Does Accord 08 Auto come with OD? - Drive Accord Honda Forums
Old 02-10-2010, 09:54 PM
DriveAccord08's Avatar
DriveAccord08 DriveAccord08 is offline
banned
Exclamation Does Accord 08 Auto come with OD?
i just wonder accord 08+ have overdrive and where it is?
Old 02-10-2010, 10:16 PM
AznX TL's Avatar
AznX TL AznX TL is offline
need 6 speed!
Send a message via AIM to AznX TL
d4 is OD, d3 is OD off.
-08 Accord lx-s 5speed manual/ tafetta white
mods
|DDM tuning 6k hids|12" Alpine Type-R|TSX switchblade|Lip spoiler|Type-R Suede red stitch boot|Gunmetal Type-R knob|
|Intake Resonator Delete|Hyper White led license plate led|led interior bulbs|Smoked Reverse lights|
Previous owned
-97 Acura 2.2CL auto/Flamenco Black
Old 02-10-2010, 10:17 PM
argus's Avatar
argus argus is offline
5th Gear
Nope..
..I don't believe it has an O/D
edit : ^ ok so it has it..
'08 Honda Accord Coupe V6, AT, San Marino Red, black 'leather' interior/ HFP under spoilers (front-rear-sides)
Mods:
Voltage stabilizer kit, with additional ground wires
Bosch 35W-6000 HID kit for the low beams,
Magnaflow CFE # 16817
Nokia 500 Navigation unit
Intake resonator removed
11-row engine oil cooler with steel braided lines
11-row transmission oil cooler with Honda inline ATF filter
Old 02-10-2010, 10:27 PM
banned
where is d4?
Old 02-10-2010, 10:58 PM
MrLogan13's Avatar
MrLogan13 MrLogan13 is offline
4th Gear
Originally Posted by DriveAccord08 View Post
where is d4?
It's D.
Old 02-10-2010, 11:00 PM
argus's Avatar
5th Gear
The normal 'D' position
Mods:
Old 02-10-2010, 11:12 PM
nadram's Avatar
nadram nadram is offline
4th Gear
Yes it has overdrive in the regular D position
(called D5 cos it has 5 gears - there is no D4 - in D3 OD is off)
E.A.
2009 Accord EX-L V6 3.5
Mods: 30% black tints * White LED interior lighting * Maxguard protection * front bottom Odyssey grille* LED illuminated door sills * Ichiba spacers 25mm back 20mm front * Roof spoiler * HFP body kit * Intake manifold gasket
Care to sponsor me?: J-Pipe * HIDs * Coil-overs
Old 02-11-2010, 02:33 AM
TH23 TH23 is offline
4th Gear
Not having a D4 position on the shift-gate ticks me off. Not having SportShift ticks me off even more. The $18k Fit Sport has it, why can't the Accord?
Old 02-11-2010, 02:41 AM
argus's Avatar
5th Gear
^ That's nothing man.. the Fit this side of the world is called the Jazz, and has paddle shifters... so does the Civic...
Mods:
Old 02-11-2010, 02:49 AM
denniswolf denniswolf is offline
6th Gear
yeah same , we get them on the accord too.. i guess the benefit of not having Acura brand here.
'08 PMM v6 sedan:
Old 02-11-2010, 02:55 AM
Trip's Avatar
Trip Trip is offline
You would think the Accord would get some of those niceties. But IMO, it's too big to really be considered sporty and I'm sure Honda thinks the older demographic would not appreciate those features. Probably the same reason you can't get an EX-L with a 5MT anymore Apparently if you want a 2.4L, 5MT, and NAVI, u're screwed.
In regards to the transmission question, typically Honda ATs work something like this:
D1: Holds 1st
D2: Skips 1st, starts in 2nd (good for starting from a stand still on slippery surfaces)
D3: 1 - 2 - 3 but will not engage 4 or 5 (supposed to be used when in hilly area)
D4/D5: normal driving. OD kicks in on the highest gear available.
Current:
2009 Mazda 6 iGT 6MT
1989 Laguna Gold 5-sp Prelude Si
Come & Gone:
84 Accord HB, 91 CRX Si, 89 Accord LXi, 90 Accord LX Cpe, 94 Accord EX,95 Accord EX Cpe, 98 Accord EX,
03 Accord EX-L, 91 Civic RT4WD Wagon, 06 Accord EX-L NAVI
From The Dark Period:
99 A4, 01.5 Passat, 08 Accord 6-6
DA MOD TEAM
Old 02-11-2010, 03:08 AM
argus's Avatar
5th Gear
Originally Posted by denniswolf View Post
we get paddle shifters and 'S' mode on the accord even in japan they dont have that feature.
I am so jealous..envious may be the right word..I need those on my Coupe..
Two questions though, i) how's the shifting with the paddles? I test drove a Civic, and it seemed to miss a few times especially on down shifts.
ii) How's the 'pause' between paddle click and gear shift - and I'm not expecting you to say it shifts as quick as a Ferrari or something - but still, any lags there?
D1: Holds 1st
^ That sounds right on the money, Trip!
Mods:
Old 02-11-2010, 03:14 AM
6th Gear
we dont get the coupe though! But couldn't you just manually shift through the gears to get the same experience? I havn't noticed any missed shifts and it seems to respond pretty quickly.
'08 PMM v6 sedan:
Old 02-11-2010, 03:24 AM
argus's Avatar
5th Gear
Ok, then I'm a bit less envious (since you don't have the coupe) he he
Noted about the response to the paddle shifts, guess there are better quality components in the Accord as compared to the Civic.
Yeah I do occasionally manually shift just to get a kick out of it, but still, that don't beat the real thing..
Mods:
Old 02-11-2010, 09:25 AM
elp_jc's Avatar
elp_jc elp_jc is offline
Out of Control
To answer your question technically, I'm sure 5th is an overdrive gear (numerical ratio less than 1), but it's a lot higher than previous generations due to VCM. In other words, rpm in top gear is (a lot) higher than Gen7, for instance.
As far as having an 'OD' button, no such thing on Hondas. They skip from 5th to 3rd, either by a button (CR-Vs, etc), or manually (Accords, etc).
