5-Speed Car Wont Move - Drive Accord Honda Forums
Old 02-18-2010, 05:10 AM
s10zr212 s10zr212 is offline
I have a 5-speed manual transmission 1996 Accord and just today it drove fine for about 1 minute, and now it will shift into any gear but once the clutch is disengaged the car wont move.
I did notice the speedo increases when the clutch is disengaged even though the car isnt moving.
Any ideas if this might be a clutch problem or if this is more likely a drive problem? Broken CV Shaft? Or any other ideas. THANKS
Old 02-18-2010, 07:04 AM
A&Fbro28's Avatar
A&Fbro28 A&Fbro28 is offline
Out of Control
Send a message via AIM to A&Fbro28 Send a message via Yahoo to A&Fbro28
sounds like time for new clutch bro...
Desmond,
08 Acura TL w/Technology Pkg
08 Taffeta White Honda Accord EX-L w/Navi Coupe (traded-in)
http://www.cardomain.com/ride/3093726
Old 02-18-2010, 07:35 AM
While in gear if I give it gas the speedo increases. Would this happen if this was a clutch problem? Or is this most likely a stripped CV Shaft?
Old 02-18-2010, 07:45 AM
A&Fbro28's Avatar
Out of Control
I it was cv stripped, it would make a loud "zipper" sound. My S2000's rear cv went out. woud not move put press gas in gear and it sounded like a loud zipper.
Desmond,
Old 02-18-2010, 08:22 AM
09^CBP^6MT 09^CBP^6MT is offline
banned
Its not the clutch, or the speedo wouldn't go up.
Old 02-18-2010, 09:48 AM
That's what I thought... thank you! Need to check my CV Shaft tonight.
Old 02-18-2010, 02:20 PM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
Check the left one first. I hope it's a reasonable repair.
Old 02-18-2010, 04:43 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
Either an axle isn't engaged to the diff, broken or the diff exploded. All that's turning is the final drive.
Probably an axle though.
Old 02-18-2010, 06:06 PM
A&Fbro28's Avatar
Out of Control
I'm gonna change my hypothesis to this...
Desmond,
Old 02-18-2010, 09:15 PM
banned
My guess is the diff took a crap.
Old 02-19-2010, 04:46 PM
Fredsvt's Avatar
Moderator
The diff issue is very common in snowy areas. People who get stuck spin the crap out of one wheel until the spider gears blow to pieces.
Older Chrysler FWD cars used to spit the gears through the case. VWs up to mid 90s (5 spd manual) would shear the pin holding the spider pinion shaft, and it would slide out and break the trans case or machine the case until all the fluid leaked out.
Title goes here
close
video goes here
