Auto-Up power window Problem - Drive Accord Honda Forums
Old 02-15-2010, 03:01 PM
matt4258 matt4258 is offline
When I use the auto-up feature on the drivers window it goes all the way up and then comes back down a few inches. Its as if i were to stick my hand in it, it would trip it back down, but it is hitting the top and tripping the saftey feature. It doesn't do it if i hold the button up manually. Anyone experience this! I have a 2006 4-door ex, 55k
Old 02-15-2010, 03:18 PM
CYANiDE CYANiDE is offline
VTAKKKK
Send a message via AIM to CYANiDE
Have you recently disconnected the battery?
Code:
NOTE: Whenever the battery is disconnected, the
driver’s window AUTO function is disabled.
56. Start the engine. Push down on the driver’s window switch until the
window is fully open.
57. Pull up on the driver’s window switch fully to close the window
completely, then hold the switch for 2 seconds.
58. Test the driver’s window AUTO function.
2006 Accord EX i4 Sedan - 5AT - Graphite Pearl - [89,0xx miles]
FF Type II Coilovers || Skunk2 Front Camber Arms || Ingalls Rear Camber Kit || Acura TL-S 27mm Front/20mm Rear Sway Bars || K&N SRI
Old 02-15-2010, 03:47 PM
I just bought it yesterday and they did just put in a new battery. But the auto window works, it just comes back down when it bottoms out up top. I tryed your thing and it doesn't do anything, thanks anyways.
Old 02-15-2010, 05:20 PM
VTAKKKK
Disconnect the battery and try it. If you bought it CPO then you can take it back and tell them to fix it under warranty.
Old 02-15-2010, 06:18 PM
sodaks2k sodaks2k is offline
Moderator
Originally Posted by matt4258 View Post
I tried your thing and it doesn't do anything, thanks anyways.
Are you holding the window switch the whole time the window goes up? You should be. I've found holding it for 5 seconds (or more) in the closed position works well.
2014 MSM Accord Sport Sedan 6M
Old 02-19-2010, 02:26 PM
When you do this does your auto up/down work at all? Mine works up and down with one touch, it just does the same thing it would do if i were to stick my hand in it. it just goes back down like 2 inches when it closes all the way.
Old 02-19-2010, 03:58 PM
rafael73 rafael73 is offline
Too old to tolerate
Can we have the auto switch on the passenger side? My Pilot has on both front windows and it is nice. Maybe the 08 switch will fit ours?
Old 02-24-2010, 01:20 PM
phunctional's Avatar
phunctional phunctional is offline
-Gene
Send a message via AIM to phunctional
Code:
driverís window AUTO function is disabled.
56. Start the engine. Push down on the driverís window switch until the
57. Pull up on the driverís window switch fully to close the window
58. Test the driverís window AUTO function.
when i do this my drivers window stops functioning until i move the passenger window up and down a few times then it releases the driver window. and the auto up/down goes back to being non existant. anyone know whats up?
2007 Honda Accord EX-L V6 A/T Sport-shift
Desert Mist Metallic
ē Amber LED Interior
ē PA15-Hon2y iPhone Adapter
ē Tein SS-P
ē 18" Alloy's
Old 05-22-2013, 03:04 PM
Aratyhq Aratyhq is offline
Code:
Work for me 2009 accord exl
Old 05-25-2013, 11:03 AM
ceannt38 ceannt38 is offline
Ceannt38
my 04 ex does the same thing, only when it's cold, works OK after sun warms the car!
Title goes here
close
video goes here
