Car shakes/vibrates when stopped with engine idling in drive. - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 03-12-2010, 03:53 PM
Signal9's Avatar
Signal9 Signal9 is offline
4th Gear
Hey folks, my Accord 09 4 door sedan 2.4L is shaking when the car is is drive.
I had a flash back that I was still driving my old 92 Accord because it had this problem as well.
Anyways, coming home today from work in the rain, I took lots of side streets instead of my usual freeway drive home. 25 miles.
I noticed the engine shakes when the car is in drive and stopped. If I put the car in neutral, the shaking goes away.
If I turn the a/c unit on, the shaking increases.
The rpm indicator does not fluctuate.
Any ideas?
09 EX-L Sedan, Taffeta White 4 banger Auto.
28.25 MPG Average
Old 03-12-2010, 05:14 PM
Sylv Sylv is offline
6th Gear
Send a message via AIM to Sylv Send a message via MSN to Sylv
I get the same sort of feeling in my car (v6), Can't really give you a good explanation, but the AC makes its shake more because the AC is putting more stress to the engine.
Old 03-13-2010, 07:31 AM
andrewd523 andrewd523 is offline
4th Gear
Sounds like it could be an engine mount. I would stop by the dealer and just show them so they can take a look. Worst case scenario they don't see anything and you just drive home.
Let us know how it goes.
2008 Honda Accord EX I4 Sedan
Old 03-13-2010, 07:50 AM
-THE PHANTOM- -THE PHANTOM- is offline
banned
Misfire??
Old 03-13-2010, 08:44 AM
jly488 jly488 is offline
same thing happens to my car but once the car warms up it goes away :/
Edaccord08 Edaccord08 is offline
Out of Control
How long have you had the vehicle ?
I am going to guess its probably normal if you had head lights , windshield wipers and defroster on(the defroster puts A/C on) .
With all these running the idle is probably little low and you feel the natural 4 cylinder transverse engine mounting movements .
If it still does feel different with acc off then bring it in for a check up, it could be bad mount .
Ed
2008 Accord LX, Alabaster Silver Metallic
gone 1985 XR4Ti
gone 1974 Opel Manta rally
aeoporta aeoporta is offline
moooo
on the off chance this migth help
http://www.driveaccord.net/forums/sh...ad.php?t=43155
instructions on how to disable a/c in defrost mode is in my signature help for new comers
Old 03-13-2010, 03:37 PM
Yukfoo's Avatar
Yukfoo Yukfoo is offline
5th Gear
Let the dealer worry about it if still under warranty.
2014 ASM Accord Coupe V6 EX-L Auto/w Navi
Old 03-13-2010, 03:45 PM
HondaGoon's Avatar
HondaGoon HondaGoon is offline
Maybe a belt issue? I haven't studied the mechanics of the newer engine design, but I assume that the A/C still runs off of a belt, which could explain the increased vibrations when its on.
Current: 2010 Coupe EX-L Navi
Previous:1998 Sedan EX
The Brake Pedal is not the Clutch
