Cant lock\Unlock Door with Key Remote...? - Drive Accord Honda Forums
Old 03-28-2010, 02:07 PM
toicy4ya's Avatar
toicy4ya toicy4ya is offline
3rd Gear
Sup Everyone,
I cant lock\unlock or open the trunk using the key remote. It stopped working from one day to the next. Initially i thought maybe the battery needs to be replaced but the red light illuminates on the key remote whenever i press a button. I think it just may need to be re-programmed. I thought i saw instructions somewhere on the forum. Anyone know where i might find this information?
Note: I'm not referring to the immobilizer or chip in the key. That works perfectly fine.
Any feedback would be greatly appreciated. btw, i tried search but it didnt yield any positive results.
Thanks
2006 Honda Accord EX i4 Sedan W/ Nav.
2000 Honda Accord EX V6 Sedan
Old 03-28-2010, 02:59 PM
laxplaya88's Avatar
laxplaya88 laxplaya88 is offline
3rd Gear
Did you replace the battery?
My Cardomain Page
2004 Honda Accord EX
20% Tints
HID
Kicker L5 & Orion 800 Watt Amp
LED Strips under dash
18" Chrome Rims
Chrome Pillars
Blacked out grille
Old 03-28-2010, 03:07 PM
toicy4ya's Avatar
3rd Gear
No, I think the battery is still good. The red light illuminates on the key remote whenever i press a button. I think it just may need to be re-programmed.
Old 03-28-2010, 03:32 PM
dominicstl's Avatar
dominicstl dominicstl is offline
2007 SE Sedan
Are you talking about the battery in the car? When I needed a new battery, I couldn't unlock the doors using the key, but the red light was still coming on as far as I can remember.
2007 Honda Accord SE i4 Moroccan Red
Diode Dynamics 6000K HIDs
Diode Dynamics LED Switchbacks
Diode Dynamics Stage 2 LED Conversion
Diode Dynamics Nokya Hyper Yellow DRLs
Old 03-29-2010, 03:40 AM
toicy4ya's Avatar
3rd Gear
No im referring to the battery in the key fob.
Old 03-29-2010, 07:53 PM
DTM DTM is offline
03 EX-L, V6, 4 DR
I am having the same problem on my 03. I took the remote to a watch repair kiosk and he checked the battery and said it is fine. Searching for answers and troubleshooting info with no luck so far.
Old 03-30-2010, 05:47 AM
toicy4ya's Avatar
3rd Gear
I replaced the battery to the key fob yesterday to no avail, im still having the same problem.
Does anyone have the Key Fob programming instructions to lock\unlock the doors and unlock the trunk for an 06 accord?
Old 03-30-2010, 07:22 AM
sirsaechao sirsaechao is offline
3rd Gear
Send a message via AIM to sirsaechao Send a message via MSN to sirsaechao Send a message via Yahoo to sirsaechao
I had the same problem with my 03. Changed the battery and nothing. Never got around to use the alarm until 3 months ago. Went into Honda to get a HP Power Steering hose and was like wth just order me another keyfob. Programmed it via directions and good to go now. Everything is working.
Old 04-05-2010, 07:37 AM
mjamidon224 mjamidon224 is offline
amideus
im having the same problem on my 03 accord. sirsaechao, can you post the directions given with the new keyfob?
Old 04-05-2010, 08:23 AM
toicy4ya's Avatar
3rd Gear
Here are the instructions i used. You need to follow the steps quickly in order for it to accept the programming. Hope this helps.
1.turn key on (II) hit lock button on fob - turn key off
2.turn key on (II) hit lock button on fob - turn key off
3.turn key on (II) hit lock button on fob - turn key off
4.turn key on (II) hit lock button on fob
5.you should hear the door lock actuators work(you are in the programming mode)
6.hit lock buttons on all fobs you should hear the door actuators working with each button press.
7.Turn ign switch to off
8.Remove key and viola, all keyless remotes shoud work then.
**You must do each step quickly for success, i would say within 5-6 seconds. It took me two tries.
Old 04-10-2010, 05:05 PM
DTM DTM is offline
03 EX-L, V6, 4 DR
Thanks, just did it to my 03 and my remote works now. Thanks again.
