tiny light on seat heater switch not working - Drive Accord Honda Forums
Old 03-26-2010, 12:52 PM
oldmansi's Avatar
oldmansi oldmansi is offline
4th Gear
This may be very minor problem but I am not sure how to fix. I have a 06 V6 coupe with leather seats. I noticed the other day that when I put on the seat heater switch on high that the little light does not light up. However, it does light up when I put the switch on low and also works fine on both high and low on passenger side. Both seats will both heat up properly on either high or low. If this is a big deal ($$$) to fix I will just live with it but if its minor and I can fix myself then I will do it. Anyone have any ideas on how to fix? Seems minor , I know, but it just bugs me.
06 Accord coupe EX V6 AT (cool blue metallic)
Old 03-26-2010, 03:43 PM
Aviography's Avatar
Change the bulb, which will be a bit of an effort since you have to pop the console cover to get to the bulbs.
My driver side seat light (not the hi/lo indicators) bulb has been burned out for 6 months now, I just can't be bothered now, no time to fix something cosmetic and has no functional effect on the seat heater operation.
TL shift knob, Hidden Hitch,
Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960
DA Moderator Team
Old 03-26-2010, 04:03 PM
oldmansi's Avatar
4th Gear
Thanks for the info, I thought it was just a bulb but wasn't sure. Seems like I should be able to take care of this myself and won't have to pay someone.
Old 03-28-2010, 01:26 PM
badboy58 badboy58 is offline
3rd Gear
Its extremely easy, mine has burned out also. I am gonna fix mine in the next few days, just got the bulb.
2003 Accord EX-L V6
Interior
'07 Shift Lever♦DD Stage 1 LED's
Exterior
HFP Lip Kit♦Limo Tint♦M3 Roof Spoiler♦LED Smoke Tails♦HID Yellow Fogs♦Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal 7 Spokes♦Hawk HPS Pads♦X-Drilled/Slot Rotors
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Performance
Spoon Radiator/Oil Cap♦Stainless Brake Lines♦Outlaw Spacers♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
Old 04-03-2010, 03:48 PM
hillstones hillstones is offline
3MTA3
It is no effort at all. Just pull the trim panel with your hand. Unplug the heated seats and remove the switch with a screwdriver. Go to any Honda parts site and bulbs are all listed under the Switches category. The heated seats used two kinds of bulbs. One larger bulb is for the button illumination and one smaller bulb (x2) is used for the on/off indicators.
Old 06-05-2010, 10:18 PM
Jaggy01's Avatar
Jaggy01 Jaggy01 is offline
3rd Gear
Interesting. My friend has an '04 coupe and he was mentioning to me about his driver side seat warmer bulb was burnt. I just noticed I have the same issue. I just find it strange this occurs only on the driver side.
Accord 2006 Coupe 7.5 Gen EX-L 2.4L I-4 5AT Sapphire Blue Pearl: 88k kms. Addons: Fast Wheels - Groove mags. Grillcraft upper and lower grill (HON1137/1138B), Weathertech "DigitalFit" liners OEM Accessories:Fog Lights Kit (08V31-SDN-101) Block Heater (08T44-S5B-100) Front + Rear Mudguards (08P00-SDN-100A) (Audio Mods: Kenwood KDC-X994 Head Unit, Kenwood KFC-1730P Component Front speakers, Kenwood KFC-X993 6x9 Rear speakers, Sony 5 CH Amp, 12 inch sony sub. SWI-Jack steering control interface.
Old 06-06-2010, 06:04 PM
3MTA3
Or it can happen only on the passenger side, like in my case. Then the sunroof bulb and TCS bulb burned out too. Bulbs get old, they burn out. Thankfully they are very easy to buy and replace.
Old 02-15-2011, 11:27 AM
harperhouse harperhouse is offline
My First Post
how do you take the bulb out of the switch
Old 02-16-2011, 04:58 AM
mugenmaster's Avatar
mugenmaster mugenmaster is offline
4th Gear
mine burned out too, driver side
2003 v6 coupe
Graphite Pearl
Mods:
35% tint all around
USA SPEC pa15-hon2
Acura TL 17mm RSB
tein s-tech
deck lid spoiler
HFP lip kit
OEM acura tl 17" rims
Racin Hart C2 19" 3-piece
blue interior leds
foglights
Wishlist:
borla catback exhaust
paul's SRI
coilovers
camber kit
get rid of all dents/door dings
Old 10-15-2012, 08:54 PM
Gu3r0-21 Gu3r0-21 is offline
is there any way to find the bulb online? im kindof getting bothered by mine already... only defect in my interior
Old 10-16-2012, 08:49 AM
frenzal's Avatar
frenzal frenzal is offline
4th Gear
www.hondapartscheap.com
Go in the "switch" category...
Car: Honda Accord coupe 2005 V6 6-speed saphire blue
