums/sh...ad.php?t=42293
To Do:
D2 coilover installed
Megan racing camber kit Installed
HID 6000K lowbeam installed
Takeda SRI, installed
2-12" Rockford Fosgate T1's wired at 4 ohms CHECK!
Eclipse za1200x AMP wired at 4 ohms- 1000 RMS CHECK
Nokya Yellow fogs.
rv6 v3
ichiba spacers 20f-25r
