Red LED turn signals? (03-04 sedan)
Has anybody done it? I thought it would be original and not that bad-looking. Doesn't really serve a huge purpose, but I imagine it looks better than the current OEM setup. Thoughts? Anyone that's done it feel free to post pics.
Current: 2003 Honda Accord EXL: 2008- Growing up: 1992 Chevrolet Cavalier: 2000-2008 1986 Pontiac 6000 LE: 1995-2000 1982 Honda Accord: 1993-1995 1979 Honda Civic: 1991-1993 |
| Sponsored Links | ||
Advertisement | ||
front or back?
If front it's illegal
2004 accord sedan EX-L V6 Graphite Pearl AEM V2 cold air intake |
red led front turn signal would look kinda weird, lol. but for rears...you wont be able to tell anyways, but u'll get a fast blink all the time, if you're into that sort of thing.
2007 Acura TL Type-S |
Red would be illegal in the front, LED would not. Red is legal in the back of course since many vehicles have a single red brake/turn signal indicator.
However, you need a special resistor control box to get an LED lamp to function as a turn signal. |
If you're going to install an LED bulb for your turn signal - in place of your standard incandescent bulb - like hillstones was eluding to, you need to install/splice a load resistor (like the pic below) in each corner that you use an LED bulb...or else, like paperboy42190 said, you'll get the "hyperflash" when you use your turn signal. Normally, if you purchase LED bulbs from a reputable seller (like the ones advertised here on DA), you can also purchase these load resistors with the bulbs.
ASM 2007 EX-V6 6MT Sedan
MODS: -35% tint -Acura TSX retro headlights (Blacked out) w/amber LED turn sig bulbs & "bullet" angel eyes -Depo Fogs w/2500K bulbs -Hybrid Tail Lamps w/red 7w LED turn sig bulbs -Custom JDM style grill & mesh lower grill insert -K&N Typhoon CAI -USA Spec iPod interface -Front 12.6" Wilwood BBK & Rear 12" upgrade w/15mm Ichiba wheel spacers FUTURE MODS: -Tein Coilovers -Vossen 19" VVS-CV3 -Hybrid Mirrors -Tanabe Medalion Touring Exhaust |
Rear turn signal, sorry for not clarifying.
Doesn't look that hard to install. Would both the front and rear turn signals "hyperflash" if I installed only LED rears without the resistors?
LED bulbs draw less current; with cars now-a-days, (you probably already know this) the hyperflash is to inform you that one of your bulbs is burnt out. Both front and back turn signals (per side) are on the same circuit; so the hyperflash will happen on the side the bulb is burnt out (regardless if either front or back is burnt out) or for your application, where you replaced the standard bulb with the LED one. The load resistor just simulates the current an incandescent bulbs draws. Hope this helps.
2003 Accord LX-V6 5% Rear Tint, 25% Front Tint | Weapon R Dragon Short Ram Intake with APC Cone Filter | Acura TL 17mm Rear Sway Bar | Eagle Eye LED Taillights - Red/Smoke | Nokya Hyper Yellow Hi-Beam Headlights | Resonator and Pre-muffler Removed | Test Pipe |
They both use the same voltage, which is dependent on what is provided by the car's electrical system. LEDs are current dependent devices, and its the lack of current draw in the circuit that causes the "hyperflashing" of the flasher switch.
Does that mean that the load resistor siphons off some current, through a low resistance resistor, to the body to simulate the higher current draw of a filament bulb?
Yes, exactly
Thanks for the help, guys. Retrosolutions, do you make any red LEDs that would fit in the 03-04 sedan's rear turn signal housing?
Well, that would technically be a 7440 RED, which we'd have to make specifically for you, but we can do it.
| Sponsored Links | |
Advertisement | |
