Multiplexer unit - Drive Accord Honda Forums
Old 03-16-2010, 10:13 AM
AccordLXMaster's Avatar
AccordLXMaster AccordLXMaster is offline
Aspiring Tuner
Multiplexer unit
my multiplexer is out. hell its been out for almost a year and a half now if not more actually. i havent been driving with any speedo lights. ive learned how to tell if im speedin or not. but i was wondering where in the world can i get one of these from? and i kno everyones gonna say a salvage yard. but where else besides dealership as well. those the only places that have em?
JDM F23A Swap Done!!
98 LX
ENGINE MODS
-Spectre CAI
-Flowmaster 40 Series
-NGK G-Power Plugs
-4-2-1 Header
-CherryBomb GlassPack Resonator
COSMETIC MODS
-Double 5% Tint
-Twin Halo Projectors
-Bright White LED Turn Signals
-DDM Tuning 6000k 35w
SUSPENSION MODS
-Megan Strut Bar
Old 03-16-2010, 12:06 PM
03LXV6's Avatar
03LXV6 03LXV6 is online now
Moderator
Thought the multiplexer was only for the doors and windows. Anyhow salvage yard or dealership are the only places you can get one of those.
2007 EX-L 4DR
Old 03-16-2010, 12:45 PM
cajun's Avatar
cajun cajun is offline
Out of Control
Look at #11 here...http://www.hondaautomotiveparts.com/...IT+%28CABIN%29
Probably not much more than you'd pay for a used one.
2010 PMM Accord LX-P, TSX rear sway, GG lower grille, 35% tint, 50K+
2006 Toyo Sienna LE, 100K+
2002 Accord SE (sold), TL rear sway and upper strut bars
Old 03-16-2010, 01:41 PM
Aspiring Tuner
umm why was this moved?? from the 1998 accord section? oh well
and how exactly do i get to it and take it out? or am i already seeing it and just thinkin its somethin else?
98 LX
ENGINE MODS
-Spectre CAI
-NGK G-Power Plugs
-4-2-1 Header
COSMETIC MODS
-Double 5% Tint
SUSPENSION MODS
-Megan Strut Bar
Old 03-16-2010, 05:11 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
If you're talking about the left multiplex control unit, it's in the back of the left fuse panel.
If you have an aftermarket radio, immediately remove any wires going to the illumination circuit of the CAR. These are NOT battery power and ground wires, they are bus communication lines to the factory radio's back lighting. By plugging those lines into the aftermarket radio, it blows out the multiplex box, and you lose all gauge back lighting.
I've probably seen more than a dozen gen 6 Accords with blown left side multiplex units, from improperly installed aftermarket radios. And nearly all were installed by stereo shops.
Old 03-16-2010, 05:17 PM
nehonda's Avatar
nehonda nehonda is offline
6th Gear
This is the 98 Accord section (6th Gen)
I presume you have checked the fuses for the dash lights #10 and 13 in passenger fuse panel. The dash lights do use the drivers multiplexer unit located on the drivers side fuse panel to control the brightness and it is used for some other light controls also. There are some other multiplexers used in the car so be sure to get the right one. This one has a 24 pin connector according to the Honda service manual.
There is always ebay if you like to gamble on used parts (search for fuse panels - the multiplexer usually comes with it).
Good Luck
2000 Accord SE I4 F23A1 Auto - Sold @174k miles & 10 years ownership
1998 Accord LX I4 F23A1 5 speed - sons DD in DC
1986 Accord LX Auto Totaled @137k miles
1983 Accord LX 5 spd My Second Accord traded in
1978 Accord LX 5 spd My First Accord sold @ 100k
Old 03-16-2010, 10:20 PM
Accordriver's Avatar
Accordriver Accordriver is offline
6th Gear
How exactly do the multiplexers on the Accord work? I'm familiar with using them for digital applications (with a clock cycle, etc.) but I'm curious as to how they're applied in the Accord.
-03 Honda Accord EX V6
-Debadged-17mm sway bar-UR crank pulley-AEM CAI
Old 03-17-2010, 11:07 AM
Aspiring Tuner
fred?? 100. 100% accurate... thats when mine happened. thing is nothin is connected to the dimmer switch. unless ur talkin about another wire.
98 LX
ENGINE MODS
-Spectre CAI
-NGK G-Power Plugs
-4-2-1 Header
COSMETIC MODS
-Double 5% Tint
SUSPENSION MODS
-Megan Strut Bar
Old 03-17-2010, 11:48 AM
nehonda's Avatar
6th Gear
Im not a Honda electrical engineer so I cant tell you exactly how they work, but the service manual has a full page description if you have access to one. Here is a shortened version.
The main purpose is to reduce the number of wires in a harness by sending multiple signals down the same wires. There are about a dozen circuits that are multiplexed. Mostly timers, reminder chimes, power door locks and windows, wipers, dash light brightness, transmission interlock, keyless entry, etc. The CPU converts the inputs to digital signals and sends them to the recievers as serial signals where it is converted to a switch signal which operates the device. The system has wake-up and sleep modes for reduced power consumption, fail safe modes for faulty connections or modules and its own DTC system for troubleshooting.
Old 03-17-2010, 06:13 PM
PaulD PaulD is offline
5th Gear
Send a message via Yahoo to PaulD
what a crock !!
if I have something that I want to light up with the interior lights, where would you connect it ?
Originally Posted by hillstones View Post
Whenever I see a "thumpin" car, the male driver is always alone because no one wants to ride in his car.
Old 03-17-2010, 06:32 PM
Fredsvt's Avatar
Moderator
If you mean instrument back lighting, there are 12v sources, one being the shifter light in the console on autos. There is also 12v sources on the back lighting for the cruise switch or fog light switch on the left side of the steering wheel. These will dim with the dimmer.
However, if you have something that's a fairly high draw, you're going to have to put a relay in the circuit.
Old 03-18-2010, 02:30 AM
Jecht's Avatar
Jecht Jecht is offline
5th Gear
Man I was lucky. Never hooked tthat wire to my radio
Old 03-18-2010, 03:30 AM
dorkiedoode dorkiedoode is offline
Zzzz
Um there this guy selling it on 6thgen forum. Good guy might want to check it out. Scroll down there is one for the 5th then 6th gen. Make sure it's the right one
http://www.6thgenaccord.com/forums/s...ad.php?t=23175
2010 EX-L V6 NAVI SEDAN
1999 EX V6 COUPE
2006 Si
Viper 5901 DIY
3rd Brake Light LED Conversion
I unlock iPhones! 3G 3GS 4 4S 5
Old 03-18-2010, 04:26 PM
5th Gear
I use relays pretty liberally with accessories, just wouldn't think of using it for the light circuit on an aftermarket stereo.
Old 03-18-2010, 04:43 PM
Fredsvt's Avatar
Moderator
You shouldn't need to put a relay in for the radio's back lighting, but DON'T hook it to the "illumination" wires at the factory stereo's plug. You'll have to find that 12v source at another location, that's all.
