DIY oem switch on ebay foglight harness
So since my ebay switch did not fit in my dash at all, I bought an oem switch. Little did I know that the connectors on the back were completely different! I dont know how many of you guys experienced the same problem as me, but I am here to offer a solution.
Here is the ebay harness NOT plugging in with the oem switch ![]() It's modding time! ![]() I looked up wiring diagrams and found the appropriate wires to connect. And also, I GOT THE DIMMING FUNCTION TO WORK. which I think is really cool! I tapped into the illumination + and - from the sunroof and wires it in. ![]() and here's proof the dimming works: Full brightness: ![]() Dim: ![]() Since many of you probably aren't even going to try doing what I did, I'll save you guys the reading of wiring colors and diagrams. However if you are doing the same mod as me, feel free to PM me for help.
2007 Acura TL Type-S |
| Sponsored Links | ||
Advertisement | ||
Post up a DIY with no diagrams or steps? Not really a DIY. I say write it up and put it in the DIY section.
2006 Accord EX i4 Sedan - 5AT - Graphite Pearl - [89,0xx miles] FF Type II Coilovers || Skunk2 Front Camber Arms || Ingalls Rear Camber Kit || Acura TL-S 27mm Front/20mm Rear Sway Bars || K&N SRI |
the dim feature is suppose to work. the issue i ran into is when i dim it the lights on the radio flicker
2007 NHBP EX-L V6 Sedan 5AT CarDomain: http://www.cardomain.com/ride/3237223 DIY Documents: http://www.driveaccord.net/forums/sh...ad.php?t=40150 |
so the only way to make my oem switch dim is to tap into the sunroof switch
I used the pdf's found on this forum thanks to princess. http://www.driveaccord.net/forums/at...9&d=1265064509 http://www.driveaccord.net/forums/at...0&d=1265064523 I used this diagram to find out what pin does what. The ebay harness had two 12V red wires, I'm not exactly sure why...so I just left one of them taped up. As you can see in the fog light switch terminal view, there is the fog light + input, fog light control, circuit 12, circuit 11, and ground. fog light + input is just the basic 12V power source, fog light control is the button, and circuit 11 and 12 are dimming controls. Also, as you can see in the moonroof switch diagram, there are the same circuit 11 and 12 wires. splice into it and connect accordingly. On the ebay harness, its pretty straight forward. Give one of the red 12V to the fog light switch + input, and leave the other red 12v wire alone. Use the yellow fog light control wire from the ebay harness and put it on pin #2 in the switch. then the same for the ground wire. wrap everything up in electrical tape and you're good!
Nice write up...I may just get an OEM switch so I can get the dimming function working..Good job!!
2004 Accord EX-L AT 4cyl Sedan Mods Ebay Foglights, custom wiring LED Interior Lights Tint - 35% Front, 20% Rear K&N Air Filter Cathode Trunk Lights JL Audio JX 360/4 amp MTX Re-Q5 Alpine SPR-69 rear Alpine SPR-60C front component 06 Front bumper/Grille Projector Headlights w/6000K HIDs 17" Enkei Falcon Gun Metal Rims |
Nice write up...I may do the same thing once I get a set.
Good job does the led in the fog light switch turn on? when u turn the fog lights on.
in my opinion, i like it over oem because oem fogs switch off when you turn on high beams(if i remember correctly)
you only need 1 of the red wires because both of them will give 12v signals. just tape one of the other red wires off and tuck it away. your gray wire is ground and yellow wire is same as mine. IIRC, you also tuck the blue wire away too. let me know if you have any more questions
![]() Ok once you cut off those wire completely. ![]() how do you manage to fit those wire in there correctly and stay?? and could you kindly post a picture point out which one is the 12V parking light wire? I have a 2006 honda accord coupe ex-l. i've been looking up all night different website tells me different wire. I can't manage to find it. And Just wondering, Can I connect 12V Red Wire straight to battery? or I have to find a 12V wire such as 12V parking light wire, 12V cigarette lighter wire? Thanks! |
ga006959, here's a picture of the parking lamp wire. Hope that helps what you're looking for.
2007 Honda Accord Sedan SE AT Alabaster Silver Metallic 17mm TL RSB, Diode Dynamics Stage 2 LED kit, 5000k 35w DDM Tuning HID kit, Nokya Hyper Yellow DRLs, eBay foglight kit, 35% SolarGard Titanium Tint, LED Glow 7-Color kit, MH1 Retro/Blackhouse, Fujita CAI, Hybrid tail replicas, Megan Racing coilovers, Ingalls rear camber kit, Acura TL wheels w/ Conti DWS |
![]() Is the left black one or right black one. Sorry that got me so confused. or both? And Thanks for providing me the picture. |
No problem bro! You see the wire tap right, the pink thing, it has the black/red wire going through it (that's the parking lamp wire). The red wire also in the wire tap is just from my ebay fog harness.
| Sponsored Links | |
Advertisement | |
